Calling all Udaloy-class (Фрегат-M) & Sovremennyy-class (сарыч) fans
Re: Calling all Udaloy & Sovremennyy class fans
An album of 40 photos of the Adm. Chabanenko taken by a Redditor some years ago: http://imgur.com/a/7MU4z#0
Haijun watcher
Post by Haijun watcher »
My local model store has the Zvezda Sovremenny class 1/700 kit, but was reluctant to buy it in place of just ordering the Dragon/Cyber Hobby 1/700 Fuzhou kit from Ebay if a conversion is not feasible.
I assume the Zvezda kit is closer to the first two Chinese PLA-N ships of the class, since the last 2 Sovremenny class in Chinese service had the 956EM mod. and thus a slightly different configuration.
maxim
Post by maxim »
The Dragon and Zvezda kits are probably exactly the same old Pit-Road kit - I would not expect differences except of the decals and perhaps some not very useful PE parts (for which better ones are available).
Sauragnmon
Post by Sauragnmon »
If the box can be believed, that Fuzhou kit is close to the 956EM, though I think they missed the fact that the aft turret is removed IIRC. Looking at the box image, it seems, however, to have the Kashtan systems that flank the helipad on the 956EM instead of the AK-630 systems. This is not hard to imagine, since Dragon also produces the Pyotr Velikiy kit, which has Kashtan systems in it.
Haijun watcher
Sauragnmon wrote:If the box can be believed, that Fuzhou kit is close to the 956EM, though I think they missed the fact that the aft turret is removed IIRC.
Umm...
Correction: Of the 4 ships in the class, Taizhou and Ningbo have the 956Em configuration without the aft AK-130 turret, while Fuzhou and Hangzhou are closer to the original Sovremenny configuration.
Therefore the Dragon Fuzhou kit is correct since the first 2 ships exported to China retained the aft turret.
redoctober27
Post by redoctober27 »
Any new russian kits to come out???
Koppalakki
Post by Koppalakki »
Hi guys I have a question I'm hoping you could help me with.
On Sovremenny class ships from about 2000 and onward there seem to be an extra black boot top stripe after the white one.
Am I correct to assume it does not go all the way down and there is actually antifouling red under there as shown on this kirov class drydock picture?
I've not found any pictures of the sovremennys on drydock past 2000 and you can't really see where it ends though some pictures do suggest there's red under it.
http://navsource.narod.ru/photos/03/486/03486083.jpg
Also if you know the purpose of this addition please do tell.
Neptune
Post by Neptune »
Yes you are right in your assumption. That is also why it's called boot topping and not anti-fouling. Normally it's around 1m, for US ships they have a certain regulation about it, like light loaded waterline + xx feet or something like that. Tracy White posted it somewhere on the board.
As for Russian ships, not sure what their regulation is. It's also unclear whether that is a real boot topping or not. The primer below anti-fouling paint is also black, so it might actually be a saving in anti-fouling paint rather than adding more paint.
The other explanation would be that this paint has different characteristics as to abbrasion from wave action or is more sleek since that is the part that is generally open to the surface wave action, where anti-fouling red is more or less always submerged and has a regular friction with the water. Not sure if Russian practice really follows US practice in this matter.
One thing is sure, the anti-fouling red is everywhere present on Russian ships, sometimes with, sometimes without boot topping and/or white "waterline".
The merchant shipyard
finnfan
Post by finnfan »
I acquired an old PitRoad 1/700 Udaloy kit which unfortunately had lost its decals. Does anyone know of a suitable decal set which will provide the overlapping circles on the helicopter deck? I tried the circles from other set from the spares box, but they are all too small. Alternatively if someone has a surplus decal set I would be happy to buy.
Don
finnfan
Post by finnfan »
Panic over! I had moved modelling benches some time back and assumed the decals had got lost in the move. However, one last look through the pile of unsorted bits revealed them.
Now I should be able to complete a diorama with Vitse Admiral Kulakov and Vesduschyi at a floating pier near Severomorsk (using Combig's resin floating pier elements)
Thanks for looking
Don
Hank McCoy
Admiral Ushakov radar fit ?
Post by Hank McCoy »
I am building the 1/350 Trumpeter Sovremenny 956 as Admiral Ushakov in current service using the GMM photo etch. Can anyone help with the radar fit - Top Steer, Plate Steer, Top Plate ? I'm also assuming that the 'Early' mainmast is the correct fit for Russian ships. First real warship build in 25 years. Thanks.
Sauragnmon
Admiral Ushakov, Penant 434 - pictures I have seen, she's packing Top Plate set - notice it's two arrays on the mast. Top Steer is two dishes, Plate Steer has one array one dish, Top Plate is twin arrays. Still operates the older AK-630 CIWS as well.
Hank McCoy
Thanks very much for the info. Working on railings at the moment and hope to be onto masts/radar soon.
Here is Ushakov's page on the Russian Navsource: http://navsource.narod.ru/photos/03/487/index.html
Michael Potter
Post by Michael Potter »
My PC malware detector blocks access to the Russian Navsource site as a source of infected downloads.
Dr James Hansen, NASA, 2008.
Aur
Re: Calling all Udaloy/Sovremennyy (?????? & ??????????) fan
Post by Aur »
Hello all :wave_1:
I have got a 1/200 Hangzhou kit made by WSN, which I believe is a copy of Trumpeter Sovremenny. Decals of the chinese ships as well as the original Sovremenny are included. I wish to make it as a radio controlled model, but I still don't know anything about the process...may need more helps for that later.. :big_grin:
I noticed that some ships have single rudder, and others have twin, so my question is how do I know which ship has which type? So that way I can plan ahead on the ship's name (and decals).
Also I would be appreciated if someone here knows where to find plans for the Sovremenny screws/propellers...if that doesn't sound too weird.. :heh:
Aur.
I'm fairly certain all Sovremenny only have one rudder - if you're referencing the image above by Koppalakki, that's of a Kirov and was used only to illustrate the boot-topping style.
Aur
Post by Aur »
Timmy C wrote:I'm fairly certain all Sovremenny only have one rudder - if you're referencing the image above by Koppalakki, that's of a Kirov and was used only to illustrate the boot-topping style.
Timmy,
I am aware that the photo is of Kirov class...but I couldn't believe Trumpeter made such an error! Most models were built with twin rudders, so I am a little confused..thanks for clarrifying me.
So I better ask; where do I find references or plans to fix the inaccuracies? I just saw Koppalakki's 1/200 Sovremenny, and it's just... :big_eyes:...The colors, weathering and shading were...:thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :worship_1: :worship_1:
The kit I got is a little bit worst than the Trumpeter, being a copy of it, as well as being rather old and badly packed, so I'll need to fix quite many things, if I could... :big_grin:
Thanks a lot!
Aur
Littorio
Post by Littorio »
Guy's I've been looking to pick up a 1/200 project 956 em Sovremenny class, now reviews of the Trumpy kit abound with it's list of faults but what I can't find is reviews of the Bronco kit.
Is the Bronco kit worth the extra cash (�50 difference in the UK)? Does it suffer from the same faults or not?
Not bothered if the finished kit is Russian or Chinese just like the looks of the Sovremenny and it is likely to be my only 1/200 kit purchase unless a Littorio comes out.
On the slip - all 1/350
USS Fletcher - Tamiya w/GMM PE and L'Arsenal resin
USS Mackinac AVP-13 - ISW w/ AM parts from several sources
In the design office -
HMS Ariadne Conversion of WEM kit
Here's a previous build thread that highlights the issues: viewtopic.php?f=59&t=92307
