HMS Berwick 1941
Re: HMS Berwick 1941
Post by ModelMonkey »
Superb, Phil! :big_grin:
Strategos Augustus
Post by Strategos Augustus »
Phil R wrote:
Guest wrote:Anyone know how far away the base kit is from a Hunt The Bismarck era Suffolk............?
HMS Suffolk is next on my to do list .I haven`t investigated it fully yet .but I will need to cut down the quarterdeck as a start.
Regards Phil
I get the feeling that the releases of Cornwall and Kent are going to be keeping you busy for a while.
Looking forward to your HMS York, btw. :joker:
Maarten Sch�nfeld
Post by Maarten Sch�nfeld »
Regards Phil
Well, I bit the bullet and I am progressing well...
viewtopic.php?f=59&t=202855
Roger Whittaker +9/13/2023
Phil R
Post by Phil R »
Hi Maarten ,I bit an even bigger bullet ,I`m currently converting this kit to HMS London after her rebuild.It`s one heck of a job .but I`m enjoying doing it,which is what the lark should be about!
Regards Phil
Maarten Sch�nfeld
Phil R wrote:Hi Maarten ,I bit an even bigger bullet ,I`m currently converting this kit to HMS London after her rebuild.It`s one heck of a job .but I`m enjoying doing it,which is what the lark should be about!
Regards Phil
Hi Phil,
Yes, that's really a large undertaking! Beginning with the hull: have you worked out a way to eliminate the bulges and get the side walls vertical? I assume you will build it waterline like most of your ships, otherwise you'll need to place the rudder, the props and the propshaft 5 scale feet backwards.
Do you have a set of plans of London's superstructure after the rebuild?
Phil R
Post by Phil R »
Yep ,altering the hull was the first thing I did ,and after a short break it is well on the way to being finished,see attached.
Cheers Phil
Maarten Sch�nfeld
:good_one: :good_job:
Keep going! And keep us posted!
Maarten
Return to “Completed Models”
