1/32 Scale - 40mm Twin Bofors Mount
Re: 1/32 Scale - 40mm Twin Bofors Mount
Post by Rick E Davis »
I looked at a number of late war photos on destroyers (I have a bunch of those) and the most common Mk 1 Mod (?) mount installed has the cover. However, a few show the cover off (sometimes with a canvas cover over the area), but since it is a yard shot, they may not have installed the cover yet. Below are two examples ... plus the view on O'BANNON shows the cover hinged open a possible option for you as well. The view on DYSON was right after the mount was installed and it appears to be freshly painted in the Dazzle camo color for that location (note the masking over the springs), which may explain why the cover is off. I have close-up photos of a twin 40-mm I found in Athens Ohio at a VFW and it has the cover as well. There were three different Power Drives used on Mk 1 40-mm twin mounts; Ford, GE, and York. I have yet to figure out which mounts have which drives.
First image O'BANNON (DD-450) on 6 January 1944 at Mare Island
Second image DYSON (DD-572) on 27 September 1944 at Mare Island
Third image HEERMANN (DD-532) on 11 January 1945 at Mare Island
oneslim
Post by oneslim »
Thanks Rick,
Those are some great photos of twin mounts.
I have the Floating Drydock Ordnance Pamphlet #6, and the 1/4" drawings. Both sets of drawings show no cover on the front of the mount. The 1/4" drawings are from the York Lock and Safe Co. Also the pamphlet IDs the componets mounted there as the Firing motor, Firing solenoid, Firing stop cam housing, and the Firing switch.
Maybe, the cover is a function of the mount maker and not time line of mods.
Bob W
Bob,
I don't think the manufacturer had much to do with whether there was a cover or not. All 40-mm mounts were built to the same specifications. I suspect that the cover was an OrdAlt to protect components on the front of the mount from damage/salt water. The covers over the loading breeches for the 40-mm guns did start out as an extra item not part of the production line for 40-mm mounts. I have read several Departure Reports for early FLETCHERS where the yard was tasked to make these for the 40-mm mounts. There were canvas covers for the entire mount, but the metal covers were better and lasted longer. There were different Mods of the mounts, and some may not have accepted the covers because of a different layout of components. Right now I don't know the answer. For your purpose, building a model of a specific mount on MONTEREY in 1951 ... finding a photo would be the best answer.
carr
Post by carr »
Rick E Davis wrote:I don't think the manufacturer had much to do with whether there was a cover or not. All 40-mm mounts were built to the same specifications.
Just to put that statement in context, all Gato class submarines were built to the same specifications and yet the boats were quite visually different from the different yards. Use of common specs did not preclude yard specific customization!
oneslim
Post by oneslim »
Rick,
Thanks for that info. Sounds like a book is needed on USN 40mm Bofors of WWII.
One thing I noticed in the photos You posted is that the cover is half again deeper ( front to back ) than on my model. So I hve removed it to work on it.
Thanks for those great photos.
Bob W
Carr,
I'm not talking about ship builders where there were variations in largely construction "style" of bulwarks (they still need to build to standard interface requirements and even build things like "tubs" to accept weapon's working circles). Things like weapons, fire control directors, etc that were "Government Furnished Equipment" have to meet specific requirements. The Government gave these items to the ship builders to install or the USN installed it themselves and you couldn't have such equipment with variations in installation interfaces or even different working circles. Equipment from different suppliers had to be interchangable for repair as much as possible. The power-drives were a major headache initially for that reason. Some FLETCHERS were equipped with different drives on the same ship ... a major headache in stocking spares and repair. Many of these FLETCHERS during subsequent overhauls had 40-mm mounts removed and swapped with other mounts so that they all had the same drives. It was just like building cars, the mount builder had parts made by various suppliers that had to be interchangable with parts from another supplier.
carr
Post by carr »
The Navy Department Bureau of Ordnance, "Gun Mount and Turret Catalog", 1945, on hnsa.org shows the 40mm Mk1 (all mods) and does not show a cover.
Friedman's "US Naval Weapons" shows the 40mm Mk1 without a cover.
I reviewed the photos in Reilly's "United States Navy Destroyers of World War II" and the mounts seem to be about half covered and half not. The covered mounts appear more prevalent in the later dated photos.
From a cursory check, there appear to be no official drawings that show the covered version. Of course, what appears in generalized drawings may vary from actual construction drawings. On the other hand, it may be that the cover was either a particular manfacturer's variation (everything that was made by multiple manf's had minor variations as far as I can tell - subs from different yards didn't even have the same number of anchors!) or a post-manufacturing modification applied during refits.
Hey, can we beat an insignificant item to death, or what? :big_grin:
Bob (C),
I have about 2500 images of FLETCHERS (WWII and the 1950s) and 1200 images of BENSON-GLEAVES I have scanned at NARA/NHHC plus images I have gathered from other individuals in trades. Since Bob was looking for a 1950 era 40-mm twin mount, I looked at images from mid-1943 to the end of the war figuring if there was a change made it would show. I have gone through enough Yard Reports and see normally pages of "OrdAlts" listed for all kinds of modification updates to 5-in, 40-mm, and 20-mm mounts along with other ordnance equipment on each ship. Sometimes what each OrdAlt (or BuShips ShipAlt) are described, but as the war went on and paperwork increased the trend was to list an OrdAlt or ShipAlt by number and indicate if the work was done and on how many mounts. Most of the destroyers (something like better than 80%) in 1943-45 have covers on the front of the mount in both Mare Island and New York Navy Yard onboard photos.
According to the BuOrd History in WWII, York Safe and Lock Company was the first Prime Contractor for USN 40-mm mounts. Then Chrysler and Blaw-Knox were brought in as secondary mount assembly contractors, York S&L Co. was still in charge of configuration control (drawings and modifications). There were hundreds of parts suppliers for these assembly contractors. In July 1943 York turned over Configuration Control to the USN Gun Factory. The differences in mods for the Mk 1 and 2 mounts was due to which drives were used. Beyond a discussion on the failure of the Ford Power-drive and new manufacturers of power-drives, the BuOrd History doesn't provide insights into other modifications made, other than to state that several were made to save weight and ease production.
I really don't know when or how many mounts had the cover or if it is related to a specific mod. But, I have to believe that with Configuration Control assigned to one company or the Naval Gun Factory, it was a planned improvement used on all manufactured mounts. Earlier mounts were rebuilt (most common to change out the Ford Power-drive) and reissued, maybe without the cover because it couldn't be installed on the old configuration or to save time/cost.
Comparing the differences in ship construction within a given class of ships to differences in ordnance is apples and oranges. As I said, ordnance being provided by several contractors to multiple parties to be installed and repaired in the field with a common parts supply system couldn't be allowed to make changes to the configuration of the mount on their own. Shipbuilders were given leeway in cutting metal and construction as long as the overall specifications were achieved (six torpedo tubes forward, length, width, propulsion plants, compartmentation, etc.). Variations were authorized for all kinds of "small" items ... I can point to several different configurations on FLETCHERS ... unique to a given builder. Also, many times changes were made during the course of production construction of large classes that only affected a few ships or many.
A close-up images of a twin 40-mm mount (Mk 1) on display outside a VFW in Athens Ohio that I took.
oneslim
Post by oneslim »
Rick,
Once again thanks for those great photos, Lots of detail there of the cover.
Let me clear up a minor point. My Dad did serve on Monterey in 50 &51, From his collection of photos the 40mm were still mounted. Some time later in 53 Navsource photos show the mounts are gone.
The time frame of my model is mid WWII. The Vet I'm building it for is a plank owner who served as a gunner's mate onboard Monterey for the duration. The only photo of that general time period that I have is from Octber of 45. This is from the book noted in one of my posts. It's a poor shot at best, dark and kind of grainy. It's a shot of the NY shore and mabe the ship Truman was aboard for the review.
Thanks for all Your help,
Bob W
oneslim
Post by oneslim »
OK, back to update,
Have finished the mount except for the cooling hoses. Spent case discharge chutes, railing, and the deepened front cover. At the rear made up barrel cleaning rods. The short pipe with cap and chain is for the brush and swab. Started on the pointer and trainer figures, had to break their legs.
Bob W
carr
Post by carr »
I just marvel at this project. Outstanding! :thumbs_up_1:
I think a company could make a profit selling kits of a whole line of weapons like this (20mm, 1.1", the various 40mm's, 5" guns, etc.), if the price were reasonable. Just a thought.
carr
Post by carr »
oneslim wrote:... had to break their legs.
Yeah, discipline was tougher in the old Navy!
Post by Guest »
Hey Bob,
I just couldn't continue to be a silent lurker any longer. You have done an incredible job with this kit. This is what I envisioned when my father and I decided to create this kit, a model with all of the wiring and tubing in place! I took us three years of research and planning to get her done. I did my best to represent the Bofors as accurately as possible with the info available. This weapons platform Is truly an electro-mechanical monster!
My interest in the Bofors started over ten years ago when a good friend of my fathers, a retired General, had access to the Phila. Navy Yard, any time we needed. We went there to view and take photos of a late model Bofors that was salvaged from one of the many ships that passed through that yard. It was on display, out in the open with about 20 coats of paint on it. It was love at first sight!
Bob, you have done justice to all of the work in making the master pattern. :cool_1: 'Well done' somehow doesn't cover it. Looking forward to seeing the figures completed!
Scott
oneslim
Post by oneslim »
carr,
Thanks for Your thoughts, I too would love to see a 20mm with the colummn that cranks up and down inside the pedestal.
Scott,
Thank You for the kind words, I tried to do Your kit justice. I'm very pleased with the fine detail and the scale fidelity.
Bob W
oneslim
Post by oneslim »
Started to work up the gun tub for mount #9.
Bob W
Bob,
OK I have some new images. I was at NARA this last week and took time to pull photos of MONTEREY for another guy and to answer this question ... if possible. I could not find any good "overhead" shots that were sharp enough to show details. I didn't have time to hunt through all class folders to see if there were any "Mare Island" type yard photos available.
Here are four images of the aft most portside mount taken at different times:
1) 5 June 1943, while fitting out. I thought that this was interesting, obviously this was a temporary arrangement for lifting something. Most of the mounts were covered, but one of the other mounts was uncovered and the front cover wasn't installed.
2) 24 June 1943, while on shakedown. Looks better with the completed bulwark. By the way, it appears that they did have the ready use clip storage on the bulwark inner walls. I couldn't see if any mounts had front covers installed yet.
3) 6 September 1944, after being painted in dazzle camo. A little more to the stern and shows more details under the "tub". All the mounts were covered in canvas or are only visible from a low angle in this sequence of photos, but by this time it appears the front covers were installed on the twin 40-mm mounts (I got a small view of the cover on the aft starboard mount).
4) 23 March 1945, after overhaul at PSNY. A close-up cropped view from a grainy aerial shot, but the front cover can be seen. AS well as the radar antenna for a Mk 63 GFCS.
carr
Post by carr »
Rick,
I might be wrong but wasn't he looking for the starboard side aft-most mount? Or, were the mounts mirror images port/starboard?
Duh ...
I should never do this while recovering from 40 hours at NARA in 3.5 days and getting home at 2330 the night before. I just had it in my mind it was a port mount.
Anyway, here are the best views I have of the two STARBOARD side aft mounts. I have nothing overhead that shows any detail of this mount. The March 1945 photos do show the antenna installed however. The port and starboard mount installations are sort of the same, except that the portside was out further.
Image 1) 5 June 1943, I like this ... they are aligning the Mk 51 director and 40-mm mount to fire back OVER the deck? I never knew that they considered that an option. Plus you can see the ties for the canvas cover over the clip storage on the inside of the tub.
Image 2) 6 September 1944, looking at the starboard mount from astern.
Image 3) 23 March 1945, these two mounts are forward on the portside ... they show the front covers well.
oneslim
Post by oneslim »
Rick,
WOW! WOW! WOW!
Those are fantastic shots! The one from June 5 1943 is the best. I can see so many details.
1. The gauge for the elevation follower is square, not round as I made it, too late now.
2. The vertical ladder is one and not grab irons as on the drawing, with perforated treads.
3. Pipe rails on the catwalk, not chains.
4. The catwalk is perforated with two different size holes shown by the shadows.
5. The crew shelter, the openning to the right has a lip as dose the foam generating station, which is the openning to the left.
6. The angle iron brackets for the life rafts.
7. It looks like the canvas covers are lashed to eyes.
The Sept. 6 1944 shot shows more detail.
1. The beams that support the tub are very different.
2. The room or space behind the tub is not down to the bottom of the tub.
Thanks so much Rick, these are a great help. I'm sure as I study these more detail will be found.
Bob W
oneslim
Post by oneslim »
Update,
Been collecting materials and working out the drawings for the # 9 mount.
The first shot is the tub floor and the final mask for the anti slip strips.
Next is a shot of painting the strips, using Alclad II gunmetal over the 20B.
The last shots are the finished floor.
Bob W
