Carrier Builders Yard, whats on the Slipway
- gtbred
some things to come in kidds corner. only SUPERSIZE!
- Hippy Ed
gtbred wrote:some things to come in kidds corner. only SUPERSIZE!![]()
You've lost everything...
On the Bench:
On the Bench:
- kidcurrie42
One Airwing i need to finish at some point
Hopefully a CV-4 and CV-6 update in the next day or so.
Happy Modeling
John
Happy Modeling
John
Si Vis Pacem, Para Bellum
- Hippy Ed
kidcurrie42 wrote:One Airwing i need to finish at some point![]()
Happy Modeling
John
Hiya John!
On the Bench:
On the Bench:
- gtbred
now i wish i never slod my Jin Shirly Midway or BigO. OHH well.
- gtbred
this would make a nice dio. if you had the room.
NukeMM
- Back-Aft Models
Finally, I have a model to contribute to this thread. I hope no one minds that it's an LPH.
I've started the 1/700 DRAGON USS Boxer LPH-4 as part of my ongoing 1/700 Post War One of Each Class colleciton. I'm dip a toe into the aircraft carriers with this former Essex class CV.
I have a question for anyone who has built a DRAGON Essex class similar to this kit and who might have came across this obstacle in their build. This area on the port bow / flight deck edge is confusing me.
I have assembled all of the conjoining / adjacent parts around the piece marked with the black dot according to the instructions and according to the guiding edges within on the hangar deck piece. And yet, they still don't line up right at this point and the outboard piece (with the doors in it) still protrudes out from under the flight deck.
This is still a dry-fit but it obvious that even when the flight deck is permanently attached the piece with the black dot will not look right.
Here, with the flight deck removed, you'll see the gap between the two parts with black dots on them. It looks like these two parts should touch and be glued together but, this would end up with the outboard piece bending/curving inboard.
Without close-up pics of this area on the Boxer, I wonder if I can get away with leaving it this way and placing a scratch built piece of styrene (horizontally) and replicate a piece of catwalk, here.
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
Photobucket
YouTube Channel:
- Gordon Bjorklund
Carl,
That is a basic problem with building 1/700 Dragon Essex Class Carriers. I fixed those problems with plastic strip. I filled the horizontal problems by putting plastic strip in the hole to raise the deck level. I put plastic in the vertical gap to fill that hole and then sanded th bulkhead to conform the the cutout on the flight deck. Do you need to fill in (remove) the cutout for you Lhp?
viewtopic.php?f=46&t=4802&start=240#p94676
You can see some of what I did in this picture of my Lexington build.
Here is another set of pictrues of my Intrepid build.
viewtopic.php?f=60&t=35634#p222664
Gordon
NukeMM
- Back-Aft Models
Excellent solution, Gordon! Thank you!Gordon Bjorklund wrote:Carl,
I wonder if I would have come up with that solution on my own? Probably not, no matter how long I stared at it.
I didn't quite understand your question, "Do you need to fill in (remove) the cutout for you Lhp? "
Nice Lex, by the way! But, I didn't see the finished model in the MWS Gallery.
Carl Musselman
Photobucket
YouTube Channel:
Photobucket
YouTube Channel:
- Gordon Bjorklund
Carl,
I'm refering to the cutout on the flight deck above the 40mm mount. I added somemore pictures of my last post that shows the fix in more detail for the problem.
I think that you would have come up with a solution for that problem.
My Lexington is not in the gallery yet but I have sent in pictures of the completed model.
Gordon
NukeMM
- Back-Aft Models
Oh. I think I understand, now. And that is a good question. And now I'm afraid that the answer is, "Yes."Gordon Bjorklund wrote:Carl,
From the photos that I do have, I now see that the old 40mm tub is removed and that "cutout" isn't there. The edge of the flight deck is straight / flush at that point.
So, maybe the easier fix for my initial question will be to fill in (remove) that "cutout". However, I really don't feel like removing that 40mm tub. The kit's instructions show no guns mount in any of the gun tubs / sponsons, anywhere. So, I was planning on leaving this tub empty, anway. But, I may leave it there.
I hadn't planned on making this build a major modification for anatomical accuracy as I have on so, many other models. Especially since I haven't many close up pics of the Boxer. I was looking forward to a simple "as is" (not exactly OOB") model build.
Thanks again, Gordon! Wish me luck!
Carl Musselman
Photobucket
YouTube Channel:
Photobucket
YouTube Channel:
- kidcurrie42
Hello Carl,
I am looking forward to seeing your progress, that area is the main bugbear with the dragon kit, less so with the flightdeck that has no cut out, at least your hull seems to be warp free, are you going to use the Starfighter decals, the kit decals lack any helo landing zone markings, which would be in my opinion the focal area of the LPH.
Happy Modeling
John
Happy Modeling
John
NukeMM
- Back-Aft Models
Hi, John!kidcurrie42 wrote:Hello Carl,
Happy Modeling
John
This is my first carrier since completing my USS Monterey CVL-26 (DML) two years ago. The purpose of that kit was to freshen up my modeling skills which had been rust for many years, and to see what tools and supplies I was going to need to get in order to build the Fleetnet Commencement Bay kit into my Dad's USS Mindoro CVE-120 and then my Dad's USS Duxbury Bay AVP-38 in 1/350.
I "did" get the Starfighter decals. The ones for 1960-65.
At first I thought it would be cool to detail the hangar deck and open many of the roll-up doors, but have since decided against that. I'm closing up the doors.
I have the Waveline USS Iwo Jima LPH-2 kit, too. Starfighter has 1/600 decals for that and I asked Mark about 1/700 decals. He may get to some of those, for the Iwo Jima, in a couple of years. Worth the wait, I'm sure.
Any recommendations on the flight deck color for the Boxer in the early 1960's? I'd like to use a medium blue and use dark pastel chalks to weather the deck a little.
I have made the modification to this area in question and I've decided to leave the "cutout" or notch in the flight deck.
Carl Musselman
Photobucket
YouTube Channel:
Photobucket
YouTube Channel:
- kidcurrie42
Here is a great color pic of USS Princeton LPH-5, 1968 with the deck markings that you have i think, pic is from Navsource
Happy Modeling
John
Happy Modeling
John
- gtbred
anybody knows the escorts of Sara's Nam deployment in 72"? Ironshipwrights has some nice ca,ddg,dd on thier website.
- kidcurrie42
Here is Ranger and Enterprise, Ranger in process of having 5-H, 5-O and Black added to her coat of 5-P, Enterprise awaits her 5-H and 5-N over her 5-P.
Happy Modeling
John
Happy Modeling
John
NukeMM
- Back-Aft Models
Coming right along, John! Do you airbrush or hand brush your hull colors? Looks like you're using White Ensign colours and I've assumed that they're more friendly for airbrushing than for hand brushing. I've only used their Spar Yellow and hand brushed a USCG vessel so my experience isn't very, much with WE paints. (By the way, your paint bottles are upside-down
Here is my progress on the BOXER and the Starfighter decals. MAN! Carriers have a lot of decals that are more of a pain than DDs and CA/CGs.
I owe you one for the guidance on that bulkhead alignment problem, Gordan.
I've had some trouble with the circle and elevator decals silvering even after applying Solvaset. I'm not accustomed to such large areas of clear decal film like these. I've had to apply clear coats between layered decal application and pigment weathering. I've gone over the bow circle decals with deck paint and pigments to eliminate the silvering and to match the finishes.
I ended up using Navy Blue 5-N for the deck and the black and olive drab pastel chalks to dull the decals and weather / darken the 5-N. I used Neutral Gray for the hull and applied rust pigments hear and there with a black wash on the details. The flight deck isn't attached, yet, and I'm still working on the island. (There's a bit of a hump in the middle of the flight deck so the white line down the middle looks crooked from this angle.)
I don't know how DML gets away with calling this the USS BOXER, specificaly. For any time frame. Maybe they think its just the decals that make it the BOXER.
Even with the very, few clear pics that I have (and thanks for the Princeton pic, John) I can tell the kit doesn't match the real thing. The instructions tell you to fill in the holes where the 20mm guns would have been but they don't tell you to cut off (or give optional parts for) the gun director tubs. I'm leaving the gun director tubs. I didn't notice this until I'd assembled and painted those parts.
Hopefully the final paint and finish will distract the onlooker from the anatomical inconsistancies.
Carl Musselman
Photobucket
YouTube Channel:
Photobucket
YouTube Channel:
Carl,
Are you cutting the Starfighter decals as close as possible to the decal? That should help. Also, try this - when the decal is laid down and you've blotted out the excess water, brush on some of the red stuff from MicroSol, then use a hair dry (on low!) on the decals. This will melt the glue and help them snuggle down into the engraved lines in the deck.
NukeMM
- Back-Aft Models
Martin,MartinJQuinn wrote:Carl,
Thanks for chiming in!
I cut the decals around the exterior perimeter very close to the decal image. But, the centers of the circles are still solid decal film. That's where the most silvering is occuring as well as in the center of the "X" on the elevators.
I'm not familiar with the "red stuff" from MicroSol. I'll have to look for some of that. Oh, wait! I do have clear liquid in red-labeled bottle by MicroSol as well as the MicroSet in the blue-labeled bottle. I've tried these on my USCGC Bering Straight and had a hard time with it and never tried it after that. As it turned out the Coast Guard striping decals were defective and/or very, brittle or old. I've always had good luck with the Solvaset. I now think that part of the problem is that there's air under these decals even though I've tried to rub out and press the water and air from under the decals.
I am now set in the mind frame of going back over these slivered areas with the deck paint (hand brush thinned Model Master acrylics). I've had satisfactory results with the circles that I have touched up, so far.
I'll keep the hair dryer trick in mind for future reference.
Carl Musselman
Photobucket
YouTube Channel:
Photobucket
YouTube Channel:
Carl,
Brush on the blue stuff
Lay your decal
Blot out the excess water
Brush on the red stuff
blot out your excess
zap with the hair dryer
brush on more red stuff, only lighter (skip the blotting)
zap with the hair dryer again
9 times out of 10, you'll avoid silvering with this method, but IF, and only IF, you have a good gloss base underneath for the decal to lay on. Most silvering is due to the improper application of a gloss barrier, IMO, outside of bad decals.
Good luck!
Lay your decal
Good luck!
