Carrier Builders Yard, whats on the Slipway
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
MartinJQuinn wrote:Carl,
Brush on the blue stuff
Lay your decal
Blot out the excess water
Brush on the red stuff
blot out your excess
zap with the hair dryer
brush on more red stuff, only lighter (skip the blotting)
zap with the hair dryer again
9 times out of 10, you'll avoid silvering with this method, but IF, and only IF, you have a good gloss base underneath for the decal to lay on. Most silvering is due to the improper application of a gloss barrier, IMO, outside of bad decals.
Good luck!
Thanks, again, Martin.
Now that you've laid out the entire method, I bet that my problem was a flat clear coat over the finish paint, instead of a glossy clear coat. I still had flat in my airbrush and used it, then the decals, and then later used glossy. So, maybe it was that initial flat clear coat messing up the decals from laying down correctly.
I'll remember all of this, next time. Its too, late to fix my BOXER decals, but I will touch the decal film silvering with paint.
Most gratefully yours,
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
Mark McKinnis
Post by Mark McKinnis »
Hi Carl,
One thing you can do for the decals is gloss coat your finished model before putting on the decals. They will sit right down and look perfect after you hit it with dull coat. If you use super glue for PE, be careful to apply the dull coat a little at a time. A heavy dose and the super glue will turn white and really make you angry!! :mad_1:
Trust me on this one. :Mad_6:
Your Boxer looks good though. :thumbs_up_1:
John, a job very well done as usuall. :thumbs_up_1:
I am on the road a lot these days so the shipyards have been idle.
Well done lads!
MM
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Mark McKinnis wrote:Hi Carl,
Well done lads!
MM
Mark,
I hadn't heard of that problem of super glue, PE, and flat coats. Thanks for that heads-up! Does this happen with acrylic flat clear coats? I use mostly acrylics paints. And the super glue on my PE must be covered by paint, already, before a flat coat goes on. I haven't seen that effect. Yet.........cross my fingers.
I don't want everybody to think that I'm a first-timer with decals. I know about the smooth gloss coat step before applying the decals. This has worked for me, so far, and after about 18 ship models in two and a half years, this is the worst trouble I have had with silvering and bubbles and the decal not recessing down in the groves. I have always been satisfied with the job that my Solvaset does.
This being only my third carrier (USS Mindoro and USS Montery were the other two) I think this flight deck has deeper grooves than the other two and I accidentally applied an acrylic flat coat right after the acrylic paint, instead of a glossy coat. I imagine that its the rougher texture of the flat coat that is causing my decal problems, this time.
I'm going to concentrate on using the MicroSol and MicroSet on future models instead of my old, old bottle of Solvaset.
This one is no contest winner (or even a contest entry) but it will fill a spot in my intended collection.
You guys are great!
Carl Musselman
Photobucket
YouTube Channel:
kidcurrie42
Post by kidcurrie42 »
Thanks Guys, Mark, be safe out there :thumbs_up_1: .
The way i deal with any air bubbles and silvering, once decals have had a good drying time and prior to applying matt coat, any silvering/air bubbles are pricked with a very fine needle, liberal coat of decal solution, ease out the air bubbles, i have also had success with this after a matt coat has been applied.,
Touching up was a constant task on carriers, also i am sure you can work it into your weathering Carl. Yes it was a case of add decals, helo's and rename. I have all three LPH hulls in early stage of assembly, all three had differences which is good.
I look forward to future updates Carl
Happy Modeling
John
Si Vis Pacem, Para Bellum
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Well............
My flight deck is done and attached. The island, railings, gun turrets, and anchors remain as well as painting the boot top. I've gotten pretty good at painting the boot tops with a Testors gloss black paint pen. I get lucky most of the time. I find that the gloss works best (with a flat coat applied afterwards) because it slides along the model smoother than a flat paint pen. Oh! And I can't forget the helos.
Carl Musselman
Photobucket
YouTube Channel:
kidcurrie42
Looks great Carl :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: i use black decal stripe normally for the boot Topping.
Happy Modeling
John
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
kidcurrie42 wrote:Looks great Carl :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: i use black decal stripe normally for the boot Topping.
Happy Modeling
John
Thank you, John. But, I pictured a better job before I started it. I've done better work. I'm labeling this one as "A Lesson Learned".
I have some Scale-Master decal stripes that a friend gave to me, but not enough of the right width of stripe to use on this larger model. I may try to cut wider stipes to the correct width.
What stripe decals do you use (brand?) and where do you get them? Online?
Carl Musselman
Photobucket
YouTube Channel:
kidcurrie42
Looks great Carl :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
I normally use black decal stripe for the boot topping.
Happy Modeling
John
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
John,
Thanks for the tip on the decal stripes for the boot top. It worked on the Boxer, pretty well. I had 1.5" solid black decal stripe from Scale-Master and I cut 1/8" stips from it. They weren't long enough in order to use one strip per side, but I butted the ends together of separate strips. My problem was that each strip wasn't exactly the same width so, I just made sure that the top edge was straight and true and then painted the exposed gray beneath the too, narrow decal strips. Any unsightly areas will be hidden by the water base.
Also, I noticed that one of your posts was dublicated, here. I'm wondering what happened, there.
On another note, Gentleman, I'm wanting some help identifying these radars. Especially the one in this first picture on the right side of the mast / port side of the ship. The starboard / lower radar appears to be an SPS-8.
And is that an SPS-10 above the SPS-8? It looks a little large for an SPS-10.
The instructions show a large dish array (SK-2 ?) adjacent to the stack and outboard starboard. I don't see this at all in any pics of the Boxer, Princeton, or Valley Forge LPHs. I'll be omitting this one, I think.
In the future, I'll be looking for some 1/700 deck equipment like the 1960's era tractors and a Tilly. There were some nice deck tractors in the DML USS Independence CVL-22 Premium Edition kit that I built.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
A little wash effect on the island and some railings added. I've a lot more railings to go around the catwalks, flight deck around the island, and on the island.
There's the decal stripe boot top...
I'm also preparing the water base, as well.
Carl Musselman
Photobucket
YouTube Channel:
Cliffy B
Post by Cliffy B »
NukeMM wrote:On another note, Gentleman, I'm wanting some help identifying these radars. Especially the one in this first picture on the right side of the mast / port side of the ship. The starboard / lower radar appears to be an SPS-8.
http://i264.photobucket.com/albums/ii19 ... R19644.jpg
http://i264.photobucket.com/albums/ii19 ... R19648.jpg
Nuke I found the radars! The one on the outrigger to starboard is SPS-8A, above that is SPS-6B, above that on the backside of the mast is the little SPS-10, and the big radar on the back of the mast is a SPN-6 landing radar. URN-20 TACAN rounds out the mast top.
Hope that helps.
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Hey, Cliffy!
Thanks for researching this for me! I have GMM PE with SPS-8 on it as well as the SPS-10 that should work. The same PE fret has an SPS-6, but is this the same in appearance to the SPS-6B? I don't see any "arm" on this in the pics, but the GMM SPS-6 has one.
I don't see the SPN-6 that you mentioned in the pics, here. I'm really not sure what I'm supposed to be looking for. "Back of the mast"?
____________________________________________________________________________________
Editiing my previous comments, above..............
Oh! Nevermind! I see, now.
From bottom to top..........SPS-8......SPN-6.......SPS-6B.........SPS-10 way up near the top (I hadn't seen this and thought the SPS-6 was a "big" SPS-10)
So, I think I've got everything except an SPN-6. I'll have to see what I can do to replicate one of these. Any suggestions? An SPN-6 doesn't seem, to me, as a popular item in aftermarket parts.
Carl Musselman
Photobucket
YouTube Channel:
Cliffy B
Post by Cliffy B »
Sorry, I was looking at the bottom picture and its hard to tell what side of the mast they're on. For clarity, the top picture has two radars; SPS-8A on the left and SPN-6 on the right. If you need a SPN-6 GMMs 1/700-1/720 Super Carrier PE set has ONE on it.
As far as the SPS-6 goes, I thought the actual antennae was pretty much the same throughout the series with only the "guts" being swapped out in each successive upgrade. SPS-6B and C were the most common IIRC. Not sure though but I doubt the differences are all that noticeable in 1/700.
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Cliffy B wrote:Sorry, I was looking at the bottom picture and its hard to tell what side of the mast they're on. For clarity, the top picture has two radars; SPS-8A on the left and SPN-6 on the right. If you need a SPN-6 GMMs 1/700-1/720 Super Carrier PE set has ONE on it.
I think we're both clear on this, now, Cliffy. Thanks, so much!
I went Googling for SPN-6 and found a review of the GMM 1/700 1/720 Super Carrier PE that you just mentioned.
http://www.modelwarships.com/reviews/pe ... rrier.html
Short of buying the whole set, I may try to form one from PE mesh / netting.
The DML Boxer instructions show nothing, at all, mounted in the places of the SPN-6, SPS-6 and SPS-10 platforms and the instructions also are confused on the placement of the platform arms. Horrible kit and instructions.
Gratefully yours,
Carl Musselman
Photobucket
YouTube Channel:
kidcurrie42
Looking good Carl, The area that the kit lacks in IMHO is research, this happens all too much.
I had a great day at the Region 12 show in Spartanburg SC, picked up 7 awards, 2 x 3rd for my Warhammer entries,
A 3rd for my Saratoga, and 1st for Langley, a 2nd for SNS Dedalo and 1st for Lexington in the Conversion/Scratchbuild Catagory, Langley picked up Best ship award :woo_hoo: :woo_hoo: :woo_hoo:
Happy Modeling
John
Hippy Ed
Post by Hippy Ed »
kidcurrie42 wrote:Looking good Carl, The area that the kit lacks in IMHO is research, this happens all too much.
Happy Modeling
John
WTG John!! :thumbs_up_1: :thumbs_up_1: :woo_hoo:
And Carl, she's coming along nicely
You've lost everything...
On the Bench:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Congratulations, John!
It sounds like it was a wonderful day, for you! The Langley is super impressive!
:good_job: :thumbs_up_1: :thumbs_up_1:
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Thanks for the kind words, Hippy!
Here is my rendition of the Boxer's mast. Some kit parts, brass rod, and GMM radars. I scratch built the SPN-6 out of some PE mesh/netting from a GMM fret.
Carl Musselman
Photobucket
YouTube Channel:
Cliffy B
Post by Cliffy B »
NICE!!!!!
Only thing I see is the SPN-6 needs a little feed horn of sorts. Other than that its looks great man :thumbs_up_1:
Hippy Ed
Post by Hippy Ed »
Yer welcome Carl :big_grin: That SPN-6 looks good. Wish my skills were that good. :thumbs_up_1:
I know, all in due time :whistle:
On the Bench:
