Calling all Nagato (長門) and Mutsu (陸奥) fans
Atma
Re: Calling all IJN Nagato class fans
Post by Atma »
The new 1/500 IJN Nagato by Fujimi with a complete PE set is out, hurry up !
http://www.1999.co.jp/eng/10144809
Enjoy.
Atma
Post by Atma »
By the way, the IJN Nagato with the PE sert from Fujimi in 1/500 it has brass barrels for the 40 cm main guns and the 14 cm secondary guns. :smallsmile:
And is limited release, so I repeat, hurry up !
Atma
Post by Atma »
1942 version of IJN Nagato from Aoshima is out btw.
http://www.1999.co.jp/eng/10139451
Like the latest IJN Nagato release by Aoshima it includes new AA guns, new molded parts for pagoda, funnel aft superstructure etc.
Atma
Post by Atma »
And finnaly some pictures(from Hobby Link Japan) of the complete PE set that comes with a limited edition of IJN Nagato in 1/500 by Fujimi:
http://www.hlj.com/product/FUJ61003
Enjoy !
JIM BAUMANN
Post by JIM BAUMANN »
Is there a projected arrival date for the Nagato 1924 ( bent funnel) in Europe ( UK !! ) yet...\/
Having worked myself up to attack the resin kit...
I am now eager to see the Injection version and perhaps combine the best of both kits for my model....?
restless!!
Jim Baumann
Atma
Post by Atma »
If everything goes fine with Aoshima, in Japan will be out or almost out by late September.
Atma
Post by Atma »
And Im talking about the 1920's IJN Nagato.
Atma
Post by Atma »
Here is the '20's IJN Nagato by Aoshima in 1/700:
And here's the page on which that was found: http://ameblo.jp/aoshima-kumablog/entry ... 95226.html
Atma
Post by Atma »
Anyone knows exactly what date the Aoshima's IJN Nagato represents ? I can see a catapult and I guess she has double 12,7 cm DP/AA guns ?
I think by her TROM that the date is early 1930's ?
"1932:
Four twin (4x2) dual purpose 5-inch (127-mm) HA guns are installed. The existing 3-inch (76-mm) AA guns are landed. Four 40-mm/62 Vickers AA guns (2 x 2) are also added to the weather deck.
25 February 1933:
Geneva, Switzerland. Japan withdraws from the League of Nations and decides she will no longer abide by restrictions such as the Washington of 1922 and the London Treaty of 1930 that impose limitations on the number and size of her warships.
Summer 1933:
A Kure Type No. 2 Model 3 catapult, collapsible crane and rails are installed between the mainmast and the No. 3 turret. "
Atma
Post by Atma »
A question from IJN Tosa and IJN Amagi class thread, IJN Nagato class when was original build, was equipped with 12 cm or 8 cm AA and how many ?
Thanks in advance.
Felix C
Post by Felix C »
Atma wrote:By the way, the IJN Nagato with the PE sert from Fujimi in 1/500 it has brass barrels for the 40 cm main guns and the 14 cm secondary guns. :smallsmile:
I do not see the barrels in the detailed photos for the link. Is that the correct link?
Does the PE that comes separately from Fujimi have the brass barrels. # 112763
Atma
Post by Atma »
The best IJN Nagato in the market at the moment, IJN Nagato deluxe edition by Fujimi in 1/500 includes the brass barels.
The seperate box of PE for the IJN Nagato in 1/700 by Fujimi dosnt have them.
Edit: To repeat my question, "a question from IJN Tosa and IJN Amagi class thread, IJN Nagato class when was original build, was equipped with 12 cm or 8 cm AA and how many ?"
Thanks in advance.
Felix C
Post by Felix C »
Thank you Atma,
Do you know the part number for the deluxe Nagato with the PE and barrels.
Atma
Post by Atma »
Felix C wrote:Thank you Atma,
The Item Code is FUJ610030 or you can just use the number 610030 1/500 series
Felix C
Post by Felix C »
ok. I am going to order it although I do not see where brass barrels are pictured or indicated in the text.
Do you have one yourself?
Atma
Post by Atma »
Felix C wrote: ok. I am going to order it although I do not see where brass barrels are pictured or indicated in the text.
Yes.
The IJN Nagato with the extra PE set in 1/500 is limited run though, so hurry up !
Felix C
Post by Felix C »
Atma,
Wish you to know I appreciate your help. I did write HLJ earlier to confirm about the barrels and they replied today saying that no barrels are included in FUJ61003 so I suppose it is no longer available.
I asked them to reconfirm.
Atma
Post by Atma »
If the 1/500 IJN Nagato deluxe is out of stock, the "normal" edition is still in stock, and you can buy the seperate PE set by Fujimi.
Hobby Search Japan has just restored their stock of IJN Nagato in 1/500 by Fujimi with a complete PE set.
You can order it from them.
Link:http://www.1999.co.jp/eng/10144809
If you are planning to buy/build a IJN Nagato the 1/500 IJN Nagato by Fujimi is at the moment the best in market(Like the 1/500 IJN Yamato by Fujimi aswell).
Felix C
Post by Felix C »
^^^True but then where to get the barrels?
