Postwar navy.
Bob J
Re: Postwar navy.
Post by Bob J »
Hey guys,
I'm putting out a request to all you USN carrier builders. I was putting the final touches on my Truman before I started the airwing and tragedy struck. The tape I was using pulled off both island numbers. I built the ship from another so I dont even have the Italeri decals. I really dont want to buy another Starfigher ship set for just for the two numbers. Do any of you have the two island "75"? I'll gladly pay postage.
Bob Justice
Nektarios
Re: Postwar navy.
Post by Nektarios »
Bob J wrote:Hey guys,
Bob Justice
Bob i think i can help you with that. Send me a PM with you mailing address and i ll send you the decals. :wave_1:
On the workbench:
Various 1/700 aircraft.
Juan Carlos I LHD 1/700.
HMAS Canbera LHD 1/700.
FGS Type 122 class FFG 1/700.
LSD-41 class LPD 1/700.
Sauragnmon
Re: Postwar navy.
Post by Sauragnmon »
I've been working on my Republic of Japan Destroyers, the Shirane and Sawakaze, and I've come to the conclusion - the ROJN concept has posessed me in some ways. It started with the concept of doing my own VLS fitting from sheet "tile" styrene, then new gun turrets upgraded from the Shielded 5"/50 turrets with more bulk and new gun barrels, and now these two have gone Frankenstein. I'd already started the concept of using the old Shielded 25mm mountings as the basis for a CIWS mounting, but a couple days back I finally got the CIWS done - I took the gun mounts, and made them completely, then took off the gun barrels. I followed this up by taking a Phalanx, and carving away the stand, the bracket, the drum, so I had the gun barrel, with a slight extension, and the radar dome. I then seperated the two, and fitted the gun barrel with extension on the original gun mounting, and put the dome on the back of the turret top. Looks pretty good, I think, and would logically have a larger ammo capacity than the Phalanx mounting. Then, I got to the electronics. The directors you might recognize from Skywave/Dragon Type 42's - apparently, according to Kidcurrie, who served on the T42, the domeless 909's in the kit look Nothing like true 909's, so I figured I'd borrow them for my own Japanese SPG radars. Then I noticed they both had planar array radars, and when the Shirane had a STIR ball on its aft mast, I thought "you know what, I know something better, let's go for an NTU style suite!" and added the SPS radar seen here - I'm guessing the dish was off an SPS-49, as I jacked one from a DML FFG61, but the base is off an SPS-6 from the Pitroad E6 - I don't know I have anything I'd use SPS-6 on anyways, so it works out. Combine that to the planar array, and we have the 2d/3d radar combination similar to NTU. Chop a couple of Mk42 barrels off the mountings, fit them on the front of the bridge, they'll pass for SYS-2 antennae when painted right. Sawakaze got an extra pair of directors, as she had a second director tower fork. I chopped down the original forward position, until I could fit the director section over it, puttied a chunk so it had full solidity, and that was that. Of course, I had to raise the array a little so it would have view over the director, technically, but hey. Pics!
As always - questions, comments, queries and rude remarks are more than welcome, if not outright invited.
GTDEATH13
Re: Postwar navy.
Post by GTDEATH13 »
sweeeeeeeeeeeeeeeeeeeeeeeeeeet... :thumbs_up_1: :thumbs_up_1:
NIKOS (NICK)
orb
Re: Postwar navy.
Post by orb »
That is one massive upgrade. The helo deck was definitely predestined for those VLS cells. Very nice work as always :thumbs_up_1:
Image Heiko S. | MY SHIPYARD | Under construction: JDS Takanami (Takanami Class Destroyer)
Sauragnmon
Re: Postwar navy.
Thanks, guys. The Sawakaze's primary mission being AAW, the loading of that much VLS was thusly important, as was the extra illuminators. Shirane has 90 cells, while Sawakaze hosts some 54 forward, 94 aft, totalling 148 cells VLS, with 24" torpedo launchers and the new 5" and 25mm guns. I still haven't added the markings on the flight areas yet, but I plan on it. Though admittedly, Sawakaze's is for replenishment or other situations more than anything.
I honestly don't know what posessed me with the ROJN ships, as the work's gotten so deeply inspired and intricate.
GTDEATH13
Re: Postwar navy.
Post by GTDEATH13 »
Here is my contribution to this topic:
1/700 HS Formion DDG-220, ex DDG-16 USS Joseph Strauss in late 1998..
The build is nearly finished, just the props, rigging (any help with that would be extremely appreciated) and a dull coat. I am not going to give it a wash.
The kit is Dragon's premium edition Cf Adams kit, with lovely details. I built it in only four days. The pe is that of the kit, plus some GMM rails. I did not use the pe for the radars because I want to use it in another kit..
Any comments, suggestions and remarks are welcome.
P.S. In case anyone wonders about the colour of the decks, the Greek Navy started using dark grey for the decks after 2001, up to then deck painting depended on the captain and the type of ship.
NIKOS (NICK)
Sauragnmon
Re: Postwar navy.
I gotta say, I think the ship with that styling on the deck looks funky and cool. The black adds to the styling around it, and makes it quite sharp.
orb
Re: Postwar navy.
Post by orb »
Hi Nikos, very nice HS Formion! I also like the deck colors - definitely stands out from all the other uniform navies, too bad they changed that.
kidcurrie42
Re: Postwar navy.
Post by kidcurrie42 »
Very nice builds guys :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Happy Modeling
John
Si Vis Pacem, Para Bellum
GTDEATH13
Re: Postwar navy.
Post by GTDEATH13 »
Thanks guys for the nice comments. The black areas of the deck are:
Forward gun: thick rubber mats with round holes ( I do not know how they are called, we call them ubo(not a greek word) mats)
ASROC launcher: special deck covering, a rubber like substance for protecting the deck from the rocket fuel and high temperature
Aft gun: same as forward gun
Vertrep and hoist area: anti-skid
Tartar launcher: same as ASROC launcher
Aft vertrep area (later replaved by depth charge racks): anti skid
The whole ship was painted with acrylic spray, then I painted the hull with humbrol enamel and the black areas are painted with 0.1 mm rapidograph. The rest of the colours are permanent markers.
What should I use for rigging??
NIKOS (NICK)
orb
Re: Postwar navy.
Post by orb »
GTDEATH13 wrote:What should I use for rigging??
I think the most common way to rig a ship in 1/700 is still stretched sprue. There may be other ways such as using ultra thin threads, but I doubt that you will be able to get them as fine and thin as stretched sprue. There is a great tutorial by Jim Baumann on this subject in the Tips and Tricks section of the forum.
orb
Re: Postwar navy.
Post by orb »
Hi guys,
I thought I'd share some photos of my current project with you guys. I've started almost 5 months ago but haven't gotten very far yet since I was on the road for a bit, but for the past few weeks I've been back at it and finally have some progress.
Starting with the 5th Wasp class ship, there have been some major modifications to the layout of the island. Unfortunately, the only model kits of this class in 1/700 on the market only let you build LHD 1-4. Therefore, some scratchbuilding was necessary. This included not just the island itself but also the masts:
(SPS-48 missing)
(incomplete)
As for the island itself, there were also quite a few changes. Especially changing the layout of all windows was time-consuming.
All the remaining details, missing antennas, railings etc. will be added later.
:wave_1:
Dave Rowe
Re: Postwar navy.
Post by Dave Rowe »
Great work orb, can't believe that's 1/700 :thumbs_up_1:
NukeMM
Back-Aft Models
Back-Aft Models
Re: Postwar navy.
Post by NukeMM »
That's awesome, Heiko! Very nicely done and very ambitious! Its going to look great!
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
Sauragnmon
Re: Postwar navy.
I can only imagine what she'll look like with your usual grade of detailing on her, Heiko. The Wasp will be quite an interesting finished product for sure.
Nektarios
Re: Postwar navy.
Post by Nektarios »
GTDEATH13 wrote:Here is my contribution to this topic:
Really nice build there Nikos. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
I think you re getting the 1/700 virus. When we ll meet (whenever that is) i ll give you an extra SPS-40 to put on your Formion.
On the workbench:
Nektarios
Re: Postwar navy.
Post by Nektarios »
orb wrote:Hi guys,
:wave_1:
Heiko, if you continue to build models of that quality i ll be ashamed to show mine. Good work so far :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
On the workbench:
orb
Re: Postwar navy.
Post by orb »
Thank you for all the kind comments guys :wave_1:
GTDEATH13
Re: Postwar navy.
Post by GTDEATH13 »
orb wrote:Hi guys,
:wave_1:
Man, this superdetailing in 1/700 is really superb... But I would shoot myself in the head if it ever crossed my mind to do this thing... :big_grin: :big_grin: :wave_1: :wave_1:
NIKOS (NICK)
