1/96 SS Jacques Schiaffino
setori
Re: 1/96 SS Jacques Schiaffino
Post by setori »
The vents are made with brass or aluminium tubes and vacuumformed tops.
I made the masts with aluminium rods and styrene. the articulation between the mast and the derrick is made with small photoetched parts
setori
Post by setori »
I made one double mast with the corresponding derricks. As I want to finish the central part first, I'm making the railings with photoetched stanchions made by Saemann
Post by Fliger747 »
A nice scale to work in, one can do convincing wooden decks and may other small details!
Thanks for sharing! Tom
setori
Post by setori »
I've done some work on the masts and derricks
Post by Fliger747 »
One of the advantages of a larger scale is the ability to do a convincing job of rigging the cargo booms. I larger models, especially sailing ships examining the running rigging is quite fascinating!
setori
Post by setori »
thanks Tom !
While I was fixing my rigging, I was thinking of the guys who build sailing ships. This must be a nightmare, I admire them
setori
Post by setori »
The forward part is almost complete, only missin : top mast railing and rope reels.
I ve tried Hauler for etching the parts I designed on Corel Draw, they did a good job and they're not expensive. You can see it with the rope reels
Iceman 29
Post by Iceman 29 »
Can�t wait to see the rest! Superb! :thumbs_up_1:
Pascal
setori
Post by setori »
thank you Iceman !
But summer is not a good time for ship modelling : go to the beach in the afternoon, fiestas in the evening and shaky hands the day after !
Anyway I started working on the lifeboats. 2 are metallic and I made them with resin, another one is clinker built
setori
Post by setori »
The forward part is finished, the only missing thing is the name of the ship, and I still don't know how to make it.
I've ordered BECC White Vinyl Lettering, I'll make tests but this ship has such a long name !
Post by Fliger747 »
For ships name and numbers I have been able to utilize a "Cameo" machine which allows one to cut out (1) quite small and accurate letters and numbers (2) use the computer driven bead to cut stencils. I have been able to do many of such items, even draft marks with this machine. I got the idea for this from 'Iceman" who had used these machines previously. Many fonts are available and one can add fonts from on line, allowing one. to type out the arrangement of desired characters.
setori
Post by setori »
Thanks Fliger !
The Cameo machine costs 300 euros !
I'll try first the becc letters I've already ordered.
If it doesn't work, there's a fablab in my town (where i made laser cut for my hull) and I think they have a cameo machine.
The challenge then will be aligning all the letters.
setori
Post by setori »
here are BECC letters
DrPR
Post by DrPR »
I worry that these self adhesive letters might fall off after the adhesive has aged. They often are excessively thick for lettering on models. Sometimes you can't find the right color letters. And the letters may change color with ageing.
The solution I have used is this:
1. Paint the area where you want the lettering in the desired color for the letters. Let the paint dry.
2. Apply the rub-on letters.
3. Spray the background color over the lettering area. Let the paint dry.
4. Remove the rub-on letters. Ordinary masking tape has worked for this.
This allows you to use any color rub-on letters as "reverse stencils" to make any color lettering. The resulting lettering will be only as thick as the layer of paint. And you won't have to worry that the letters will fall off or change color!
setori
Post by setori »
wow ! very clever ! I m gonna try it
thank you
Post by Fliger747 »
I have used both methods for lettering. The Cameo-Cricut type vinyl stuff is often used on cars and whatnot and seems to adhere well. I overspray the applied lettering with a dull coat type material. The best most permanent method is as Phil describes as only paint remains. However the paint will attempt to creep under the edges of the masks. One can use a coat of the letters color (eg white) and then spray the hull color. A number of very light airbrush coats will minimize creep under the letters.
I suggest you experiment with this a bit first!
Good luck! Tom
DrPR
Post by DrPR »
I second what Tom said about spraying over the letters with the letter color before applying the finishing background color. For example, if you want white letters, after applying the rub-on letters spray a light coat of white paint over them. This way if any paint bleeds under the letters it will be white. Then spray the background color (grey, etc.) over the letters.
I developed this technique many years ago when I needed some silver Railroad Gothic Condensed (I think that was the font) letters for a model locomotive. I found decals and rub-ons in every color but silver! So I bought some black rub-ons in the correct font and size and used them as stencils.
setori
Post by setori »
thank you all :thumbs_up_1:
Iceman 29
Post by Iceman 29 »
Thanks Phil. :thumbs_up_1:
Pascal
setori
Post by setori »
I tried DrPr method with BECC letters 4mm high.
But these letters are too big, 3.5 mm would be much better.
I'm not very satisfied with the result, maybe because of the vinyl lettres. There are traces of glue left, as you can see and white paint is peeled in some places.
Conclusion : I still don't know what to do.
Maybe I could go to the fablab in Sete, but it's expensive
