Those baskets look great! They must be time-consuming indeed, but the results certainly justify it.
Marijn
Thanks - I don't mind at all. Keith Bender had already pointed that out to me. I did follow the instructions - and had a b*tch of a time getting them on, too. I may just leave them instead of taking a chance on breaking anything!Aur wrote:One comment, Martin, if you don't mind;
I think the screws are not on their correct positions. The port ones should be turning counter-clockwise, starboard the opposite. Maybe the instruction was wrong?
Ha!marijn van gils wrote:And you know, a finished model is always more accurate than an unfinished model�
Thanks. I briefly had delusions of beefing up the air group with aftermarket aircraft, but as that would have added another year to an already 2 year process, I opted just to go with what's in the box.Devin wrote:Nicely done!
Are you using only the kit's aircraft, or are you adding more?
