First Littoral Combat Ship Gets Underway
- chuck
Re: First Littoral Combat Ship Gets Underway
WWII destroyers can send a Nimitz class carrier to the bottom as well, provided the latter stand still and take the 8 torpedoes on the same side. But it doesn't prove anything.
Gone Asiatic
A NIMITZ class carrier has an airwing to contend with......an LCS has......
No Quarter Asked - None Given
Ultimo Tiger
An LCS might be lucky enough to have a long range SSM
Gone Asiatic
Meh, the LCS has the 57mm Bofors that has roughly the same range as the 5"/38 with many times (I assume) better accuracy. Also much faster, so it can run away till a better situation presents itself.
- ASFC
Meh, all ships are targets if you are in a sub!
The Israelis obviously think it lacks firepower because they are spending a fair whack of money to make sure the ones they get have the required firepower.
Ships on the Slipway
HMS Victorious R38
USS Pinckney DDG-91
SAS Drakensberg A-301
On the drawing board
HMS Dumbarton Castle P265
HMS Albion L14
VT Sergey Osipov
- Seasick
Under built, under manned, under armed, under way. Under RuMsFeLd.
? Seasick?
? Seasick?
- Werner
Remember, these ships' kit is one Swedish 57mm, 2 x M2 .50cal and a launcher for the RAM missile. So, the longest range weapon is 7Km or so.
-- "A Nation at Risk" (1983)
According to NavWeaps, the 57mm has a range of 17,000 m, or 17 km.
- Werner
Sorry, was going on the range of the RAM.
Nevertheless, these are all essentially horizon weapons.
Gone Asiatic
The LCS will get punk`d if it has to fight anything other than a lightly armed patrol craft.
- chuck
It was meant to fight lightly armed patrol craft. Generally people don't mean anything more by Littoral.Gone Asiatic wrote:The LCS will get punk`d if it has to fight anything other than a lightly armed patrol craft.
Gone Asiatic
Worth $500 million EA and no interchangeable mission modules?
- Lesforan
Tri-hulls are notoriously rough-riding in anything but calm waters. The tri-hull may draw less water than a single hull, an advantage to close-inshore use.
What is the Air Force doing ordering modules for a Navy ship? Haven't they got enough transport aircraft to schmooze politicians and contractors in now? Maybe aircraft do not allow enough transit time to sufficiently lubricate clients and close deals.
Any number of designs of fast attack craft have this thing outgunned. I suggest they turn them over to the Coast Guard for use in stopping smugglers. That big, empty hull could hold a lot of interdicted drugs or would-be immigrants.
Les Foran
On the Oregon Trail
On the Oregon Trail
- chuck
That depends on what the average cost per unit over the intended 50 hull run is, not the cost of the prototype.Gone Asiatic wrote:Worth $500 million EA and no interchangeable mission modules?
- Lesforan
Perhaps part of the weapons suite is intented to be inside the drop-in modules. VLS maybe?
Les Foran
On the Oregon Trail
On the Oregon Trail
LCSSailor
As part of the commissioning crew of USS FREEDOM, it saddens me to see so many postings by individuals who have absolutely no clue about USS FREEDOM, USS INDEPENDENCE, the Littoral Combat Ship program, naval weapons systems, or naval tactics in general. My recommendation to those of you who are not involved in the program and have no real knowledge of any of the issues you have raised is to remain silent until these ships are delivered to the Fleet and tested to see if their true capabilities match up to the hype.
And just in case you are wondering - everything demonstrated by USS FREEDOM to date says she'll be more than a match for her intended enemies...
- Jack Ray
Who are her intended enemies?LCSSailor wrote:As part of the commissioning crew of USS FREEDOM, it saddens me to see so many postings by individuals who have absolutely no clue about USS FREEDOM, USS INDEPENDENCE, the Littoral Combat Ship program, naval weapons systems, or naval tactics in general. My recommendation to those of you who are not involved in the program and have no real knowledge of any of the issues you have raised is to remain silent until these ships are delivered to the Fleet and tested to see if their true capabilities match up to the hype.
- Werner
Perhaps you could bring sight to the blind?
For example, what are the available mission modules?
Your hot rod has certainly failed in one key aspect of it's mission: it's extravagant price overruns forbid acquisition in any quantity, leading to the cancellation of LCS-3 on.
Your LCS is destined to be a one-off oddity with no mission in our Navy. Perhaps Pakistan or Taiwan will find a use for her.
Gone Asiatic
A modern day Vesuvius perhaps? Perhaps that will be an ironic benefit of the program....its cancellation!Werner wrote: Your hot rod has certainly failed in one key aspect of it's mission: it's extravagant price overruns forbid acquisition in any quantity, leading to the cancellation of LCS-3 on.
Methinks Pakistan won`t be able to afford such an expensive patrol boat; Taiwan will likely continue to build indigenous or European-influenced designs with more capability at a fraction of the cost (producability and capability).
