1/72 USS Manila Bay (CVE) - 28OCT08
- Dave Wooley
- Jose Chaica
Victorious
- Jose Chaica
- Jose Chaica
- Jose Chaica
- Jose Chaica
Victorious
- Jose Chaica
- Neptune
- Jose Chaica
Victorious
Just go easy with using electric sanding tools on Balsa, it is very soft wood and if not done lightly, will soon be sanded away to sawdust. I tend to shape away large areas with a Stanley knife and finally finish off with sandpaper, Medium grade and finally Fine grade.jmchaica wrote:Yes, it does take a lot of sanding... better done with some electric power sanding tool, otherwise...Neptune wrote:...But I didn't know Balsa is that shapable, I guess it does take a LOT of sanding work to get this done no?![]()
- Jose Chaica
Hey, I found no problem with that... I�m using a B&D "Mouse" sanding tool, and with great results.... If it wasn�t for that, I would have had much more work... But, it�s like you said, you must go easy with balsa wood...Victorious wrote:Just go easy with using electric sanding tools on Balsa, it is very soft wood and if not done lightly, will soon be sanded away to sawdust. I tend to shape away large areas with a Stanley knife and finally finish off with sandpaper, Medium grade and finally Fine grade.jmchaica wrote: Yes, it does take a lot of sanding... better done with some electric power sanding tool, otherwise...![]()
I�m currently working on the propeller shafts and rudder...work is a bit more advanced than what is shown in this picture, as I already added the propeller shafts fins...
- Jose Chaica
Ok...so the propeller shafts are now complete, and being so fragile, I had to apply a coat of fiberglass and resin to strenghten them...
Next comes some final touches (sanding) around the bow area, and then I will apply the resin and fiberglass to the hull...which should take some weeks...
Thanks...
Thanks...
- jep1210
progress???
JM, How's the project? Haven't seen a post in a while and was wondering how it's coming. Not trying to rush you but this is the project I'll be following closely due to my current 1/192nd scale build.
I'm sure I can speak for most/all of us when I say we're looking forward to the next installment.
John
John
- Jose Chaica
- Francisco P. de Nanclares
Not an expert at all, but I would say go with whatever makes you feel better. The end result is going to be astounding, for sure.
Oh, and please, keep us up to date on your second child. Best wishes on this!
a new shipmodel eater on the block!.
Cheers.
Pachi.
Cheers.
Pachi.
I will miss you Werner. Fair winds and following seas.- Jose Chaica
Thanks TommyL.TommyL wrote:Just keeping this post current so it doesn't fall down the listing too far. Some great work with balsa sheeting would be lost due to the auto prune.
TommyL.
I�ve been out of the shipbuilding "industry" for the last 2 months... I intend to pick it up, again, soon.
Once again, thanks...
