What ship are you doing?
- Jose Chaica
I don't really have any good interior shots of Yorktown. But I can give you some descriptions of interior spaces. I'll be writing about one aspect that is true for all of the carriers in a couple days.
Finally dug up the picture I have on this. This is ESSEX November 1944 following a Kamikaze hit. The ammo cans are visible on the bulkhead inboard of the catwalk. Normally these would be covered with a fabric "flash guard" meant to provide some measure of protection from fire; you can see these in the interiors of quad 40mm tubs as well.grim reaper wrote:Ok guys, I have a question; I'm stumped I've looked a books pics and I have yet to find pics of where the 20mm ready service lockers are placed, my guess would be where the mounts are located but no evidence that shows this any help is welcomed. Chad
By the way, 15 men died in this kamikaze hit and 44 others were wounded. That's probably blood you see on the deck at the base of the guns.
Hangar Space Info
OK, been meaning to do this for a while.
One of the things that was reported early on with the Essex class was that night time operations in the hangar were highly disrupted by the need to darken the hangar whenever a door was opened. One of the solutions was the creation of what were initially called "Light Labrynths" around doorways to the outside. I've also seen them referred to as Light lockers. These were light sheet-metal covers over the inclined ladders leading up to doorways from the main (aka hangar) deck. The documentation I have on them indicates they were to be manufactured by the ship's force so they could have appeared at any time (as opposed to upon a major overhaul). If you want you can read the original I OCR'd and posted here.
CV-16 Lexington and CV-17 Bunker Hill got them first as they were test ships for the concept. All of the other ships should have got them starting July 1943 or so.
I have some pictures of them, here's one of CV-13 Franklin's damaged after the Kamikaze attack of October, 1944 (this was the one just aft of the #2 elevator that lead up to where the ship's launch was kept.
This is the top of one further aft on the port side as well as a slightly different shot.
This would be farther back on the port side.
There were very few open platforms on the inside bulkheads of these ships as compared to, say, the Yorktown class. There were some, and a lot in the overheads, but not to the doors out to the decks.
- Devin
Tracy,
I wonder why they'd enclose the ENTIRE ladderwell? Modern warships use temporary canvas covered panels that fold out of the way during the day (as I'm sure you know). I wonder if it took a while for them to figure out how to do it more easily, or if the wide open expanses of the hangar deck made this necessary?
-Devin
-Devin
Well, these were just for the inclined ladders on the inside of the hangar bay. My guess was that they were still experimenting; hence the 20' black deck around the opening.
By the way, there were two at the forward limit of the hangar bay, just outboard the aft end of the #1 Elevator. I can see that. Just not clear enough to know anything other than that they were there. I have no idea what this structure look slike so if anyone could suggest a book that they know has a picture of this area I'd appreciate it!
James Noblin
Thankyou for the pictures of the Paravane chain openings Tracy. Do you happen to know if the chains made it up to the deck? Have you ever seen a picture of the chains at the bottom of the bow and how they enter the hull?
Again can't thankyou enough for your answers to mine and everyone elses questions. They have been a ton of help.
I don't know how but hte chains would have to get up to the deck somehow as that's where the paravanes were stored. I've seen a picture of the chains sort of ... taken from CV-10 Yorktown looking down into water that was so clear you could see all the way down to the bottom of the hull! Not an incredibly useful perspective however. Typically those chains didn't enter the hull on the bottom but passed through a hole in a special protrusion.James Noblin wrote:Thankyou for the pictures of the Paravane chain openings Tracy. Do you happen to know if the chains made it up to the deck? Have you ever seen a picture of the chains at the bottom of the bow and how they enter the hull?
Hmmm I just came across a drawin in the AOTS Intrepid book that also has that same hole... I'll have to look into this some more.
- Jose Chaica
I'll have to get back to you when I have a chance to write that much
You have the CV-10 kit and not the CV-13?
- Jose Chaica
Lots of little details. For one, remove the starboard hangar cat. It has to be replaced with a sponson/platform though and it'll take me a while to find some references for you.
For two, Trumpeter errored on Franklin when they had the builder put the Mk 51 directors next to the added quad 40's... in most cases they were added to the catwalks ABOVE the guns and not next to them. I presume this error is the same for Yorktown but I have less photos of her so I'll have to look through those and double check.
Mk 51s for the added starboard quads are missing too... they're up on the island next to the 20mm platforms.
Just a lot of little stuff like that.
- Jose Chaica
That's my intent too, but in book form so that it can't get hacked or taken off linejmchaica wrote:My first intention was to point the omissions and errors from these models , so that anybody who wishes to produce an even greater model, won�t miss a thing...![]()
I do have pictures of Yorktown that are not on Navsource but the agreement I have precludes me from redistributing them; I'll be able to license them for a book but that's it. If I can use them to see what might be the same as Franklin I can help you there though. Franklin and Yorktown went through overhaul at the same yeard only a month or two appart so a lot of the updates are exactly the same.
- Jose Chaica
You see some on individual ships but nothing like a walkaround for all of them.
But there are TONS of details to track and make sure are accurate. Radars alone are giving me fits and I'm about to send a check off to Ron to pay for some scans that will hopefully answer some questions. It's fun, but it's a lot of work!
- Jose Chaica
Decided to take a ride to the local hobby shop at lunch today (always dangerous to my wallet!) and saw they have the new 1/700 Trumpeter Yorktown and Franklin in stock, for $28.79. Being that I have the 350th Trumpeter Yorktown and the 700th Dragon Essex and Randolph, I didn't bite (but I did by wingy thing decals!). I'm curious to see how they stack up against the Dragon kits...
Downunder
1/350 Trumpeter Kits
Can somebody please tell me the differences between the 1/350 Trumpeter Franklin and Yorktown kits, esp. in terms of the aircraft included?
Many thanks,
Ross
Many thanks,
Ross
