Calling all USS Boston CAG-1 fans!
RandyM
more progress...
Post by RandyM »
I managed to build a stand, paint the hull, install the wood maindeck and start on the foc'sl and foredecks.
Note that I had a HORRIBLE time trying to get Vallejo Air to stick to Mr. Surfacer. I primed the (*VERY* clean) resin with Mr. Surfacer, let it dry till it no longer smelled (three days), and painted below the waterline with Vallejo. After a week's drying time I masked for the haze grey and applied that color in ModelMaster. Upon removing the (Tamiya) masking tape, the red VAllejo came off in sheets. I stripped all the paint (and had to scrub to get the Mr. Surfacer off), then tried everything again, thinking I had somehow done something wrong. Exact same results the second time around. After stripping the entire hull for the second time I went back to my tried-and-true formula (Tamiya and ModelMaster). I used Tamiya below the waterline and everything else is Model Master. No real reason for this combination other than I am comfortable mixing the correct vertical/horizontal colors in MM (NB: in this context I use the word "correct" with respect to my tastes - if something doesn't look right to you, I always welcome useful critique), and I happened to have the correct combination of colors in Tamiya for the anti-foul red.
If anyone can tell from my description what I'm doing wrong with Vallejo, PLEASE let me know: I actually like the paint quite a bit, but if it won't stick reliably it is of little use to me.
After everything was nice and dry I made a template of the planked area and transferred it to a piece of "tinted wood" deck from ScaleDecks.com. I cut that out with scissors then carefully sanded its edges to precise shape. Then after summoning the appropriate courage I glued it to the hull using Zap-a-Gap. I am personally impressed with how great it looks.
The second image shows the current state of the foredeck. Prior to painting and with the exception of a few pieces on the stern, I sanded all of the cast-in detail off the hull (the kit's foc'sl was particularly "interesting" and had to go), and sanded down the planked area to approximate the thickness of the wood deck. So, everything you see in the photos - aside from the hull itself and the turret bodies, is scratch-built - except for the exceptional L'Aresnal twin bits. I know the extreme edge of the decking looks "a bit rough" but the good news is that the maindeck railing with hide it.
Still having fun with this kit...
- Randy
el Cid
Re: Calling all CAG-1 USS Boston Fans!
Post by el Cid »
Thanks for the update Randy, she's gonna be a beaut.
Keith
gtbred
Post by gtbred »
very nice looking model. :thumbs_up_1: :thumbs_up_1: wonder it can be bought as a waterline?
RandyM
Post by RandyM »
Absolutely. The hull comes in the standard top/bottom halves: building a waterline version would actually be quite a bit less work :)
gtbred
Post by gtbred »
cool, building a waterline Tonkin Gulf fleet. she will look good next to my Chicago CG-11. :thumbs_up_1:
RandyM
incremental progress
Post by RandyM »
Built up the main tower this evening. I must say that in my experience, YMW's photoetch is very, very nice.
RandyM
Main tower finished (but not painted)
Post by RandyM »
RandyM
some more progress
Post by RandyM »
Spent some more time on Boston this weekend, and figured I'd place all the subassemblies just to see how everything is shaping up. First up is an overall shot of current progress. In this view the main/01 deckhouses are attached to each other but not to the hull, and everything else is just "sitting there."
I came to a bit of a nasty realization... I'd been planning on assembling/painting on a deck-by-deck basis, but due to the general design (ie., multi-deck height of the amidships superstructure, 3" guntubs - which share a seamless deck with the 02 level, etc.) that I would have to at least work on the maindeck / 01-deck assemblies as a unit. So I assembled those decks and took care of remaining seams, then realized that the 03 bridge deck would also have to be assembled to this unit - the splinter shields form a seamless assembly with the deckhouses immediately below. So much for plans.
This next shot shows the bridge area with the main tower in place (just sitting there). Visible are several items which required replacement with scratchbuilt parts: the 03 deck and railings (the kit-supplied parts for which scaled out to around 12-inches thick...), the port-forward 3" gun tub (which was oddly shaped and again way out of scale), and the flag-bag deck and flag bags (once again, waaay too large).
This is the area I mentioned earlier - where the maindeck and 01-deck houses form a seamless vertical wall. The only way I know how to achieve an acceptable finish is to build/finish them as one piece. The forward missile launcher mount had to be replaced (too thick, details too soft). I also replaced the kit-supplied pedestals for the launchers.
View of the foc'sle in current form. The hull in this area was scraped clean - out of scale, wrong shape, etc. - and replaced. The very nice chain comes from L'Arsenal courtesy of Tony Bunch.
This shot shows the amidships works including the mainmast and main tower. The deckhouse supporting the SPS43 radar antenna was replaced with scratchbuilt items (out of scale, mis-shapen, really bad texturing). Once again the photoetch in this kit is very nice. Keep in mind the tower/mast are "just sitting there" and are not yet correctly aligned to the hull.
Closeup of the SPS43 radar and house.
And finally, a closeup of the forward launcher.
That's it for now.
s4usea
Post by s4usea »
Any updates?
Boston is on my short list to do, and I'm following your build with interest.
el Cid
Post by el Cid »
Thanks for posting Randy, your BOSTON is looking very nice.
Keith
RandyM
Post by RandyM »
Thansk for the encouragement, guys... this is a challenging build from the standpoint of a [time invested]:[progress made] ratio. I'm fighting the usual battle: balancing the honey-do list, modeling, documenting the modeling... oh, and work too :) Living in southern california means that I can rarely use the weather as an excuse to keep my butt indoors.
I've made some progress since the last photos - still concentrating mostly on the 01/02 decks, getting them ready for paint/installation. Most of the new work is focused on cleanup, continuing to add PE to make up for all the detail I had to, errr, remove. I realized the stack had to be added to this assembly - again due to seamless vertical surfaces - but I think I have finally arrived at the first "module configuration" to be added to the hull. I'll try to take photos this weekend, but again, most of the work is on detailed cleanup of seams, corners, PE, yada yada, so nothing new from an appearance standpoint. The good news is that I've informed the family I intend to put some hours in on her this weekend.
Randy
RandyM
Milestone progress
Post by RandyM »
I'm up to about 125 hours into this build, and tonight - against my better judgement - I put the first several haze grey color coats on the maindeck assembly. I consider this a milestone because a very large percentage of those hours were spent on this assembly, and frankly I'm getting very tired of looking at it.
Here she is - the hull is just as it has been for several months, but now the main, 01, and 02 deckhouses are grey! Which means I've finished with the main detailing of this area of the model - a task which turned out to be quite tedious. I've been staring at photos so long I feel like I could make my way around Boston unattended.
The 04-deck radar structure is just "sitting there" - as is the maindeck assembly on the hull.
Starboard forward...
This shot shows the reworked rear 5" turret mounts (the kit's mount is a flat surface while the ship in this era had an elevated lip on the after side). Also the (giant) maindeck ventilation intake. And if you look below the stack you'll see a small platform with numerous triangular supports - this was fun (and I got to do one for the other side too!). Everything you see on vertical surfaces is either PE or scratchbuilt.
Another view of the forward section - the splintershield on the bridge deck was also replaced (are you beginning to see a trend here?).
This view shows some of the details added to the underside of the forward missile launcher area (and that GIANT intake duct again...).
Still a loooooong way to go, but I'm excited to be at this stage. It feels like I just poured the foundation for a new house. Tomorrow I hope to spend some time on cleanup and some additional haze grey coats, then move on to the decks...
s4usea
Post by s4usea »
Awesome thanks!
Boston was the first ship I remember going aboard when my father was aboard her, (it was his fist ship after finishing what was then destroyer school in Newport) so I'm looking forward to getting to my kit, but the amount of work you have to do is, while not intimidating, substantial, so I'll have to wait until I have time for it...
Thank you again for posting!
gtbred
Post by gtbred »
Thanks for posting. You made me get back to work on my Chicago CG-11. :thumbs_up_1: :thumbs_up_1:
RandyM
Post by RandyM »
FWIW, I got to work on this project early this AM, cleaning up. I usually take a series of hi-res close-ups and analyze them separately (I have a 14MPxl camera with macro, from which NOTHING can escape), then fix areas identified as needing attention. Then I wash/rinse/repeat, dry, and paint. I usually have to iterate 2-3 times: we'll see how it goes on this model.
The next looming challenge: painting the decks. This ship will certainly test the limits of my patience with masking tape.
RandyM
some more progress
Post by RandyM »
Got the main superstucture masked and painted (phew!), plus the bridge decks built and primed.
The first image below shows the 03-05 deck structures prior to painting, while the second shows:
- main superstructure in place but not attached
- scratchbuilt 3" gun tubs in place but not attached
- 03-05 deck structures primed but not painted (ditto the flagbag deck)
The bridge structures need to be cleaned up and "fitted" - if you notice in the first photo the PE part which forms the "crown" of the 04 deck - this fit of this part is critical to the stackup of the pretty much all the other pieces. I used it as a template when creating the 04 and 05 decks (the kit-supplied parts were hopelessly out of shape/undersized/overscale). The other major fit issue I need to work out are the window frames on the 03 and 04 decks - they are supposed to be angled outward but the kit parts are designed to be vertically mounted as shown. I have a plan for doing this, so we'll see...
The mast/tower are the same as before, just posing for photos (and the mast is angled waaaay too far astern).
RandyM
Post by RandyM »
So much for best-laid plans...
I took the plunge and hacked up the bridge windows so they could be canted outward as on the prototype. I obviously hadn't thought this thru, as making this change resulted in the PE crown piece now being undersized. I made a new one out of 0.005" sheet plastic - seven total pieces.
Here's the modified bridge in process...
And here it is posing with its first color coat. The change is subtle but effective, IMHO.
RandyM
Weekend progress
Post by RandyM »
I spent waaaaaay too much time at the bench this weekend, but results are starting to show. The 3" gun tubs are installed, as are the bridge decks up to 05. The two directors are posing, as is the main tower. As you can see, I've begun installing railing and deck details on the bridge superstructure. Staring at these photos I notice some haze grey overspray up between the three 5" mounts - oh well, something else to deal with.
gtbred
Post by gtbred »
RandyM
more progress
Post by RandyM »
I finished the main and secondary gun armament (8" and 5" turrets), plus some directors and some additional inner railing/ladders. I'm also comparing the 3"/50 gun mounts from both Yankee Modelworks (kit-supplied - on the after mount) and Veteran (on the fore mount). No detail paint yet... just gallons and gallons of haze grey.
One (of many) thing I've not been able to figure out yet - the forward 5" mount on Boston had what I believe are shell ejection chutes on the back of the turret (you can just see one of them in the last image above, and clearly see them on the prototype in the image below), while the other four mounts did not. Why?
Return to “Cruisers”
