Calling all Los Angeles-class (SSN-688) fans
SS, and SSN.
Tom Dougherty
Re: Calling all Los Angeles SSN-688 class fans
Post by Tom Dougherty »
Many thanks, Tracy! I too thought I had tried that link permutation!
Frankly, the instructions for revising the relocated link files on the website are...obscure at best.
Tom Dougherty
Vepr157
Post by Vepr157 »
Tracy White wrote:
Vepr157 wrote:The I3B and I3M are your classic skewed propellers (skewback is an ok term, but I think still slightly colloquial). The I3B is the original 688 propeller, and the I3M is quite similar. I suspect the difference is either that the I3M has improved blade tip geometry or it can mount the hub vortex diffuser.
I've been doing some digging here and there to try and come up with "definitive information" (I'm not holding my breath) and came up with interesting information in SSN-762 Columbus Command History for 1994 (on page 4) of the Command Histories for Columbus on the Naval History and Heritage Command site.
Essentially, Columbus had the I3M propeller and "dihydrals" (page 3, paragraph 3 "narrative") installed in the first half of 1994 and when she reached the Pacific afterwards , she performed extensive testing in September. I'm not sure if the baseline they established was for her or for 688i's in general, indicating a rough timeline of when the I3M became available.`
I suspect that the I3M was developed in the '70s. The official history of DTMB (Where the Fleet Begins) mentions that in the '70s DTMB developed a modified blade tip for the 688 propeller to improve tip cavitation, and that older propellers had their tips cut off and the new ones "bolted" on (must have been flush fasteners or something). Also the SKU of the I3M has a similar number to other 688 propeller developed in the '70s.
The 688I was intended to have a hybrid propeller from the start, as evidenced by congressional testimony (the Navy just said they would have new and quieter propellers, but the artists' impressions show a hybrid propeller). I would guess that most, if not all, 688Is had hybrid propellers when they entered service.
So I would guess that in the case of the Columbus, the newer hybrid propeller was removed and the older I3M installed for testing purposes. The early '90s was a time of intense propulsor development in preparation for the Seawolf and NSSN. The Philadelphia even tested a few varieties of pumpjets.
Jacob
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/350 George Washington
1/72 Type VIIC
ESzczesniak
Re: Calling all Los Angeles-class (SSN-688) fans
Post by ESzczesniak »
I'm building the RCSubs 1/144 Los Angeles class as the USS Indianapolis SSN-697. The kit includes two caps (there's probably a more correct term) for the horizontal fins on the tail. However, the instructions don't really give much help which one to select. Are any experts out there able to help shed some light on the differences and which one to use? Thank you!
Maarten Sch�nfeld
Post by Maarten Sch�nfeld »
Just my guess: the cylindrical one is used in case of a towed sonar array, the cable protruding then from the rear of that cylinder. Erroneously called 'antenna unwinder', but the idea is obvious.
The other pointed one is fitted when no towed sonar array is carried, mostly in earlier versions.
Does this make sense?
Roger Whittaker +9/13/2023
ESzczesniak
Maarten Sch�nfeld wrote: Sat Jun 13, 2026 11:05 am Just my guess: the cylindrical one is used in case of a towed sonar array, the cable protruding then from the rear of that cylinder. Erroneously called 'antenna unwinder', but the idea is obvious.
Definitely makes sense. Just not sure which would be on SSN-697.
EDIT: I’m not much of an expert at all on ships. My Googling is suggesting flight I and II were retrofitted with the towed array. Google says the retrofitted ships had a “starboard protuberance” to identify them. Is that the long rounded half cylinder that runs down almost the full length of the hull? If so, the kit has that molded in, so using the second option labeled as “antenna unwinder” would be correct?
Maarten Sch�nfeld
ESzczesniak wrote: Sat Jun 13, 2026 11:09 am
Yes, the duct along the hull is associated with the towed array. So if that's installed, the obvious working end would be the 'antenna unwinder'. Only in specific cases when the array is not used or installed the other 'cap' could be in use, but it would be the anomaly.
ESzczesniak
Thank you!
Vepr157
Post by Vepr157 »
ESzczesniak wrote: Sat Jun 13, 2026 10:21 am I'm building the RCSubs 1/144 Los Angeles class as the USS Indianapolis SSN-697. The kit includes two caps (there's probably a more correct term) for the horizontal fins on the tail. However, the instructions don't really give much help which one to select. Are any experts out there able to help shed some light on the differences and which one to use? Thank you!
You should install just the port towed array tube as I believe the Indianapolis did not get the thin-line towed array which was streamed out of the starboard stabilizer. The airfoil-shaped caps they provided are odd and I have never seen a 688 with them.
Jacob
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/72 Type VIIC
Return to “Submarines”
