Uh oh...that could be a problem...can't build her as she appears now then. Would you happen to have any pics of her with her non-skid pattern? I want to know how much of Trumpy's is correct.
Tony Bunch
right quick....
Post by Tony Bunch »
Hi Guys,
Timmy,
and....
here you go...right quick.
Tony
Did she ever have a period where there was some more wood?
Tony Bunch
Trumpeter's 1/700 Iowa Class
Hi Guys,
Timmy,
The 1/700 Trumpeter...Pit-Road kit is closest to the New Jersey in accuracy.
If you want Mo, FILL IN all of the necessary recessed deck plank detail till you arrive at the Missouri's patern; that's what I did with the Tamiya New Jersey kit.
Remember too; the forwards fire control tower is different....
I'll say this only once........remember????????
Better off building the New Jersey.
I'll be happy to help you.
Tony
Building NJ would mean making the ears, though =( I was hoping that Trumpy/PR would have made different deck patterns for the four ships. Did you just use putty to fill the gaps?
Here's the last page of the instructions:
http://warshipmodels.com/~users/TimmyC/ ... nslast.JPG
I'm not sure why there's that sphere in front of the tower...I'll be leaving it off, I guess. Do you think that the structure on the tower represents the Missouri structure enough?
And here's the aft deck:
http://warshipmodels.com/~users/TimmyC/ ... eckoob.JPG
dick wood
Tony....So your going to work on a real scale ship model
Post by dick wood »
Tony, Glad to see that your 1/350, real scale, model of the Mo is on your work bench again. Now are you going to finish her this time? Will it be ready for the Nats in 07?
She is looking sweet, love the Mo. :thumbs_up_1:
Your buddy
Dick Wood
Dick Wood
Tony Bunch
okay...
Hi Guys,
Timmy,
Now I remember more correctly. Yes, the Trumpeter Missouri kit had somewhat of an accurate forward fire control tower. You could just enclose the roof of it and call it accurate. To do the New Jersey would be more work, no point in that; especially if you want to do the Missouri.
For the "spheres", they are the RPV drone antennae. The RPV drones were not in use the entire lifespan of the modernized Missouri. I have pics of Missouri with and without the RPV antennae and the related platforms.
The satellite antennae are also located in these same "high up" areas of the superstructure, (fwd fct and aft funnel), and they are round, recessed shaped.
Unlike with the RPV antennae, the satellite antennae do seem to be in all of the modern Mo pics I've seen.
Dick,
How do you do? :thumbs_up_1:
Be well Gents, Tony
So it would be correct to leave the sphere on?
And thanks =)
Tony Bunch
Hi Tim,
And thanks =)
Yes, BOTH of them.......
The RPV antennae sphere(s) were installed between May and December 1990.
"When all else fails, ask an Iowa fan.. :thumbs_up_1: "
Tony
Awesome. Thanks Tony :thumbs_up_1:
thathaway3
Post by thathaway3 »
Looks OUTSTANDING, Tony. One thing I found out when I did my Tamiya Missouri. The flag bag lockers that are molded into the deck are slightly too far forward from the actual position on the ship. You can tell when you look at the photos, that the deck opening aft of them in the model is quite a bit larger than it should be. I didn't notice until I'd gone way too far into the build to cut them off and re-locate them. It probably wouldn't matter too much, except when I installed the PE railing on the lockers and then ran the halyards up to the yard arm which is located up on the mast, the halyards wound up with a very pronounced diagonal run when in fact they should be a lot more close to vertical. Since I went to the trouble to scratch build the missing locker aft of the after stack, and modify the aft mast, I wish I'd noticed the problem on the forward ones before it was too late.
Tom
Tom Hathaway
Tony Bunch
too far along...
Hi Guys,
Tom,
Same thing' too far along! Thanks for the info though.
I have also scratched up the aft funnel flag bag; not attached yet.
Right now, I am focusing on the bow 20mm platform. I will now have to make a new one and find the exact shape to copy. I've been studying lots of bow-on shots. I still have to add on the anchor bolsters too. That will be easy when compared to the 20mm platform. Plus, I'll probably re-paint the metal deck area, as it has taken quite a bit of abuse lately.
back to work for me, Tony
Jeffcsr
Post by Jeffcsr »
Sorry to be dense, but the differences in the 4 Iowas were that the Iowa had an open bridge and different AA guns on the #2 turret. Were the other 3 the same?
How about the bow? Were they all the same shape? The Wisconsin, after having the bow replaced, was it different before & after?
Jeff: At WWII's end, all four Iowas had square bridges. So it really depends (as it always seems to be in ship modelling!) on the time period ;)
Iowa and NJ were born with open bridges.
NJ then had rounded bridge before going to square. Not sure if the same is true for Iowa.
And Miss and Wis both had square bridge as built, I think.
Poppop
Post by Poppop »
Has anyone seen pictures, or have a review on the 1:350 Yankee Modelworks Iowa Class BB Replacement Turrets?
I went to the Yankee site, but it is under reconstruction.
The description of the product sounds quite interesting... turrets (both 16" and 5"), metal barrels, bloomer bags, etc.
Charlie
Tony Bunch
Hi Guys,
Charlie,
I have the YM Iowa Class turrets; got them at the Nats for $25. I had to see them! I'm an Iowa fan!
Okay okay......I like L'Arsenal's 5" twin mounts better...with the L'Arsenal BRASS barrels. Kind of a pain to use the brass barrels, but probably the best set up.
The 16"50 Mk7 three gun turrets look pretty much the same as Tamiya's turrets...I have to tell you.
Of course, now I'll HAVE to post some pics...give me a minute...
Here are the 5" twin mounts for you to see...similar in most respects.
The CW barrels fall far short of the L'Arsenal offerings.
Please noone ask me to do a cost comparison here...okay?
Here are the main turrets...
The main battery turrets by CW look like resin cast already assembled Tamiya turrets...just no ladders in place. I can say this though.....I ruined one main battery kit turret trying to remove the molded in ladders on the turret face.
The CW turrets are ready for my Nuttal brass barrels....and the GMM vertical ladders for the turret faces. I'll not be using the CW cast barrels as they fall far short in quality.
Hope to help Charlie and anyone else...
Tony Bunch
Iowa Fan First!
Poppop
Post by Poppop »
Tony:
Thanks for the prompt post. As usual, your insight is helpful and "to the point". I have a set of L'Arsenal 5" turrets and barrels, along with a set of Steve's 16" barrels (it still hurts to remember he is not with us physically). I will be thinking over the options.. it may be worth the price to get the 16" turrets without the ladders, along with the blast bags. Could save some precious time in trying to get the Missouri moving again!
Charlie
Tony Bunch
Hi Guys,
Charlie et all,
Maybe now is a good time for us to be thankful.
Glad to help, Tony
ps the bottom of the resin turrets are mostly the same, but with two hatches in place additionally.
abramsteve
Post by abramsteve »
G'day Guys!!
Its been a while since Ive posted here, but Ive finnaly got round to giving my Missouri her repair and refit after her (much) earlier fall. Ive rebuilt some of the structure and repaired the main guns. Theres still some parts that need replacing but I was quite happy with the lower hull fit, which I pinched from a Trumpeter Wissconsin.
http://www.warshipmodels.com/~users/SteveD/DSCF0556.JPG
abramsteve
oopppsss!!!!
That was my first attempt at posting an image, that wasnt what I was expecting! :smallsmile:
