Meanwhile, I started the seascape, a first for me.
By far the best seascapes I have seen in the flesh are by Werner Dekeersmaeker. He uses Jim Baumann's watercolour paper technique, but glues it over shaped styrofoam for more dynamic seas, and spends a lot of care and time in painting and finishing.
I need a bit more choppy sea than Werner usually uses, and in a smaller scale (he usually builds 1/350th), so I needed much smaller waves which are hard to form in styrofoam. So instead, I sculpted a basic wave-pattern in Magic Sculp, on top of a 3mm sheet of plastic. I impressed the waves with a small teaspoon and smoothed it a bit with some water and my fingers.
In de hole for Lex, you can see the layers: styrofoam (I like some height to my bases, and it also keep everything on top stiff and straith), plastic sheet and Magic Sculp:
I like my groundworks to extend completely to the edge of the base, so I glued plastic sheet to the sides of the styrofoam before gluing the watercolour paper, and cut this even with the Magic Sculp waves at the top. Any gaps were filled with more Magic Sculp.
Then I glued the watercolour paper on top of this (after soaking in water for 15 min), with a lot of superglue, pressing the paper down into every wave. After drying, I "hardened" the paper with a coat of handbrushed varnish (to protect the texture from handling damage), and cut the sides and holes for the ships.
Then I filled the gaps between paper and plastic at the sides, sanded, and gave the sides a primer coat with black paint (you can see slight overspray on the waves).
It takes a bit of extra work, but the result are neatly finished sides of the base, with the water texture continuing right up to the edge.
With some of the paper I used:
I will have to place ships, boats, planes and figures (and do the painting of the sea) in different stages for me to be able to reach everyting but not damage anything, but we're slowly getting there!
Cheers!
Marijn
