1/72 USS Conyngham DDG-17
- Dave Wooley
Re: 1/72 USS Conyngham DDG-17
I've only been off site a few days and I'm missing out. Your DD-17 is off to a flying start. As ARH would say "I'll also be watching" . Scratch building at its best.
- Unicorn
I think it was his first model, and he over-engineered.ARH wrote:Hi CCain, I will be watching,![]()
The ship photo with the custom made hull looks a little low in the water, seems over ballested, or superstructure a little heavy for the cast hull.![]()
The DDG hull was notoriously low free board at the stern and the design has a lot of top hamper, combine the two and you have every likelihood of sitting low in the water.
The one still under construction is definitely not going to suffer from that problem, it is very light and should sit well when ballasted.
Unicorn
Pictures of model warships available at http://s554.photobucket.com/albums/jj41 ... ?start=all
Task Force 72, home of some of the world's finest 1:72 scale model ships http://www.taskforce72.org
- ARH
- shaitan
hi, there is looking good, why did you cover the hull in foil, never seen that before, would that not tear when you sand the plug.
Wrench
It's a male plug and builder will lay fiberglass over the top. The foil acts as release agent.shaitan wrote:hi, there is looking good, why did you cover the hull in foil, never seen that before, would that not tear when you sand the plug.
- Scale Shipyard / W.L.U.
- Scale Shipyard
Some replies are not showing up for days...it must be my AOL.
W.L. Upshaw
The Scale Shipyard
World's Largest Supplier of Large Scale Warship Hulls and Fittings
http://www.scaleshipyard.com
The Scale Shipyard
- ccain
OK... After looking at more in depth drawings and detailed pics, it has come to my attention that this hull is... gulp... ALL WRONG!
No kidding... All wrong. It's too high overall by what looks like an inch. It's too narrow at the rear and too wide just forward of midships... Not to mention the whole rear portion of the keel. Heck, I even got the point of the bow all wrong. Oh well... Not too bad first time out of the gate.
So I've decided to scrap this one and start on a new one. I chalk this one up as a learning tool and proceed from there. As of right now this hull resides over the rafters of my garage for further study or the trash bin... Either or.
I'll keep you posted.
Chris
Chris
- shaitan
just a quick question, what have you added silver foil to the hull, never seen this done before, whats the reason for this.
Al
Al
- ccain
shaitan wrote:just a quick question, what have you added silver foil to the hull, never seen this done before, whats the reason for this.
Al
It was so the fiberglass would release from the mold.
Well gang, like I said... The old hull is trash and I'm starting over.
In my quest for various building techniques and media, I decided to go with a wooden structure similar again to ARH's Iron Duke but using a different wood.
I figured I'd try using the wood I've gathered to test fit some hulls... I decided to go ahead and build the motor launch and the whale boat. I'm pleased...
- desron48
for some reason i can't get pg.2 on this tread can some one pm me ......joe
Reason: PM sent
Reason: PM sent
- grim reaper
ARH wrote:I would have left the small keel off till you had cast the hull, and then fix it in position, it stops the hull from sticking at that piont.![]()
This is the last post I can read on this topic is something wrong with it?????? Chad
In war there is no substitute for victory.
USMC-2531 1991-1999
USN ABE2 2013-Present
1/96 Missouri 1944
1/96 Pennsylvania 1941
1/96 Yorktown 1944
1/96 Oscar Austin DDG 79 2013
USMC-2531 1991-1999
1/96 Missouri 1944
1/96 Yorktown 1944
- ccain
Here's where I'm at today...
- ccain
I got just a little more done to the structure before I called it quits for the night.
- desron48
looking great chris....so your going with the plank on frame??....if you have any questions you know my front door is all ways open....joe
- ccain
desron48 wrote:looking great chris....so your going with the plank on frame??....if you have any questions you know my front door is all ways open....joe
Thank you Joe!
Here's today's progress:
I got the hull planked and the bow carved and given the initial sanding.
I need to finish sand the hull and fill in the stern.
- desron48
chris......one good trick i learned....before sanding is to put a thin layer of spackel over the entire hull...then coat inside the hull with resin or epoxy the spackel keeps the resin from seeping out side the hull this also locks the planks so they won't shift on you when your sanding.
....joe.....btw hulls looking exelent.....
- Dave Wooley
Hi Chris A superbly crafted plank on frame hull . Question what type of adhesive do you use to bond the planks? I've always used a resin based wood glue called Cascamite now produced in the UK by Humbrol. The blurb says it's stronger that the material that it's bonding!
- trigrodge
hi ccain,
your hull looks fantastic, i've never built a hull from scratch before but want to give it a go when my other projects are done, so trying to gather as much info as possible, am i correct in thinking this is just a plug for a fibreglass hull or will this be the actual hull?
many thanks
leigh
many thanks
leigh
- ccain
Thanks Joe! Let's say I was looking into epoxy... What's the best epoxy to buy that will hold up for this purpose? I mean, I know there are some model rocket guys that are using this stuff:desron48 wrote:chris......one good trick i learned....before sanding is to put a thin layer of spackel over the entire hull...then coat inside the hull with resin or epoxy the spackel keeps the resin from seeping out side the hull this also locks the planks so they won't shift on you when your sanding.....joe.....btw hulls looking exelent.....
What do you think?
Wow Dave, Thank you so much! Well, Ive never tried to attack anything quite like this before. So, prior to construction I did several adhesive tests using every kind of glue I could get at the hardware store. I then took these test panels and abused them severely. No kiddin', I threw these things around the shop, twisted them, pried on them and even whacked them with various blunt objects. The neighbors probably thought I was mad!Dave Wooley wrote:Hi Chris A superbly crafted plank on frame hull . Question what type of adhesive do you use to bond the planks? I've always used a resin based wood glue called Cascamite now produced in the UK by Humbrol. The blurb says it's stronger that the material that it's bonding!
Dave Wooley![]()
So, long story short, it's all held together with super glue. And I figured since I'm going to apply a coating over the entire hull that it should hold up just fine. Although, I have to tell you... I have always been guilty of over engineering things.
Hi Trig...trigrodge wrote:hi ccain,
many thanks
leigh
Nope, not a plug. She's gonna get a coating (to be determined later) and this hull will be used as the actual hull for the build. Good luck with your build!
- ccain
I worked out the hull mounted sonars today...
