Calling all Oliver Hazard Perry-class FFG fans
Willie
Re: Calling all FFG Fans!
Post by Willie »
Tony Bunch wrote:The ship was not moving as best I could tell, but was not anchored either. The SPS-49 was in use and there were crewmen moving about the main deck
Hi Tony and all,
Something I forgot in the previous message : the signal " ---o--<>--o--- " in the halyard means that the ship is stopped repairing an underwater cable or picking up a buoy.
Very best regards again,
Willie.
Neptune
Post by Neptune »
That signal is the general signal for "restricted in its ability to manoeuvre". Might mean pretty much anything ranging from what you mentioned to doing helicopter operations or towing its sonar array, difficult to tell which one is the case here.
The merchant shipyard
brad
Post by brad »
G'day Willie,
Once again - a true craftsman - I would love to sit and watch you work one day.
As with the Seahawk, Veteran Models also do inflatables - although it's a bit late now....and u really have done a superb job of it.
cheers,
bj
Happy to help with research & assistance regarding medals to Australians.
Willie
Post by Willie »
brad wrote:Once again - a true craftsman - I would love to sit and watch you work one day
Any time you want, my friend. You would be disappointed at seeing how easy to do these things are, but beer is already in the fridge...
Nice going in Down Under, and very best regards from the North Atlantic,
Willie.
reigels
Post by reigels »
Willie wrote:I hope you like it, and very best regards from Spain,
Willie.
Very nice work. What is the gray material you're using for the loops and 1/2 circles, etc?
-- Scott
Willie
Post by Willie »
reigels wrote:Very nice work. What is the gray material you're using for the loops and 1/2 circles, etc?
Hi there Reigels and all,
Easiest thing ever : It is only streched sprue. You simply have to wind it around something round and re-heat the plastic very carefully. Then cut in slices as many times as necessary, and adapt to the required lenght.
There are a lot of things that can be done with sprue :
http://www.u-modelismo.com/manuales/ace ... struccion/
It is in Spanish, but I think the pics are clear enough. Click on the pics to open them.
Very best regards,
Willie.
GTDEATH13
Post by GTDEATH13 »
Willie the rhib is superb... :thumbs_up_1: :thumbs_up_1: I have a question for you: If you examine the pictures you posted closely you will notice that the bollard for the rope at the bow of the boat has the horizontal bar passing throug the vertical one, and not in the front of it as yyou have placed it. Why did you do that?
Keep the photos coming!!! :wave_1:
NIKOS (NICK)
Willie
Post by Willie »
Hi GTDEATH and all,
GTDEATH13 wrote: If you examine the pictures you posted closely you will notice that the bollard for the rope at the bow of the boat has the horizontal bar passing throug the vertical one, and not in the front of it as yyou have placed it. Why did you do it ?
In simple words, because I am a bit of a stupid: I didn�t pay attention to this detail when gluing the parts, and I have just realized the mistake after reading your message... :bash_2:
Anyhow, the whole RHIB is so tiny that this will go unnoticed when the construction is finished :
Very best regards from Spain,
Willie.[/size]
GTDEATH13
Post by GTDEATH13 »
Now that I see it.... Woooooow... Soooooooooooooooooooo small... Unbelievable... It is 1/300 if I remember correctly? :wave_1:
NIKOS (NICK)
Willie
Post by Willie »
GTDEATH13 wrote:It is 1/300 if I remember correctly? :wave_1:
1/300 sharp !!!!!
Brgds,
Willie.
Willie
Post by Willie »
Hi all,
I have already finished the markings on the flight deck.
After making the exterior lines --as shown in a previous post-- the border of the observation post and the midships line, I have drawn the central circle, a problem which I solved after some hesitation using two coins, a 2 Euros coin for the outer border and a 20 cts. one for the inner border.
The template was like this, with the little central marking drawn with no template :
After this I made the "H" for the HIFR, using Tamiya masking tape :
As for the rest, I made a template ad hoc, that was somehow long to make, but not difficult at all :
So all the markings together are now like this, with the little circles of the HIFR line made purely by hand, because I was not able to make a template this little :
It needs some retouching in a couple of points, but I hope you like it anyhow.
Willie.[/size]
Willie
Post by Willie »
Hi all,
After finishing the flight deck paintjob, the problem was to erase the remmants of glue from the sticker, so I thought that for the red lines template in the forecastle I could try something cleaner, which is to discard the sticker and use only the paper support, fixing on it stripes of Tamiya tape, which is simply ideal for this job, because it leaves no traces of glue at all.
The template was like this :
Once I had given the first hand in red --and it was perfect-- I had to ruin the job taking for the second hand the wrong red can and applying satin instead of matt red... :doh_1: The border lines of the satin red are much thicker when retiring the template, and they break more than when using matt. But it could have been worse...
The forecastle is now like this :
These lines are again a bit oversized, but this is the only way I have found to keep the visual effect of the tape breaking withing reasonable limits.
I hope you like it, and best regards from Spain,
Willie.[/size]
Unicorn
Post by Unicorn »
desron48 wrote:anyone know if there's a fiberglass perry class hull in 1/72 scale???....joe
As previously mentioned APS Models do a 1:72 Australian long-hull FFG hull. It is available as a hull only or as part of a pretty comprehensive kit.
Here are some shots of completed RAN FFGs using that kit as a basis.
Adelaide
Newcastle
Darwin
Two close up shots of Melbourne
Regards
Unicorn
Pictures of model warships available at http://s554.photobucket.com/albums/jj41 ... ?start=all
Task Force 72, home of some of the world's finest 1:72 scale model ships http://www.taskforce72.org
Willie
Post by Willie »
Hi there Unicorn,
Thanks a lot for posting these pics. This is one of the finest models I have ever seen !!!!!! It is so good that is almost a sin to risk her in the pond. It is not awesome, it is simply breathtaking...
Anymore pics of this model, please ?
Thanks a million again, and very best regards,
Willie.
Willie
Post by Willie »
Hi all again,
After painting the flight deck lines, I had to make and set in place the towing tracks. They are made with 1mm. Evergreen stripes and stretched sprue. Once painted, I reduced the profiles with a blade, and set the in place with CA. They were like this :
After painting again in grey, I had to retouch all the white lines and draw the yellow ones:
And this is the effect with the helo on deck ::
Now I can start with the main structure.
Willie.[/size]
Tony Bunch
Post by Tony Bunch »
Hi Guys,
Willie,
Do we like it?
That's a big............affirmative !!!
Tony
Unicorn
Post by Unicorn »
Willie wrote:Hi there Unicorn,
Willie.
Check out my Photobucket account in my sig block for more. There are also a lot more shots of various model warships at the Task Force 72 website under the Events and Reports tab.
Unicorn
carr
Post by carr »
Admhawk
Post by Admhawk »
Yes, they go down to the keel on both sides. The idea is to supply a bubble curtain for the whole underwater hull.
Now stop getting distracted and get back to the Kirov! :big_grin:
Darren (Admiral Hawk)
carr
Post by carr »
