Jose
1/700 Amagi diorama
- J. Soca
Re: 1/700 Amagi diorama
You never seize to amaze me this is truly mind boggling
Jose
Jose
marijn van gils
Thanks guys!
And Wouter, you're welcome of course!
Marijn
Marijn
marijn van gils
Meanwhile, I tackled the last area of battle damage: the area to the inside of the stacks.
I only had blurry photos of this area at first, and at high tide, and I had misinterpreted a wire with wreckage hanging down as a crack in the hangar deck.
So I filled this with superglue and sanded smooth.
Sharper pics at low tide also showed a missing plate in the hangar deck, at the water level. This was cut out, and had it's edges thinned.
I 'dented' the aft stack a bit by scraping plastic away with a n.15 blade:
Next, I adding the damaged internals. I started by making a piece of bulkhead in the way I described before in this thread:
� and glued it in place. I also added some adjacent less damaged compartment bulkheads the the front of it.
Now I added the support structure beams I could make out on the photo's:
Several pieces of rubble, like this one, were constructed separately:
�glued in place:
� and added more detail and rubble to, in situ:
After repeating this a couple of times, this is the result:
Some of the pics I worked from:
Cheers!
Marijn
�glued in place:
Cheers!
Marijn
Koppalakki
That looks pretty sick
Indeed. I can't recall every seeing anyone capture battle damage to the extent and with the finesse that you have. Unreal.Koppalakki wrote:That looks pretty sick
Ditto that.Indeed. I can't recall every seeing anyone capture battle damage to the extent and with the finesse that you have. Unreal.
- Goodwood
In triplicate.Dan K wrote:Ditto that.Indeed. I can't recall every seeing anyone capture battle damage to the extent and with the finesse that you have. Unreal.
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
On the ways:
In the stash:
- blacman
hmm...
you are really insane...
this is insane
I love it
this is insane
I love it
- JIM BAUMANN
Fine damage indeed ! ? !
once all the colours are homogenised it will really pull together with the dark/light and shade!
JIM B
JIM B
- Aop Aur
Very nice! I guess I am going to need the brass shim as well....looks pretty very useful for anything!
Can't wait to see the first coat of paint on!
Aop
Aop
On the way:
And our artworks!
And our artworks!
marijn van gils
Many thanks everyone!
Luckily, not too much is left: the AA platforms forward of the island, one rudder and two propellers, two masts, and observation platform at the starboard stern.
Marijn
That's the plan indeed! The painting will be the real fun!JIM BAUMANN wrote:once all the colours are homogenised it will really pull together with the dark/light and shade!
Me too, me too!Aop Aur wrote:Can't wait to see the first coat of paint on!
Marijn
Joe Simon
This thing is going to be crazy. I see another book in your future!
anyahajobuzi
This is going to be the most beautiful heap of scrap I had ever seen!!!
Extremely neat work Marijn!!!
Cheers: Laci
Cheers: Laci
- DWD
Marijn, that is some spectacular modelling of metal carnage right there. Can't wait to see what you do with the paint and weathering.
Doug
Currently building:
viewtopic.php?f=59&t=120496
Currently building:
- Aur
Extremely amazing work! Very, very realistic battle damage, too! Can't wait to see them painted!
Aur
How are you going to make them? Scratch-build? Looking forward to seeing them!marijn van gils wrote:two propellers.
Aur
On the way:
1/350 Tamiya DKM Tirpitz Nov 1944
1/350 scratch-build HMS Lion never built battleship (1938)
Completed build:
1/350 AFV Club Japanese Submarine I-58
And our artworks!
Completed build:
And our artworks!
marijn van gils
Can't wait to see it painted too!
Unfortunately, I haven't been able to do much modelling lately. Too much new music to study for a couple of upcoming gigs...
But that will out of the way soon.
But first I have to finish the last AA platforms near the bow�
Marijn
All I have lying around is the props of Lexington. I'll see if I can start from there (carving them down), but more likely they will be scratch built indeed.Aur wrote:How are you going to make them? Scratch-build?marijn van gils wrote:two propellers.
Marijn
marijn van gils
Finally back at the bench...
I finished the last platforms, the ones closest to the bow:
The basis of the 5' platforms comes from the Lionroar PE set, but had to be modified heavily because the guns are removed. The star-shaped parts came from Bruno Gire's PE set, which was very useful! Thanks Bruno! For the same reason, and also to get them finer and more correct, the gussets and supports underneat had to be scratchbuilt.
Marijn
Marijn
- LE BOSCO
This is a slap in each progress
just superb Marijn
cheers
nicolas
cheers
nicolas
- Angeliccypher
I do not know whether I should cheer due to the awesomeness of this build or puke because I feel like a hack watching this.
well done Marjin
Gabriel
- robn1
Absolutely astounding, and the scale makes it even more so. I am in awe of your skills.....
