1/350 HMS Hood (scratchbuild)
rotley
Re: 1/350 HMS Hood (scratchbuild)
G'day EJFoeth
With your anchor arrangement I was wondering how you made your anchor stopper chain. Are there existing PE parts or did you design/make the pieces yourself? Have considered using 1/700 scale anchor chain as the stopper chain on a 1/350 model but would that be over scale?
Rod
Rod
EJFoeth
Hello Rod,
both the main and stopper chains are from a set of chains I bought from Saemann in Germany (http://www.saemann-aetztechnik.de/index.html). I do not see the chains on his page at the moment. I flattened all the links with a pair of pliers to get them into the right shape and added the center stud to the main chain; the rest is stryrene.
EJFoeth
The first margin plank pass around the foward superstructure was added. This is a depressing part, because it shows the oldest parts of the model from when I thought that adding a pre-scribed styrene sheet to the WEM model was a good idea. Meanwhile I had to carve out large areas of the styrene and replace them when necessary. The glue wasn' t spread out very well everywhere so I just cut out a part, added glue, and put the original deck back. Oh well, why not. You can also see many of styrene rods in the deck; these are small "deck anchors"... the superstructure will be placed on a few of these anchors or screwed into support pillars glued directly into the resin. The debonding of the styrene with the hull would mean this model would be beyond salvage, so I cannot glue anything to the prescribed styrene. So, this doesn't look pretty, but no harm in admitting a few mistakes. I also had to remove the vents around the conning tower but these could be salvaged and will be placed back later
EJFoeth
So, fine, I violated the agreement I made with me that I would not demolish anything on the model, but the forward breakwater just had to go to add the margin planks. Be gone, awful breakwater!
Just a matter of drawing up a new one with minor but persistent disturbances, in this case Sigrid, one of our new Norwegian Forest cats. They can even reach the safe space on top of the cabinet where I store my tools "away from the cats".
I did some programming work in Rhino but never really used it to draw. It went really easily. The tricky part about the breakwater is those two storage lockers that contain the paravanes. The long side of the locker follows the breakwater and the few images I have show that the roof is completely flat so it has to angle down a bit. This will add some taper to the front of the locker where the hatches are. When I built the first version I had no images how much taper would be there, but meanwhile Ian Johnston's Clydebank Battle cruiser book shows the locker twice with hardly any taper (as far as I can see). I played around with the height of the breakwater and taper angle until I got something that was looking decent. This means deviating from the AOTS slighly (<0.5mm). I also had the doors etched so I added them to see if they would fit at all. Looks good enough.
Adding the margin planks should be a lot easier now.
- Three Missouris
I cannot see any pics on this post. Just blue squares with question marks.
Hold on, now I see the cat photo and some others.
- Aop Aur
I am envious that you have such a good program!
The cat is really lovely! How many do you have in total?
Aop
Aop
On the way:
And our artworks!
And our artworks!
EJFoeth
Our cat herd consists of 6... 2 black Norwegian's , 2 blondes as above, and 2 Siamese. The blondes are kittens and they demand a lot of attention. The Siamese always require attention
I'm really happy with the cover for my model...
So far Rhino works really nice, almost the same as Autocad; the line commands are slightly different so it takes some getting used to. Mi used to be mirror, now it is minimize; results in weird facial expressions. Because it's 3D this particular item is much easier to set up using planes and intersections. I'll try to make a 3D drawing of the part including plate thickness for the models.
It is a good exercise, because for my next model most of the ship has to be entered into 3D before progressing. It's the best way to keep notes
I have some parts drawn in 2D for Hood (stair case placement for the correct dimensions etc) but the use is limited. It will also be easier on the math; e.g., the shape of the breakwater plates can be determined by hand (I know my vector algebra) but simply reading it from the drawing is easier.
- JIM BAUMANN
Foeth wrote;
...because for my next model...
Now that is the voice of future planning!
I have long admired your perseverance and tenacity with the protracted Hood build!
and now I am in awe of your long-term vision !
JB
JB
EJFoeth
I hope to have the decks painted these Christmas holiday.. beginning of the end
I want to build this scene:
- Model Monkey
The breakwater render looks very good!
Surely John Roberts struggled mightily to make his AOTS drawings from the original 2D NMM plans, certainly old and with some distortion that naturally comes with time. Using any CAD program to actually build a feature in 3D from 2D drawings can sure show where things aren't quite right with the 2D drawings.
Still, my hat is off to John for giving us something very valuable to work from.
It is easy to imagine the metal fabricators of the real breakwater scratching their heads when they received the original plans. I often wonder how many times fabricators said, "Obviously, the engineers who drew those plans never and to make this object. I don't care what those ridiculous plans show, we're going to actually make that object like this...." Thus, the need for us to see good photos of the real object.
Can't wait to see paint on the decks.
Impressive scene on PoW! Is that the meeting of Churchill and Roosevelt?
That will be a very fine build.
EJFoeth
The AOTS is a great reference but not perfect. I also found out that the aft searchlight platform drawing doesn't add up for the two levels. It's not so bad, but you really need to check everything... going to 3D is a tool people did not have before so of course it will show minor deficiencies. Nothing new here! If I had to start over I'd use the original plans, but even then the AOTS is such a wonderful resource. For the bridge levels I made the deck outlines first and made damn sure all the ladder openings are exactly on top of each other (I even used a styrene strip to test fit... ). And still you find small problems to solve.
The breakwater is actually quite a complex shape for a simple quick&dirty 2D drawing, as you need to draw a few angled plates onto a camber deck. I learned a few drawing tricks at school to do such intersections but it takes time. I now work under the assumption that a) the roof is perfectly flat (because I cannot see any non-parallel lines or contrast changes, even not a subtle one) and as the front the paravane locker is really invisible when looking at the breakwater I conclude the roof must follow the breakwater outline. So it seems the really did make that odd shape! I suppose detailed drawings were made up for the vessel by the yard. My model does not have the deck camber, incidentally. Next one will... I think...
I have to do a bit more deck scratching around the fwd barbettes, breakwaters, and a bit at the deck edge, then the boat deck and below the boat deck (last one is simple). Then paint it, see the horror and correct! Paint it again, fingers crossed...
The POW pic is indeed Churchill and Roosevelt, meeting at Placentia Bay, with the USS McDougal next to her. Going to add her too. Bought plans (floating drydock), all the pictures I can find. Need more... Fortunately this site has plenty knowledgeable USN people so I know it will turn out ok
PRESIDENT ROOSEVELT MEETS PRIME MINISTER CHURCHILL. 10 AUGUST 1941, ON BOARD HMS PRINCE OF WALES, IN THE NORTH ATLANTIC OFF NEWFOUNDLAND. THE MEETINGS TOOK PLACE ON BOARD THE BATTLESHIP HMS PRINCE OF WALES AND THE AMERICAN CRUISER USS AUGUSTA, THE MEETINGS STARTED ON 9 AUGUST 1941.. � IWM (A 4808)IWM Non Commercial Licence
EJFoeth
So I trashed the second breakwater too and started scribing in the lines. The yellow parts on the rendering contains lines spaced 0.5mm, parallel to the breakwater.
3D work is great, really helpful, should have done that sooner.
The boat deck is now nearly completed, scribe wise. One of the many tricky parts is a) drawing paralel lines on a part with so much junk (err, detail) in the way, and scribing these tiny lines without punching through the deck. Very time consuming, but, calming work to do... All the lines and maring planks have been added and all damaged splintershields nearly all repaired.
- Martocticvs
I saw your work on the scribed sheet deck when I was looking through your website the other day. How are you finding it? I'm considering this approach for my build of KGV as Duke of York. Your work looks very thorough and effective - but I'm guessing this is one of those things that sounds like a good idea and turns out to be a herculean task?
EJFoeth
I really like working on the decks, but indeed, the amount of work is huge. Of course, doing this in the final stages of the model rather than at the start has resulted in many additional hours, but you'd still be spending well over 40 hours (probably a very optimistic estimate
). The big breakthrough was finding a set of chisels by Sujibori-do. Very expensive(>�25 each) but I find them very useful not only for scribing but also for cleaning up the model.. Here's a pic for the upcoming blog post:
These have been so very useful for adding in the various lines and I think they are the best tool find of the past years. If I had to start all over, I'd probably add the V-grooved Styrene (Or Car siding depending on what ship you are doing), use a router to remove the waterway along the entire outside of the deck, and add a plastic strip to simulate the waterway. Then you can slowly start adding deck detail and carve in the margin planks. For most of the deck you'd have to go through the putty-and-rescribe routine. But having a clean surface to work with should make life so much easier! Most the superstructure of Hood can be removed and I demolished the breakwaters and splintershielding, but I kept the barbettes, anchor chains and all the detail on the boat deck... The scary part will be priming the deck once done and to see what it really looks like...
EJFoeth
Breakwater planking pattern added, using the 3d file as a basis; the planks line run partially parallel to the breakwater. There is no plank nibbing in the margin planks on the fwd side of the breakwater but I added some at the rear around the paravane lockers... The main plank lines are added to the forecastle part. Once the 2nd breakwater pattern and steam winch locations are added the rest of the deck can be completed. And then: repair of the spurnwater and degaussing cable where necessary. The spurnwater did not always survive the chiseling.
Best enjoyed with a small bottle of wine
- JIM BAUMANN
Remarkable and dedicated retro-work on 'the' model .....at such an advanced stage...
Brave !
JB
Brave !
JB
EJFoeth
Thank you... a better choice of word than "stupid"JIM BAUMANN wrote:Brave !
Remarkable work. Your dedication and persistence are incredible. I'm not sure if you should commended or committed.
EJFoeth
Committed and treated for not being able to finish anything and coming up with creative ways to postpone?
The forward breakwater itself is also nearly done
EJFoeth
used the Easter holidays to add a bit of detail to the fwd breakwater....
