1/350 HMS Hood (scratchbuild)
EJFoeth
Re: 1/350 HMS Hood (scratchbuild)
I find a wash look a bit too rough; I really want to blend in more color preferably by handpainting. Exert more control over the effect. I did a number of deck parts with oils washes but didn't really like them.
Rough in what sense, if I may ask?
EJFoeth
It depends a bit on the type of wash. Some people add a lot of oils and then swipe off the excess paint. This changes the base color too much. A lighter wash/filter is something more subtle and I think I'll have to add one to add contrast to the lines in the deck. The less pronounced the wash is, the more the base needs color variation to be visually interesting. I want to be able to get these colors in locally and continue painting in color differences. I think that would also be easier for local touch-ups and corrections. I hope!
EJFoeth
My model was built using Evergreen V-grooved styrene. At the time I didn't know there was a finer material called Car Siding which I prefer to having used. Too late now. Also, many preprinted and lasercut decks than can be bought and added to most models. Some of these look really great but even with the finest wood grain they still look a bit odd to me, but they add a lot of detail I might have added to my model. What do the decks of HMS Hood look like in terms of structure?
Here you can see the deck in progress of HMS Hood taken from Ian Jonhston's Clydebank Cruisers (I cannot recommend this book enough). This and other images show how they started with a line of two planks from start to end and the rest are added later. At the far left of the image you see the planks are simply cut off at an angle.
Note how random the planks end; it's not really well organized.
Now, on many of the premade decks have a lot of detail in the deck around all the pieces of equipment, but here there is no structure whatsoever in the deck other than the planks. So no planks / frames around skylights, hatch comings, vents and so forth.
Forget about the ship in the background, focus on the deck in front of the ship also present at the Clyde. Note how the planks end on the edge of the vessel with no nibbling sometimes seen in after market decks for model warships. It is actually fairly simply in terms of planing detail. It appears my very simple approach for the decks is actually quite good for HMS Hood.
On to the painting. I start by airbrushing the deck in Humbrol 72 (Khaki drill mat) and letting it dry for 24 hours. I then first add a new layer of H72 by brush and paint in a very large scale accents adding white and a tiny bit of van Dyk brown. Then it's time for my smallest brush, painting in the planks semi regularly with a larger brush standing by for corrections. The deck is painted with H72 and H110 (natural wood) with white and van Dyk brown mixed in. Although the real deck is irregular, I wanted to have at least some structure visible and painted an odd/even spacing, but not so much you would notice. This is before adding the wash that pulls all colors closer together, so one goal of the exercise was to learn how far the colors need to be apart, before washing, to look good after washing. I made several test pieces, also throwing in some H83 (too yellow) and H84 (H72 relabeled; at least, they are so close in tone I wonder why they bothered to issue it), but I like this one best.
After the paint as dried (again 24 hours) I added a few van Dyk washes; I wanted some brown to interact with the planking detail and not black. I also wanted to avoid an overly hard effect of black caulking lines. I think I need to add a coating first as the paint was damaged in one location (beneath the turret). I really like the effect I have now but I'm a bit conflicted as I do not want to see individual planks but I also want color variation! And I want to see individual planks too and for them to be all the same color!
I have to be a bit more careful with the H110 as the differences are still too large but otherwise I think the effect is starting to look really good. I also have to be careful with all the small hairs and dust collecting in the paint; some of it probably accumulate during drying (add cap when drying) and lot of dust flows with wash...
Meanwhile, all photo-etched deck lockers have been soldered and painted as a small how-to-highlight-tiny-details painting exercise. A few minor corrections are required in a few shadow lines. I really like how well my solution for the design of these lockers worked out with the small legs running to the far edge of the locker extending below the fold line of the part done like so
The part right was supposed to act as a backbone but was not required; it was much easier to solder the part without it. The lid was held in place with tape before soldering which was a nice new challenge in terms of positioning.
- JIM BAUMANN
Your paintwork is fastidious and the quality shows...!
very good
JB
very good
JB
EJFoeth
Thanks Jim! People like you here show me what can be done with paint and a brush so practice, practice, practice!
Dino Carancini
...very good EJ, worth the waiting time
marijn van gils
The deck looks excellent to my eye! Very good colors!
Only be careful that the wash dries up evenly. Now the dark lines in the seams look a bit interrupted if you look very closely.
Marijn
Marijn
EJFoeth
Thanks! I experimented quite a bit with combinations of colors and it seems to start working now. I noticed the intermittency of the deck lines as well so more washing is required. Next time I'll start with one wash to modulate the colors a bit and then seal it with some coating before accentuating the lines... perhaps... it could also be the H72 didn't adhere too well and I need to prime first to avoid damage. It's a dusty color that doesn't become as scratch resistant as other colors (perhaps I thinned down too much). What I not intend to do is any drybrushing; I think it will ruin the effect. I do have to practice more spots, wear & tear of the deck and so forth, before painting the ship itself, but I am overcoming my horror vacui.
What's really annoying is that I am automatically spotting color differences in wood on buildings, floors, furniture.. in real life or on TV...
- Model Monkey
Absolutely brilliant work! The effect is quite realistic, very life-like. And I LOVE the deck lockers.
Ah, the result of art affecting the mind of the artist! You have crossed over to the Dark Side.EJFoeth wrote:What's really annoying is that I am automatically spotting color differences in wood on buildings, floors, furniture.. in real life or on TV...
- Admhawk
EJ, I've always preferred the technique taught to me by Loren Perry,
Basically, you spray a base coat of tan and then using Floquil Natural Pine stain and Driftwood stain, brush light, short strokes of each colour, along with thinned tan until you are happy. If I recall correctly, I did a series of the natural pine, then the driftwood, then the natural pine again, then did some thinned tan and finally, I gave it all a light dusting of thinned tan to even it all out. The trick is to NOT get too much paint on with each stroke. A quick dip in paint with a fine brush, quick dab off on a tissue, do 4-5 quick light strokes, repeat. Random strokes, location and length, work best. This technique also works really well on raised plank decks found on older kits!
I know the Floquil stains aren't available anymore, but the Driftwood is a very very light grey and the Natural Pine is an olive drab color. Both stains can be made by thinning any regular paint to a wash consistency. You've come up with a pretty good technique and I thought maybe you might want to try other colours than white or brown. You'd be surprised at the depth you get.
Here are a couple of photos of my Titanic, sorry for the poor quality, but you get the idea.
Darren
Darren
Darren (Admiral Hawk)
EJFoeth
Nice work on that Titanic! I'm more or less trying the same technique with Humbrol paints. At least it is very easy to get very thin strokes and I have yet to paint out any detail with it. What I will not do is adding any overspray by airbrush. Sounds to risky actually...
- LordAnkarin
Wonderful build. Will have to use this as a reference for when I get to Hood. In the next decade at the rate I build
How fine is that Car Siding? I have some v groove I was going to use to replace the deck on the 1/350 Arizona. Was looking on the evergreen site, and it indicated the vgroove had thinner spacing.EJFoeth wrote:My model was built using Evergreen V-grooved styrene. At the time I didn't know there was a finer material called Car Siding which I prefer to having used. Too late now. Also, many preprinted and lasercut decks than can be bought and added to most models. Some of these look really great but even with the finest wood grain they still look a bit odd to me, but they add a lot of detail I might have added to my model. What do the decks of HMS Hood look like in terms of structure
Jeremiah Hoskins
Middle School Social Studies and ELA teacher
Current build
1/350 Bismarck
Current build
1/350 Bismarck
EJFoeth
I suggest Evergreen 2020 with a 0.20"/0.5 mm spacing. The V-groove goes down to 0.025"/0.64mm. Makes a difference at this small scale. I wish I'd known that there was a finer deck before I started but changing the decks now would be model suicide.
- Aop Aur
Amazing job EJ!
Don't know will I ever get such skill...
On the way:
And our artworks!
And our artworks!
EJFoeth
It's quite easy: just don't give up
I remember the "car siding" from eons ago when I built a bunch of HO N3 rolling stock. A great job the deck washes, actually looks better than the later cut ones. A problem with any single solid sheet is the wood texture and grain carry laterally from board to board. Hand planking in 1:35 might be interesting, bad enough in 1:192.
Great work! Tom
Great work! Tom
EJFoeth
HMS Hood just docked after a 18 month tour of the liquor cabinet for her deck refit
- Model Monkey
Amazing.
- Jabberwock
Just read through this post - I am in awe!
However, I wish to point out that the statement you make about the picture of the deck construction where you say -
I copy the picture below, look how the ends of the timber lines up.
You can see how the coloured arrows denoting the ends line-up.
Hope this helps but is probably too late now!
Cheers, Jabb
is I believe, incorrect.Note how random the planks end; it's not really well organized.
Cheers, Jabb
HMS Hood, the big one!
