Calling all USS North Carolina BB-55 & USS Washington BB-56 fans
Re: Calling all USS North Carolina & Washington fans
You may find something here
- jester63
Thanks Martin! So is this http://www.usswashington.com/armnt.htm the late 1942 modified AA fit then?
The Workbench:
1/350 USS Vincennes
1/350 USS Indianapolis
Future Builds:
1/350 USS Quincy
1/350 Tam USS Missouri
1/350 USS Vincennes
Future Builds:
1/350 USS Quincy
- Dick J
The armament in that drawing on the main page looks like 1945, not late 1942.
- ArizonaBB39
Hi all. I'm almost done with a drawing im doing of the North Carolina in her MS12mod scheme and need help. I'm having a problem determining the pattern on the starboard side superstructure. Any help would be appreciated. I found this model http://www.modelshipgallery.com/gallery ... index.html is that close enough for me to use as a reference? Thanks in advance
- Dick J
Based on this photo http://www.navsource.org/archives/01/015537.jpg and comparing the hull painting, I would be inclined to question the superstructure as well. While this next photo http://www.navsource.org/archives/01/015519.jpg is tagged as "August 1941", it doesn't seem to match the modified MS-1 or MS-2 (depending on which source you reference) that North Carolina was reputed to have carried at the time. But it does show that when the superstructure was in the MS-12 (mod), the wave pattern on the hull was crisp and clear. Unfortunately, MS-12 (mod) was not as codefied as the later MS-31/32/33 patterns, MS-12 (mod) being largely at the discression of the ship and yard, so we don't have "official" pattern sheets to reference for any ship. Without a ton of photos (next to impossible, considering the paranoia - read "photo-phobia" - of the time), we are left to interpret fuzzier, more distant shots in order to approximate the patterns. I doubt that anyone will truely "get it right". On the flip side, it also means that whatever you do, it will be hard for anyone to prove you wrong.ArizonaBB39 wrote:I found this model http://www.modelshipgallery.com/gallery ... index.html is that close enough for me to use as a reference? Thanks in advance
The best interpretation of the Ms12 patter is in Randall Shoker's book on the North Carolina.
ddoyle
I thought I had located a pdf of the North Carolina's booklet of General Plans (or, MAYBE it was Washington's) online some time ago, but I cannot find same in my book marks.
Can anyone point me in the right direction?
David Doyle
David Doyle
- BSteinIPMS
Do any of you expert researchers have, or know of, a hull plating diagram or shell expansion diagram for North Carolina or Washington? This would be an excellent reference for detailing the hull.
--Bob Steinbrunn
--Bob Steinbrunn
IPMS/USA 3345
NRG 3569
NRG 3569
Bob e-mailed me and I sent him this link already: http://www.marylandsilver.com/world_war ... leship.htm
- BSteinIPMS
Thanks very much, Tracy, I appreciate the link. Although spendy it appears Mr. Borchers, Sr., at the Maryland Silver Company has just what I need. There's nothing quite like the original hull plating diagram or shell expansion diagram to make a model ship look like a real one: strakes of plating, hull lift rings along the bow, intakes, outlets, propeller lifting hard points, and such. I spent quite a lot of time on this 1/192 model of Kidd doing just that, all from plans and photos. Wish I'd had a plating diagram at that time.Tracy White wrote:Bob e-mailed me and I sent him this link already: http://www.marylandsilver.com/world_war ... leship.htm
Cheers!
--Bob Steinbrunn
IPMS/USA 3345
NRG 3569
NRG 3569
- dsk
That model is simply spectacular. Is there a link to more pics somewhere?
Hi DSK,dsk wrote:That model is simply spectacular. Is there a link to more pics somewhere? :)
I hadn't meant to divert this thread away from North Carolina by showing my 1/192 model of Kidd, but rather to show what hull detail could be added by having a hull plating diagram or shell expansion diagram. Pretty much the same thing.
Anyway, to answer your question, if you google my name and "USS Kidd" you'll come up with a number of hits, these among them:
http://www.steelnavy.com/BlueJacketKiddBSteinbrunn.htm
http://www.steelnavy.com/SteinbrunnFletcher.htm
Cheers!
--Bob Steinbrunn
- BSteinIPMS
Hi dsk,dsk wrote:That model is simply spectacular. Is there a link to more pics somewhere?
I hadn't meant to divert this thread away from North Carolina by showing a photo of my 1/192 Kidd, but rather to show what hull detail was possible by having access to a hull plating diagram or shell expansion diagram. Both pretty much the same thing.
Cheers!
--Bob Steinbrunn
IPMS/USA 3345
NRG 3569
NRG 3569
ddoyle
--Bob Steinbrunn[/quote]
Yep, and you can also Google his name and "M5A1" and find an equally impressive tank (for those interested)!
Bob, I've misplaced your new (as of a couple years ago) email address. Please drop me a note, there is a Tennessee boy that would like to pick you brain on some things.
David Doyle
David Doyle
- dsk
Wow, that's all I can say. But it must have made you sick when the goons accidentally busted the mast off!
Anyway, getting back on topic, I really want to build a model of Washington, but from what I'm reading here the model in the Trumpeter box is actually North Carolina. I'm not interested into hyper-accuracy like recontouring hull shapes and such, but is it a relatively simple process to modify the kit into a reasonably correct Washington, regardless of year?
- BSteinIPMS
Has anyone here built the Iron Shipwright 1/350 resin kit of North Carolina? It's my next project and while the hull looks fairly nice there is much to be replaced by aftermarket items in resin and photoetch.
--Bob Steinbrunn
--Bob Steinbrunn
IPMS/USA 3345
NRG 3569
NRG 3569
- CWatson
dsk wrote:Anyway, getting back on topic, I really want to build a model of Washington, but from what I'm reading here the model in the Trumpeter box is actually North Carolina. I'm not interested into hyper-accuracy like recontouring hull shapes and such, but is it a relatively simple process to modify the kit into a reasonably correct Washington, regardless of year?
This is for the 1/700 Washington boxed kit that contains a early 1942 N.C.
I do not have my notes anymore on my build but the main changes are:
#1 Filling in the extra 20mm and .50 cal mounting holes on the deck by filling them with plastic rod.
#2 Adding a 20mm on each side just aft of B turret so there is three on each side. You will have to shave off the shielding from the deck and replace it with a longer one from plastic strip. See my earlier post on this thread for pictures.
#3 Raise forward funnel 1.5mm and replace spotlights, 1x each side on the aft end of the funnel platform with 1x20mm AA gun each.
#4 Change radars on the main gun directors.
#5 Re arrange life rafts on structure and turret
#6 Paint in early Ms 12 Mod for Atlantic use. N.C. and Washington had slightly different schemes. Also Washington's main gun blast bags appear black on A and B turrets and canvas or light grey on C turret.
CW
Felix C
Compare the white metal castings to what is available from equivalent scale and model plastic injected. That tends to be the irksome point for me.BSteinIPMS wrote:Has anyone here built the Iron Shipwright 1/350 resin kit of North Carolina? It's my next project and while the hull looks fairly nice there is much to be replaced by aftermarket items in resin and photoetch.
--Bob Steinbrunn
So one could build the "Washington" out of the box and build a 1942 North Carolina?dsk wrote:I really want to build a model of Washington, but from what I'm reading here the model in the Trumpeter box is actually North Carolina.
- Dick J
From what I have seen of the 1/700 kit, the light AA arrangement is North Carolina's, not Washington's.MartinJQuinn wrote:So one could build the "Washington" out of the box and build a 1942 North Carolina?dsk wrote:I really want to build a model of Washington, but from what I'm reading here the model in the Trumpeter box is actually North Carolina.
