Calling all Steregushchy-class (Стерегущий) Project 20380 corvette fans
GTDEATH13
Re: Calling all Russian Steregushchy class corvette fans
Post by GTDEATH13 »
I found these...
NIKOS (NICK)
Skipper46
Post by Skipper46 »
Timmy C wrote:I was able to find this, but not at any larger size.
Timmy C - this a absolutely great. I have found a wide range of exellent photographs of the front and sides of KASHTAN but the rear and overhead has been very difficult. It is worth noting that this is an earlier KASHTAN verison and not the one fitted on STEREGUSHCHY - the lower "skirt" (I presume that they are used to capture the expended cartridge cases) and the arrangments for connecting the Gatling gun to the missile rail are quite diffierent but are very easy to deduce from the excellent photographs available. Now all we need are the hull frame or cross section drawings!!!! Cheers from OZ.
Dave P
I'm glad you find it somewhat useful - I was worried about the possibility of different versions as well!
Post by Dave Wooley »
Timmy The Drawing of the Kashtan is just the ticket . As I have said so often you really can't have enough information .
Here're some more shots of Stere's Kashtan/Kortik. There are more shots of the ship's starboard side on pages 2 and 3 of this thread:
http://forums.airbase.ru/2007/09/t57614 ... schji.html
Sean Hert
Post by Sean Hert »
You rock Timmy!
Sean Hert
Skipper46
Post by Skipper46 »
Thanks Nick - Had not seen the very useful shot of the flight deck control centre before - not many clear shots of this area. This will definitely help in accurately modelling this area. Cheers
dave P
ozpirate
Post by ozpirate »
Noticed you were looking at the front of your gun try this shot then from the back
Building
1/72 Admiral Kuznetsov
Mick
Tumut Australia
Hi Mick That's a great shot .I must admit I hadn't any photos of the rear of the Kortnik. Also photos of within the bridge wings are rare has hens teeth a bit of a blank spot? Thanks for posting up the picture very useful indeed.
ozpirate
Post by ozpirate »
Not from Steregushchy but same gun
Building
Mick
Tumut Australia
Skipper46
Post by Skipper46 »
We seem to have a great photograph collection and some excellent plans of this ship but as I see it there are still two key items we lack - pictures of the inside of the bridge wings and of course hull lines/ cross sections. No chance you can work your magic again timmyc??? Cheers
Dave P
Sorry Dave - the Airbase forum is dead right now, so none of the old threads are accessible. I was already looking for hull lines last time, and there weren't any. I don't think you'll find much on the inboard side of the bridge wings either, since most of the photos were taken from dockside.
Skipper46
Post by Skipper46 »
Does anyone have any idea what STEREGUSHCHY's ship's badge looks like? I cant find one on any of the photographs that I hold. Cheers Dave P
This what a Russian Navy ship's badge should be based on as I understand it.
I hope to commence building the Steregushchy some time in August/September at 1:100 scale . :thumbs_up_1: :wave_1:
Sean Hert
Post by Sean Hert »
Sooo looking forward to your build Dave!
Sean Hert
Neptune
Post by Neptune »
Me too, although I'm likely to be onboard again by then, probably without connection.
Maybe I can already start the topic, like I did on Kiev, that'll get you moving! Besides, June was the approx finishing date for Kiev, and August and September is quite a while later, so what would you be wasting your time with in between??? :heh: :heh: :heh:
The merchant shipyard
Skipper46
Post by Skipper46 »
Dave Wooley wrote:I hope to commence building the Steregushchy some time in August/September at 1:100 scale . :thumbs_up_1: :wave_1:
Great news Dave - how have you approached the hull section issue? I am still working up my own interpretation of the hull sections for 1/72 scale and I hope to start building the hull *Plank on frame) before the end of the year,
Cheers Dave P
Neptune wrote:Me too, although I'm likely to be onboard again by then, probably without connection.
These over runs :heh: a normal procedure for all naval projects!!!!! Roel Just think of how long the old Gorshkov has taken , even I'm building faster than that project and that's saying something. :big_grin:
Sean Hert wrote:Sooo looking forward to your build Dave!
Hi Sean I just want to get started on that Kashtan , now thats what I call a headache :heh:
Cheers Dave P
Hi Dave looks like we will be on the same project at around the same time but at different scales, this will be interesting . The hull will be plank on frame but I'm also looking into the possibilities of going GRP. As with all the models I build I do like to have them working even if it's only to prove to myself that they do just that .
