Also another update on my part. After finishing major work on the island, I've started working on the hull and finished building various platforms and replacing all plastic ladders with PE ones. Also started working on the catwalks and adding railings and braces.
Heiko S. |MY SHIPYARD| Under construction: JDS Takanami (Takanami Class Destroyer)
I can appreciate your efforts on these tiny, but significant, details. Your work reminds me of all of the details and modifications that I did on my second USS Iowa.
Nektarios wrote:
John, you have added all the extra electronics and radomes in order to show the ship sometime after 2000. Great job. Can t wait to see more.
This will be the AFG 3 USS LaSalle, Next will be to add the decals and some more PE. I added the extra deck from a Austin kit and as you pointed out added all the extra domes and electronics. I also needed to update the crane and mast.
The next question is what to make out of the Austin kit. LPD 4 USS Austin; LPD 14 USS Trenton or LPH 15 USS Ponce. I am leaning toward the Ponce found a pic with a bumch of AH-1 on deck and I have a some of WEM versions buning a hole in my pocket .
John
John,
Beautiful Job!! I have a bit of an interest in the LaSalle since it was the command ship that took over for the three little Seaplane Tenders (AVPs) that served as flagships for Commander Middle East Forces. Am I correct?
My father served on the USS Duxbury Bay AVP-38 and the other two ships were USS Greenwich Bay AVP-41 and USS Valcour AVP-55. Was the LaSalle painted white at any time? I think she was. The AVPs were painted white to reflect the suns heat while cruising around the Med, Red Sea, and Persian Gulf.
I'm anxious to see some finished and close up pics!
I did not know she took over for the three little Seaplane Tenders. As for being painted white she was known as "The Great White Ghost of the Arabian Coast" so you are absolutely correct. I am not sure why she was painted white, somehow in the back of my mind I thought it had something to do with the history of the Great White Fleet. I am sure someone knows the full story. It has been a fun build so far. I will keep posting pictures.
John
The white was pure and simply for heat reflecting purposes, same reason you find the Ammo lockers on US ships are white, air conditioning in older ships was pretty poor.
J Goodacre wrote:Thank you all for the kind words, I finished the flight deck and the stern decaling. I am happy with it the stern is not as clean as I was hoping but it will work . Next will be to add the PE and the rigging. Then off to the USS Austin.
It looks really nice John. I had the exact same difficulty with La Salle's stern. Good luck with your next build
On the workbench:
Various 1/700 aircraft.
Juan Carlos I LHD 1/700.
HMAS Canbera LHD 1/700.
FGS Type 122 class FFG 1/700.
LSD-41 class LPD 1/700.
orb wrote:Also another update on my part. After finishing major work on the island, I've started working on the hull and finished building various platforms and replacing all plastic ladders with PE ones. Also started working on the catwalks and adding railings and braces.
Once more a great update Heiko.
On the workbench:
GTDEATH13 wrote:All I need now is a Greek flag and a nameplate at the base to call this build a completed one...
As always, any comments, rude remarks and suggestions are more than welcome...
Nice build Nikos. Considering the fact that this is you first waterline diorama it looks very
good.
I see you ve caught the divine scale virus which makes me very happy.
On the workbench:
Here is some more pictures of the AFG3 LaSalle. I am finished for now. My problem is that I do not know how I want to fill the flight deck. SHould I add SH60's, CH64 or H53's. I can leave it empty as well. Any comments are welcome. Hope everyone has a Happy Thanksgiving - John
good.
Divine what? There is nothing divine in this scale except the pain in my eyes...
If there was a plastic 1/350 scale C.F. Adams available I would never have set hands on those miniatures...
Well, except the Kirovs, the Iowas and the Montana I am building...
I am going to build a second one as HS Kimon, DDG 18
I already have a nameplate for that project...
NIKOS (NICK)
