Carrier Builders Yard, whats on the Slipway
gtbred
Post by gtbred »
Gulf War era 1990-1991. don't have a Supercarrier with Tomcats.
potchip
Post by potchip »
Weekend progress. (dropped a few times already, surely exceeded my drop quota?) Hoping to finish by the end of this week. :woo_hoo:
Mark McKinnis
Post by Mark McKinnis »
Hi Potchip,
That is a really nice build! :thumbs_up_1:
kidcurrie42
Post by kidcurrie42 »
Wow, Looking really very good there, great paint job. Really looking forward to seeing more as she progresses.
Happy Modeling
John
Si Vis Pacem, Para Bellum
gtbred
Post by gtbred »
Connie has been put on hold again. i have been ask to do another 1/350 Oriskany 1969. that makes three BigO's that i have done. there have been other 27C's in Nam besides BigO.
kidcurrie42
Ooh Sounds like a good future group build idea :thumbs_up_1: :big_grin:
Ok CV-34 as gtb stated saw service in the Vietnam war, the following Essex class also saw service during that war as Angled deck Essex class.
CV-10, CV-11, CV-12, CV-14, CV-19, CV-20, CV-31, CV-33 and CV-38 also seeing service in the unconverted state were LPH-4(CV-21), LPH-5(CV-37) and LPH-8(CV-45).
Many of these saw service in three wars, others saw service in Korea and Vietnam. What service these beautiful Carriers gave.
Happy Modeling
John
gtbred
Post by gtbred »
CVA-34 nearest the bottom,CVA-19 is next. gonna redo Hornet. Sara just needs water. Image
Mark McKinnis
kidcurrie42 wrote:Ooh Sounds like a good future group build idea :thumbs_up_1: :big_grin:
Happy Modeling
John
Which really makes me wonder why we do not have 1/700 and 1/350 scale plastic kits of these ships in the SCB-125 form??????
kidcurrie42
Same here Mark, i just hope that some company will see the selling potential, yes there where differences between members of the class, but none that cannot be easily worked into a properly planned kit, take for example Hasegawa, different bow sections for long and short hulled variants, same thing could be implemented for the various hurricane bows, Trumpeter has the solution to the different arrangement of flightdeck edge lift positions, the Trumpeter hangar deck bulkheads are separate from the hull, unlike dragon's hull arrangement, therefore with a little tooling, these could be molded in different versions on frets as required for whatever carrier is being released.
Research? USS Yorktown, Intrepid, Hornet and Lexington are all still floating, not like a diving suit is required.
But i would be equally happy with one nearly accurate release and make my own changes, i am sure many of you guys out there would be satisfied with that.
I hope that Mark at Starfighter has great success with his Renwal 1/500 release of an Angled deck Essex class. i for one will be buying some.
I hope the other companies watch and take note and give us this sorely missed subject i 1/700 and 1/350.
Happy Modeling
John
gtbred
Post by gtbred »
Hans did this with a Essex 1/350 from Trumpeter. Image Image
kidcurrie42
Yes i have saved all the pics i can find of Hans stunning build, Bon Homme Richard is a favorite of mine and definetely one i would build as an Angled deck, has Hans ever posted pics of her completed with aircraft?
Happy Modeling
John
gtbred
Post by gtbred »
he was on the other website asking somebody to work on his aircraft. don't know if he got anyone to do it. if you got any more photos of his build please post.
JevJanson
Post by JevJanson »
Excellent builds everyone! I wish I was that good... I am quite new to model building, only building ships for about 2 years. I have completed the Revell 1/720 Enterprise and Italeri 1/720 Nimitz(Well, sorta...) I need to repaint the deck of Enterprise, and paint the Nimitz. I hope you could give me some pointers on how to make the models from good to excellent. My main downside to painting is that I have a very unsteady hand, so I messed up the deck lines on Enterprise. All help is appreciated.
Greetings from Montana!
Ryon Olson
kidcurrie42
Hello Jev and Welcome aboard,
Ok, when you say that you have unsteady hands, do you mean when painting or applying decals?
If you decide on painting the deck markings, use a good tape to enable a good clean straight line, ensure it is rubbed down to avoid seepage, a good way to avod seepage is, once the tape is down, apply a light coat of the deck color, this will help avoid seepage, paint the lighter colors first when doing the Red/White and Yellow/White lines, do not leave tape on for excessive amount of time, this may cause more work if it lifts your paint off.
Decals, ensure that the deck or surface to have decals is glossed, either with clear or gloss varnish. i like to have a good bit of water on the surface, makes it easier to move my decals around, once in place i soak up water with a tissue/napkin.
Landing area, apply one white side marking, ensure it is straight, i always look down from above to achieve this. apply second side decal, keep it wet, i use a small metal ruler and ensure that the distance is the same all the way down between the white inner edges. now measure and find the mid point between the two white lines, this is where the yellow and white center line will go, again use the ruler and ensure it is correctly centered all the way down. now you can use your decal solution if you choose to do so. or when dry, check for any possible air bubbles as these need removing before sealing decals, this should avoid any silvering.
They are my own ways of doing my decks, others may have more and better advice.
Most of all, Just Enjoy this Great Hobby.
Happy Modeling
John
jgrease
Post by jgrease »
Ok guys, I am actually really working on a carrier. My wife got me the Dragon CVL-22 for Christmas, and I am gonna get it built for a contest on April 2. I am working with the box contents, and will probably add some Trumpeter planes I have on hand, along with some additional PE from the Tom's Modelworks Essex set that I have left over. Here's a couple of pics to show where I am:
I've got the sides of the superstructure attached, along with the catwalks on the exterior. I am modeling her as she appeared in 1944, dazzle camo and all. The detail on the hangar deck is incredible.
I've finished the four stacks as of last night. Some of the smaller thin parts are a little fiddly, but I am happy with the results. The directions were a little vague in spots so far, but I am adapting. So far the only putty was along the join of the sides and the hull, and some putty where the stacks and supports meet. Nothing really bad. I will post more as I make progress.
John
kidcurrie42
Hiya JG, A great start on your CVL, those stacks look really detailed, Well done :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: i am looking forward to seeing more as you progress, i have a 1/700 CVL that i won in a raffle, it may end up as one of the units loaned to France after WW2, will join my Spanish Dedalo.
Happy Modeling
John
Hippy Ed
Post by Hippy Ed »
JG workin' on a carrier?!?! :big_eyes: :faint: :whistle: :thumbs_up_1: Great!!!
You've lost everything...
On the Bench:
JevJanson
Post by JevJanson »
To clear up things first, it is when I am painting that I have the problems. I just noticed that the decals that come with Nimitz include the deck lines, and I thought I could run off a copy on a blank decal sheet to get that fixed. My original plan was to add an extra coat of paint to the deck, to remove the old lines. I found an easy way to give it a weathered look was to take a napkin and wipe the surface about a minute after applying, allowing the majority of it to stay, but it made streak marks on it. I'm going for an effect as if the ship hasn't been to a repair station in about 5 years. It is part of my what-if story I am writing. I'll post pictures once I get the ship repainted and the new decals applied.
Ryon Olson
JevJanson
Post by JevJanson »
Also, I just thought of this:
I had a little problem with the paint guide of the Enterprise. It told me the entire lower hull is to be painted black, but only after building did I notice that it was supposed to be red. Now I have to start over and remove the lower hull to spray paint it. The pictures will be delayed for awhile, because of this.
Ryon Olson
jgrease
Post by jgrease »
Hippy Ed wrote:JG workin' on a carrier?!?! :big_eyes: :faint: :whistle: :thumbs_up_1: Great!!!
Thank you very much Ed and John. It's a really nice kit, which would have been a killer with clearer instructions! I look forward to working on the flight deck - many lessons learned from my Essex build. I will be posting more in the coming days.
