Carrier Builders Yard, whats on the Slipway
Hippy Ed
Post by Hippy Ed »
Hill wrote:
kidcurrie42 wrote:Hiya Hill,
What date are you going to depict CVA-19 in, at the moment i have several Hasagawa kits that i will be using, i have a CV-15 in progress and CV-10, CV-15 and CV-17 will also be done WW2
Happy modeling
John
I want to build ship in late 60 or early 70 configuration. I am using BUILDING TWENTY-SEVEN-CHARLIE by Ray Bean from this forum, and few drawings and photos from net. I have a lot of photos of Intrepid and very fev of Hannah, and I hope that this ships was similar. But still i have a few questions, for example about deck markings.
You have your work cut out for you converting from WWII to Vietnam era. You can find alot of info on the Hannah as there is a CVA-19 association. I don't have it bookmarked at the moment.
Will be interesting to see this build tho :big_grin:
You've lost everything...
On the Bench:
mitchell300
Post by mitchell300 »
kidcurrie42 wrote:
mitchell300 wrote:No only the decals are shiny :S
But thanks.
I hope my modelshop has that paint..
Mitch ;)
Mitch did you Varnish or use clear/future on the deck before decals ?
Is it bad if i say i didnt use anything?
:S
Mitch ;)
New Ships Planned For Shipyard:
USS.Missouri 1.545 scale to new jersey desert combat
Ships in dock:
USS.Saratoga 1.535 scale Desert combat (currently on hold)
Ships in repair:
SMS Tirpitz 1/540 (adding new radars and fixing the main guns)
DBlack
Post by DBlack »
mitchell300 wrote:
kidcurrie42 wrote: Mitch did you Varnish or use clear/future on the deck before decals ?
:S
Mitch ;)
You'll get much better results applying decals to a glossy surface.
kidcurrie42
Post by kidcurrie42 »
:S
Mitch ;)
Ok, Mitch,
When a matt paint is applied and dries, if it was looked at under a magnifying glass it would look sinilar to a orange peel, put a decal on top of this and it traps air, when sealed with gloss or matt varnish the trapped air will show through and the clear decal film will show, this what we call silvering, putting a decal on a glossy surface is like putting it on a piece of glassand when sealed no air is normally present and the decal film is virtually invisible.
Hope that explains it and makes sense.
Happy modeling
John
Si Vis Pacem, Para Bellum
Sauragnmon
Post by Sauragnmon »
Between that and peeling, it's why I don't do decals. all my markings are painted.
mitchell300
What do i have to do now then?
Yesterday 1 decal came loose...
I trew it back on and it sits stil on the deck.
But what to do now?
I am going to weather it ofcourse, but what if the paint comes under it?
Mitch ;)
Ships in dock:
Ships in repair:
arnobiz
Post by arnobiz »
Remove them and paint the markings or try to brush your deck with very diluted gloss varnish in the hope that it will flow underneath your decals.
mitchell300
removing and painting?
U know how hard that is O.o
Mitch ;)
Ships in dock:
Ships in repair:
orb
Post by orb »
mitchell300 wrote:What do i have to do now then?
But what to do now?
Mitch ;)
Hey Mitch, Humbrol has something called "Decalfix" on the market. You apply it before and after the decals. Maybe that could help.
Image Heiko S. | MY SHIPYARD | Under construction: JDS Takanami (Takanami Class Destroyer)
Hippy Ed
Post by Hippy Ed »
But what to do now?
Mitch ;)
I always use Future (Klear)floor wax when I decal. I gloss coat the model & let it dry and, when I get ready to apply them I dab a brush into the Future jug & place it where the decal will go & then apply the decal & let it set up somne before I put a final coat over the decal.
Hope this helps
Eddie
On the Bench:
Mark McKinnis
Post by Mark McKinnis »
mitchell300 wrote:removing and painting?
Mitch ;)
Removing the decals will actually be very easy since they are peeling off anyway. Put the ship under water in the sink and gently rub the decals and they will flow right off. If you do not want to paint the deck, then get some more decals. Starfighter decals offer a set of Forrestal Class decals for the ships and they are very good. They are fairly difficult for a beginer due to the fact that they are thin. That makes them look great, but it is a little harder.
If you are doing decals, gloss coat the ship first. It should look very glossy when it is dry. Apply your decals and let them dry. Spray the ship with Dull Coat and let it dry. Then you can do your weathering. Skip the paints and varnishes at the hardware store or in your garage and just get to a hobby shop and buy gloss coat and dull coat. You may be able to do it online as well. If you spray the decals with dull coat and they are not dry, they will wrinkle up and you will be very angry, so that is why I emphasize letting them really dry before moving to the next step.
If you apply your decals and they are still not sitting down as you like, use a mixture of 50% water and 50% vinegar ( essentially solv a set)to soften the decals and they will sit right down on the surface of your model. I keep a little bottle of that formula handy when I apply decals just in case. Let your decals get tacky before you apply the vinegar solution or you will create a lake on your model and they will float off of their designated positions.
If you decide to paint the details on your deck, gloss coat the deck as well. This will create a nice surface for the tape that you will use to tape off the stripes and such. Tape does not stick well to a dull surface and this will screw up your striping effort.
Follow these steps and your carrier will look great!
Good Luck,
Mark
mitchell300
Lol, i dont know what for paint it is.
But if i use translate.google.
It says its boring paint and shiny paint :big_grin: :heh:
Hmm, my other carrier fine done whit decals.
Why is this 1 giving me problems?
Is it maby bcs my other carrier had a shiny paint on it?
(could see myself in it, until dust came on it xD)
Mitch ;)
Ships in dock:
Ships in repair:
Hill
Post by Hill »
Hi friends,
here is little progress on my Hannah.
mitchell300
What is that ?
USS Hannah?
Thats an destroyer xD
Can u tell me what ur building?
Mitch ;)
Ships in dock:
Ships in repair:
nick
Post by nick »
mitchell300 wrote:What is that ?
USS Hannah?
Mitch
What is that ?
USS Hannah?
Mitch ;)
:wave_1:
I think you meant the USS Hancock. She was nicknamed "hannah", I think...
He may have used a 1/700 Essex clas '44 era kit and converted it to a post-war one, tough job I suppose!
Nichol Caballero
mitchell300
What are those sticking out things in the middle side then?
On the side from the conning tower.
Because i cant see them on the real carriers.
Mitch ;)
Ships in dock:
Ships in repair:
Nektarios
Post by Nektarios »
Hill wrote:Hi friends,
That looks great Hill. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :wave_1:
On the workbench:
Various 1/700 aircraft.
Juan Carlos I LHD 1/700.
HMAS Canbera LHD 1/700.
FGS Type 122 class FFG 1/700.
LSD-41 class LPD 1/700.
nick
Post by nick »
mitchell300 wrote:What are those sticking out things in the middle side then?
Mitch ;)
This is highly hypothetical but here goes...
SInce the Essex class carriers' flight decks were a tad too narrow to support jet aircraft, The deck edges were extended for more deck space. This can be clearly seen on some modernized Long-hull Essex class carriers especially Oriskany. I think this is the reason why the Midway class had an oddly shaped flight deck...
:big_grin:
Nick
Nichol Caballero
mitchell300
Wow, never knew that.
Thanks for the info!
:thumbs_up_1:
Mitch ;)
Ships in dock:
Ships in repair:
Avery Boyer
Post by Avery Boyer »
Mitch ;)
:big_grin:
Nick
Very good! Just to elaborate slightly, the angle decks were added, as Nick said, to support modern jet aircraft. They allowed aircraft to be launched more quickly and recovered more effeciently. One aircraft could be launched off the angeled portion of the deck, and one off the bow. HTH! :thumbs_up_1:
