Calling all Queen Elizabeth-class (1914-1947) fans
Dino Carancini
Post by Dino Carancini »
...if you should build one of the QE class battleships in 1/350 ... the Barham in '41 as example :eyebrows: , wich photoetched kit would you buy?
One of the HMS Hood, the KGV set or something else?
In my opinion the GMM HMS Hood set is the one with more common details with QE class.
Dino
Dino Carancini
Laurence Batchelor wrote:
...am I wrong or there aren't rivets on the roof of the towers?
Foeth
Post by Foeth »
Only the 15" Mk II turret on HMS Hood has rivets. That is, non-flush...
largeallan
Post by largeallan »
Interesting she's flying her jack while still underway
Joseph R
Post by Joseph R »
Dino Carancini wrote:...if you should build one of the QE class battleships in 1/350 ... the Barham in '41 as example :eyebrows: , wich photoetched kit would you buy? Dino
This is probably where you should consider making your own PE. Much cheaper that way.
IG: @somewhere_east_of_suez
www.JosephReindler.com
Laurence Batchelor
Post by Laurence Batchelor »
EJ Foeth wrote:Only the 15" Mk II turret on HMS Hood has rivets. That is, non-flush...
Also the KGV's had rivetted turret plating...
Foeth
Post by Foeth »
except that it's a 14 inch turret.... :welcome:
Laurence Batchelor
Of course! I was just suggesting the practice was continued after Hood :big_grin:
Dino Carancini
...if this is the Barham in 1941, and I think she is, she still has her stern catwalk, a nice vintage touch for a WWII model...
Just to know what was the pourpose of that thing? ( be patient please my military experience is limited to field howitzers :heh: )
source : http://www.worldisround.com/articles/16107/
Post by Guest »
those were rather BOLTS not rivets because the necessity of
eventual easy acces in case of gun dismounting.
Post by Guest »
And other ships had also bolted turret roofs but bolted from inside,
at least on sides. plates themselves could be joined by "keys"
Laurence Batchelor
Still they protude like riverts :big_grin:
My mistake, though I'm aware of the bolting on the turrets.
I've seen them lifted off cruisers in photos, it helped no end on ships Like Liverpool when there were getting rebuilt in the US in WW2
Dino Carancini
Guest wrote:And other ships had also bolted turret roofs but bolted from inside,
... let me understand, with "keys" you mean like late war german tanks? And in this case were the plates welded each other?
Post by Guest »
A bit different: one plate could be "milled" in ad other "milled" out and
joyned like "wall panelling" with own key.
As welding in those times was practically not existing the plates were
bolted on sides to frames. Side and fore plates as well.
Even later when welding became more common there were much of
problems with joyning by welding the thick surface hardened steels or mild steels (vide German welding problems with their Wotan materials
in spite being in van with welding technics)
I'm not sure but I dare to think the thickest plates were still bolted (at turrets at least) :big_grin:
Dino Carancini
Anonymous wrote:
Dino Carancini wrote: ... let me understand, with "keys" you mean like late war german tanks? And in this case were the plates welded each other?
Thank you!
Dino
Dino Carancini
Pom Poms!
I was studying the Barham 1941 drawings on "British Battleships of WWII" and I saw a strange thing, the last added pom poms ( near the conning tower ) are represented as MKVII mounts ( quad ) while in the text they talk about MKVI mounts ( octuple ).
Profile Morskie drawings shows instead two MK VI
I think they were octuple mounts, but I'm not 100% sure about this... any idea?
TIA
Dino
wr
Post by wr »
Quads.
Mistake in the text.
Dino Carancini wrote:Pom Poms!
TIA
Dino
Dino Carancini
Thank you for the quick answer wr! :thumbs_up_1:
wr wrote:Quads.
Dino Carancini
HMS Queen Elizabeth at the London Science Museum, an interesting representation of the QE in her mid-life aspect.
http://wmunderway.8m.com/museum/londons ... ience.html
Post by ModelMonkey »
Drools.
