Gentlemen,
I should probably read through this entire thread, but time presses . . .. Are the ICM 1/350 Koenig class ships each from the same molds? Or, do the kits reflect the minor differences between the actual ships?
Thanks!
Bill
Calling all SMS König class fans
- Maarten Sch�nfeld
Re: Calling all SMS K�nig class fans
There are only slight differences in the kit on the yardarms of the foremast.
Roger Whittaker +9/13/2023
William
Maarten,
Thank you!
Bill
Thank you!
Bill
- Atma
Hello guys Im building the Markgraf from ICM in 1/700 and the instruction suggest a small range fingfer on top of the Turret's roof number #4, I thought that this small range finder was only available/attached/used/etc by later war (1917 ? ). Shall I omitted it for an early war Konig class battleship ?
Thanks in advance.
Thanks in advance.
thebunkerparodie
thebunkerparodie
do I have to do a lot of modification in order to do a final preliminary project K�nig class from a 1/700 model?
The F sprue is the molded-in-red version of the propeller skegs: https://www.detailscaleview.com/2017/03 ... eview.html
