HMS Naiad revisited
middle_watch
middle_watch
middle_watch
middle_watch
middle_watch
Victorious
As ARH has quoted, you have been kept at it. Well done, it's looking great.
It will be a few weeks yet before work on the Marlborough can commence. The Dry Dock is without electricity. You won't believe this, but on Boxing Day morning, I discovered that a fox or something had chewed through the cable where it enters the shed. I know I should have encased it in some conduiting, but did it as a quick job.
I am now going to run a new cable which this time will be through a length of conduit actually entering the shed.
My original cable does go through conduit until the last foot, where it goes into the shed, and this is where the fox had had a bite at it.
middle_watch
Cheers guys.
I cannot work in my shed for a different reason, it has turned into a junk room come orniment storage come extended larder come beer storage during the party season. I have to snatch time on the dining table while the rest are nursing hangovers.
Sure it was a fox? Sounds more like rodent work! Just had a major battle with mice in mine, took me a while to realise why the (deleted) alarm kept going off in the early hours.
middle_watch
middle_watch
middle_watch
- kennylibben
- Dave Wooley
Victorious
Good luck with the filling middlewatch, it's all the sanding down afterwards, that is the messy part.
Better not do this indoors, or you may be visiting the divorce court.
And be careful with that heater, or you might grill the Naiad.
middle_watch
Not looking forward to that bit, last time the stuff set so fast I never really had chance to shape it, wonder if I use to much activator? It is a bit difficult to measure.Victorious wrote:Good luck with the filling middlewatch, it's all the sanding down afterwards, that is the messy part.
Better not do this indoors, or you may be visiting the divorce court.![]()
And be careful with that heater, or you might grill the Naiad.![]()
Cheers for the encouragement all.
- ARH
Mix about 3 tablespoon fulls with about enough hardner to cover your thumb, about 1/4 inch high, put it on as thin as it will go, 1/32 inch, lightly sand, put on more , do the same till the hull is covered in a thickness no more than 1/8th of an inch, that should be more than strong enough, ARH
Simple but effective.
middle_watch
