Calling all Akagi (赤城) and Kaga (加賀) fans
GMG4RWF
Re: Calling all IJN Akagi and Kaga fans
Post by GMG4RWF »
Matsuo Akira wrote:Fujimi has just announced to issue their 1/700 triple deck version Kaga on Wonder Festival 2014.
https://twitter.com/minielian/status/43 ... to/1/large
cool - wonder how much (also pick will be a help on my KB)
Haijun watcher
Post by Haijun watcher »
Matsuo,
Do you know if those carrier section cutaways behind the Kaga in that picture were from a single kit or were they scratchbuilt seperately?
Can't wait for the tri-deck Kaga!
That's a mirror/glass, so there's only one "cutaway". It's also not a cutaway, but a "chibimaru", or egg, Akagi. It goes with Fujimi's chibimaru series of tanks, planes, and ships: http://www.1999.co.jp/search_e.asp?Typ1 ... =chibimaru
Post by Guest »
Hello...new here...first post. No stranger to modeling but this is my first look into doing ships.
This may be a really stupid question, but has there been any word of someone doing a less expensive 1:350 Akagi than the Hasegawa? Seems strange you can get almost any US carrier from the era for a little over $100 but you cant touch a Japanese one at this scale for less than $300+.
Guest wrote:has there been any word of someone doing a less expensive 1:350 Akagi than the Hasegawa?
Not that I've heard of and, frankly, not likely.
BTW - as a "guest" your posts have to be approved by a moderator before showing. If you register, posts show up immediately when you log in.
If you're not beholden to scale, then you could probably get a 1/450 Hasegawa version at a good price. Not as new but, affordable.
Sunsanvil
Post by Sunsanvil »
I thought I was logged in at the time...clearly not. :)
Haijun watcher
1935-38 Kaga, after first reconstruction
Okay, upon going through older posts such as this thread about the Fujimi 1/700 Kaga, I take it there is no kit out there that models Kaga after her first major reconstruction between 1934 to 1935?
This was when she got her first island configuration installed and was changed from her original 3-deck configuration to a single, full-length flight deck at top.
I am interested in this Kaga because finishing her refit by 1935 allowed her to participate in the 1937 "Panay incident" and other attacks on the Chinese mainland at about this time.
It seems to me from reading older posts that the Fujimi Kaga is made from 1940 plans, while the Hasegawa Kaga is only meant for 1941-42. If someone can point out something I've missed, please let me know.
Furthermore, it says in the wiki article on Kaga that she had the ff. changes made starting in 1938 during her 2nd reconstruction, that would prevent me from using a later era Kaga to model a 1937-38 one.
Kaga entered the shipyard on 15 December 1938, where her arrester gear was replaced by a Type 3 system and her bridge was modernized. The flight deck and hangar areas were enlarged, increasing the carrier's aircraft capacity.
The ship was completely overhauled from 15 November 1939 to 15 November 1940 before returning to active service. In the meantime, a new generation of aircraft had entered service and Kaga embarked 12 Mitsubishi A5M fighters, 24 Aichi D1A dive bombers and 36 Yokosuka B4Y torpedo bombers. Another 18 aircraft were carried in crates as spares.[22][42][Note 7]
This is how that 1935-38 Kaga looks like:
On first look, it doesn't look that different from the later Kaga, but the wiki excerpt above says otherwise.
The idea came to me of just getting a Fujimi or Hasegawa Kaga and sticking 1/700 scale Type 90 and Type 96 fighters biplanes on it, but it just won't be accurate...
Last edited by Haijun watcher on Sun Mar 02, 2014 9:23 pm, edited 1 time in total.
I do not have either of the references that the wiki article cites for details on the recontruction. However, I believe the one external feature added to Kaga's bridge is an narrow, sponson-like extension forward of the AA command deck level (top). It can be seen at the upper left in the first photo, covered by fragmentation hammocks. Any other modernization was probably due to equipmnet changes inside. I don't know if this appears on the Fujimi kit but, the Hasegawa kit does not have it.
Not sure what, if any, aspects of her flight deck were changed.
Some inspirational shots for your China era build
Peter H
Help with 1/350 Akagi Deck
Post by Peter H »
Hi Guys
I need some advise / assistance with the Dry Decals for the wooden deck on my 90% complete 1/350 Akagi. She has been "put aside" for a year or more because when I first tried to apply the dry decals some stayed on the wooden deck and some peeled straight off and were no use (ruined).
Is there a "trick" to this? I did all of my previous 1/35 Military with dry decals for several years and normally worked perfectly on plastic so I am used to dry decals.
I assume the wooden deck is not a good bonding surface? (I have NOT put anything like a sealer etc on the deck, its straight from the pack)
My Akagi is out of retirement now and I have found most of the un-fitted parts & have the rest of the dry decals to fit. I just need assistance, help! :-)
Thanks in advance.
Peter Hoskins
Sydney, AU
Peter, since that's more of a modeling technique question, you might want to ask it in the Main Forum or Tips and Tricks instead.
Peter H
Post by Peter H »
Hi Tim
Thanks for the reply, I just thought that someone who had built an Akagi may have encountered this before & may have an answer.
I will add to tip section and see how I go.
Peter Hoskins
Sydney, AU
Post by Guest »
Just noticed HLJ has a Fujimi 1/700 Kaga full hull for August release, hurrah!
Surely that must mean the hull form is on the CAD files for 1/350... one can live in hope.
Post by Guest »
A quick look at the Japanese Fujimi mokei homepage reveals artwork for a 1/350 Kaga!
http://www.fujimimokei.com/
There's also box art for a 1/700 triple deck Kaga, previewed on this thread.
Amazingly good news, well done Fujimi (if true)!
It doesn't get much more real than an official posting on the company's site. They've also been posted in the Main Forum's Upcoming Releases thread for a while ;)
Mutsuo Sasaki
Post by Mutsuo Sasaki »
It looks as if the researcher for the Fujimi 1/350 Kaga kitmodel has found something new in recent months,consequently there must be a delay in it�s release.
Mutsuo S.
Adaks
Post by Adaks »
New book Kaga 1920 - 1942. The Japanese Aircraft Carrier has been published by Kagero. :) It looks good.
Interesting because this title was announced by AJ-PRESS four years ago. Cover art is the same.
Many thanks to Cadman for posting an in-box review of the new 1/700 Akagi kit today. From his posted pics, it appears that Hasegawa managed (again) to execute properly scaled flight deck planking. With rain gutters to boot.
Gee, imagine that, Fujimi. It can be done. For both plastic and wood sticker.
Peter H
Post by Peter H »
Just an FYI, Fujimi's 1/350 IJN Kaga & etch sets have just become available as pre-order on the Hobby Search page with release quoted as "late May".
Rgds
Peter H
Sydney, AU
Jack G
Post by Jack G »
A Kaga flight deck question: on this link (3rd photo you can select) a model of Kaga is shown with multiple greys in the metal sections of her flight deck.
https://www.hlj.com/product/MDG23093/Nav
Is this how her deck was coloured, or is this some artistic licence the model maker has used? It's quite fetching and I used this scheme of greys on the 1/700 'study' model of Kaga I did in anticipation of the big 1/350 kit.
Return to “Aircraft Carriers”
