I spent some time working on my model again, and by a some I mean a lot! I finished the deck scribing for the entire model which turned out to be the most time consuming modeling activity ever
Scribing the decks at such a late phase of the build was really not a very smart idea as I destroyed a lot of existing detail, including the breakwaters (need to do one more). Adding all the lines where to scribe with all that nonsense (err, detail) in the way was really a time vampire! Suddenly the deck of a small model starts to look like a vast area.
The far end of the hull shows all the planks lines dutifully carved in as well as the margin planks around the bollards, the rudder plate and deck edge. You'll notice a few circular inserts between the vents; this is one of the area's where the glue between the deck and styrene separated and needed to be repaired. I also decided that the individual stanchions with railing will work so all the stanchion positions are drilled in, as well as the positions of all the awnings. I had some etched parts but they didn't work and need to be redone. The awnings were not present on deck, so they'll be the deck fittings. Drilling in should help positioning. I used the spring action pin vise bought at
Ushi's webshop and their drill set. The individual drills are very good (only 3 of them now permanently reside in the model) and even though the spring action drill could be a lot better I'd recommend getting one.
The margin planks around the barbette are easy to add without the turret in place (surprise!). The locations for the 4 steam winches are in place. Here you can see I also add to remove large positions of the deck. The part is really old and I should throw the entire hull away but I'm not going to. So, some inconsistencies will probably remain visible. There are a few circular details scatted around the deck, as well as a few positions for the davits than will be painted hull gray. I spent a lot of time looking at pics to see if margin planks should be added to all perpendicular lines but these were not always present or they were but I can't tell. If you look a bit to the right of the rear bollard you'll notice another disc in the waterway; this is a repair after a drill broke (0.25mm, don't move to much!).
The center deck was doing not so well. I removed all WEM parts when I got the kit and apparently puttied the deck, adding deck plating later. This is the cause for delamination (of course). All the brass rods are drilling into the styrene to fix the superstructure parts to so there will be no stress on the deck plates. Areas without any function were carved out. This shot also shows I continued with the margin planks for the superstructure, drawing the outlines, added an offset, puttying the existing lines, scribing in the details. Most of the disaster areas will be invisible after painting, but the deck isn't entirely flat. A lot of ammo lockers need to be added to this location to hide gaps between the superstructure and the deck... or I'll add random Denton floats that were stored there. There are many support pillars in this area. Today I replaced all of them by tubes by Albion Alloys. The center part of these pillars need to be painted white so adding three segments of tube is probably an easy way to get this demarcation quickly. There are four rectangular support pillars in the outer edges of the deck that were all damaged while scratching, as well as one of the folded ladder davits..
The margin planks at the deck edge look ok. I did some practicing on scrap styrene but decided to continue on the model Some are a bit wobbly but soit, should be fine I hope. The locations for more folded ladder davits are also in place.
In the end adding margin planks went quite well, so even the inside of the quarterdeck bulkhead is detailed (one skylight etch part to be added). The two etched parts on the deck are foot plates; the ladders will not be added as these were stored when at sea. In the right corner of the quarterdeck you'll notice one of the eight scupper scattered around the waterway.
Only one bollard missing... could be worse (Oh, I also lost the aft capstan and a winch drum
). I'm going to try adding a layer of primer of the quarterdeck and the main deck below the boat deck and paint those (hopefully this week / tomorrow). The forward deck and boat deck need a bit more work (sigh). Then I need to repair and the damage I did to the side of the hull (sigh). This is a depressing part but at least parts are now getting finished.
