Thank god I am not the only one! I mean what is the best solution here? Does screwing the models down on a strong (wooden?) base solve this problem for good? I know a lot of people do this and yet some hulls deform again even with the ship being securely fixed. What is this witchcraft?rfwood1 wrote:I am concerned about the very same thing.
Resin "Memory" of a Warped Hull (Correcting warped hulls)
TheDuneSea
Re: Resin "Memory" of a Warped Hull (Correcting warped hulls
rfwood1
What is the best solution here? Does screwing the models down on a strong (wooden?) base solve this problem for good? I know a lot of people do this and yet some hulls deform again even with the ship being securely fixed.
I tried to super glue my HMS Lion onto a strip of metal, maybe 1/8" thick, but the ship bent the metal, so I don't think that was a good idea. (Of course, maybe I should have used a thicker chunk of steel.)
- JIM BAUMANN
Good evening!
weighing in with some thoughts;
I have a morbid (and healthy!! ) fear of anything model shippy trying to warp,
be it wood, plastic and indeed resin...
I do not trust wood of any kind to resist resin warpage as a base, especially not plywood or MDF etc
I always secure all model ships--resin or plastic to a stainless steel plate
( I work in the marine/ yachting industry -so stainless steel is common and available; mild steel is muuuch cheaper
and more readily available--just ensure its well painted to prevent surface corrosion over time)
for 1/700 3 or 4mm thick pending length of model...
( or for 1/350 Big Battleships like the (resin ! ) ROMA I went to 5 mm )
here is my step by step of attaching model ships to base ( and watermaking thereon..)
the images and text should be of assistance
viewtopic.php?f=4&t=37223
HTH
JB
HTH
JB
