I had a little problem with the paint guide of the Enterprise. It told me the entire lower hull is to be painted black, but only after building did I notice that it was supposed to be red. Now I have to start over and remove the lower hull to spray paint it. The pictures will be delayed for awhile, because of this.
Take a look at http://www.starfighter-decals.com/ for decals for your flight decks. The 700th scale sets will be a little big but can be easily cut down. They are pretty thin and take a bit to work with but produce a wonderfful result.
One of the things I do if I am not sure about colors and need a painting guide is to do a search on the gallery to find other builds similiar to what I am doing. There are some pretty neat ideas being executed out there and plagerism is encouraged!!
Continued work on the Independence. Working on all the tiny PE parts gave me an overwhelming urge to throw it at the wall. Here's my best attempt at the two quad-mounts:
I left off what I believe are the charging handles from the PE - I just can't get a hold of really tiny parts with the tweezers I have - they just shoot across the desk. It was hard enough to build these things as shown - tweezers in each hand looking at the whole thing through a magnifier. I am hoping the paint will make them look better.
John,
You did a good job on the quad 40mm's. These are the same 40's that are in my Gearing kit and I had a hard time getting the small pieces on them also. It is very frustrating to pick up a piece only to have it fly aceoss the work bench.
Keep up the good work and fell free to post more pictures.
I will start my Independence after I get WEM's PE (when it's released) and finish Monssen,Buchanan,Fletcher and Pittsburgh. Hopfully it will be in April.
Gordon
Here are some photos of my latest build a what-if modernised H.M.S. Illustrious uparmed with a 32cell Mk-41 VLS and some extra electronics. I tried not to alter the ship too much which would reduce the air complement but just compensate for the loss of the Sea Dart launcher and add the necessary satcom systems found on most NATO warships.
On the workbench:
Various 1/700 aircraft.
Juan Carlos I LHD 1/700.
HMAS Canbera LHD 1/700.
FGS Type 122 class FFG 1/700.
LSD-41 class LPD 1/700.
Superb build Nektarios that would have been a great update to that class, i never rated them as fixed wing carriers, but as always the RN made the best use of what was available.
Please leave off the Harriers, put on a full compliment of Helos, maybe even an Ospey or two and use them in what could be their best role, LPH.
I ll order the Regia Marina PE set for the Merlin helicopters When i ll put the PE blades on the Merlins i ll post pics of the Illustrious with its full air complement.
On the workbench:
Looks great Nektarios! Looking forward to seeing the aircrafts on deck. I plan to build the Ark Royal some time in the future, should be a fun build, even though it won't be as upgraded and modern as yours.
Heiko S. |MY SHIPYARD| Under construction: JDS Takanami (Takanami Class Destroyer)
Last week completed Junyo, started painting Hiryu
Then...the news of a new tool Kaga means...I just could not resist..
Argh...I need to find myself a pre-mixed wooden tan colour. Hiryu deck turned out too yellow, a brown wash may fix some but my painting room is dimly lit (it's the laundry ha!) so rather difficult to eyeball it every time.
