Carrier Builders Yard, whats on the Slipway
gtbred
Post by gtbred »
Chris Boatman 1/144 CVN-68 NIMTZ in the water. a test run. Image Image Image
JevJanson
Post by JevJanson »
That is one awesome Nimitz there. Now, all that needs to be made is a scratch built Gerald Ford-class!
Greetings from Montana!
Ryon Olson
doog_k
Post by doog_k »
kidcurrie42 wrote:Thanks for posting the additional pics Doog, i am sure she will make a great static display if she is unable to be run on the water. what aircraft are you going to put on her?
Hopefully post some pics of my pre war wasp later tonight, hangar is painted, just finishing off the aircraft to place inside.
Happy Modeling
John
Hi John
I'm planning a representative selection of some of the types flown to and from Wolverine and Sable.
The collection would be unlikely to be seen all together but President Bush's (senior) Avenger will be one of them (he deck qualified on her in '43) along with a couple of USN T6s, a Helldiver, two Hellcats and USMC Corsair. With a couple of Fleet Air Arm Martlets (Wildcats) as some Royal Navy and Royal Canadian Navy pilots also were graduates of Chicago's carriers.
Doug
On the Slips:
1/144th Stand-off scale:
IJN Nisshin
HMAS Albatross
Keels laid: IJN Tone
Frames laid 1/25: DDR KleineSchnellBoot
http://www.edinburghmodelboatclub.org.uk
https://www.facebook.com/pages/Edinburg ... 2565540179
DanCinSD
Post by DanCinSD »
Welcome to the launching of USS Boxer, LPH-4. This is Dragon's 1/700 kit of Boxer. Anyone with comments on the Dragon kit and it's accuracy issues will be most welcome!
I don't know much about post-war carriers.
Boxer is being built for a library display in 4 months, she will be basicly Out of the Box. The kit comes with some p/e, on first look I will just need to add railings. The kit also has parts molded in clear plastic which I have found gives fit issues, that being said, since this will be a "slammer" and for a public display I am thinking of using the clear flight deck to show a little of the hangar bay.
That will depend on how the build goes. The nice thing about post-war carriers is not having to build multiple AA mounts, USS Boxer only retained the 4 twin 5'" mounts.
If anyone has any extra UH-34 Seahorse helos, that would be nice to add to the 8 in the kit.
Here goes! Keel being laid..... A tradition of mine is to superglue a current years penny into the build somewhere.
The kit.
Island started...
Clear and normal flight deck...
Decals, p/e included with the kit.
oh look, two cute, tiny, tugboats!
Any idea on the flight deck color? The Dragon instructions say "intermediate blue"..... I am thinking of using either Gunship grey or the late WWII flight deck stain (250n?)
The overall ship will be "Haze gray"
Dan
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Dan,
On my Boxer build, I used Gunship Gray and weathered/darkened it with pastel chalk black and brown/rust. I did this before any clear coats. Then after that, I applied a gloss clear coat (you loose a little of the rust color when you do this but, it turns to a different shade of "dark" than the black chalk.) and then apply the decals and put a little more black chalk on it to dull them down and then a dull coat over the whole thing.
I used Starfighter decals for mine. I had trouble with the helo pad circle decals. Bubbles, trouble with them settling into the groves, and then silvering, of course because of the air beneath them. I think part of my problem, then, was I had a dull coat layer, somewhere in the process, before the helo pad decals went on. I'm sure that the Starfighter decals were fine, just my technique didn't work. Not even with Solvaset. I ended up trying to paint over the helo pad decal film and covering up the silvering but, this didn't work the best, either, especially close to the decals' color portions.
I crush up the chalk and apply it sparingly with a small brush and lightly move it around without much pressure. Then I blow the majority of the chalk off of the model and then go back and rub the chalk in, and around, with the brush. Most times, if you don't like it, you can use a little water to clean it off. BTW: I use Model Master Acrylics.
Good luck with your Boxer! I'll be interested in seeing its progress. I'm wondering if you are going to pursue more accurracy in your model than I did with mine and what DRAGON didn't do with the kit; i.e. the 20mm and 40mm gun sponsons on the bow and stern, etc.
There is a tricky fit where hangar and hull bulkheads come together on the forward-port quarter. It takes a little scratch work. I guess that everybody who builds these DRAGON Essex class kits have to deal with this. I think that it has been talked about earlier in this thread.
Here are a few in-progress pics of my Boxer build:
http://s264.photobucket.com/albums/ii19 ... ?start=all
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
Mark McKinnis
Post by Mark McKinnis »
I like to paint the deck on my post WWII Essex Class light ivory or a light deck tan. Then I take a blue ball point pen and draw over the tie down strips that are molded on the deck. After it is thoroughly dry, lightly spray a coat of Flight Deck Stain 21, which when I think about it, is the same as intermediate blue give or take. Give it a light sanding with super fine emory paper.
My most successful application of this technique is my Antietam.
Good Luck,
Mark
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Mark McKinnis wrote:I like to paint the deck on my post WWII Essex Class light ivory or a light deck tan. Then I take a blue ball point pen and draw over the tie down strips that are molded on the deck. After it is thoroughly dry, lightly spray a coat of Flight Deck Stain 21, which when I think about it, is the same as intermediate blue give or take. Give it a light sanding with super fine emory paper.
Good Luck,
Mark
Mark,
I bet that, that Antetam deck looks even more impressive, in person. I love that! :thumbs_up_1:
Carl Musselman
Photobucket
YouTube Channel:
Mark McKinnis
Good Luck,
Mark
Mark,
I just wish that they all came out that nice!
mitchell300
Post by mitchell300 »
gtbred wrote:Image Image
Awesome.
I wish my little boat could do that (only 134m long).
I wish my navy had carriers :dead:
New Ships Planned For Shipyard:
USS.Missouri 1.545 scale to new jersey desert combat
Ships in dock:
USS.Saratoga 1.535 scale Desert combat (currently on hold)
Ships in repair:
SMS Tirpitz 1/540 (adding new radars and fixing the main guns)
kidcurrie42
Post by kidcurrie42 »
Here is my USS Midway that i have over on the Cold War group build, flightdeck has been sanded and all raised detail removed, island has been started, hangar deck just needs some detail added, still working on the airwing decals.
Happy Modeling
John
Si Vis Pacem, Para Bellum
Hippy Ed
Post by Hippy Ed »
Lookin' good thar John!! :thumbs_up_1: :thumbs_up_1: :big_grin:
You've lost everything...
On the Bench:
JevJanson
Post by JevJanson »
Glad to see the Midway coming together! Coming along quite nicely. I wish my ships would turn out half as good as yours. Speaking of ships, I will finally have pictures of my Nimitz and Tarawa up tomorrow!
Ryon Olson
gtbred
Post by gtbred »
Image Image Image John does have a BIGGER ONE guys. :lol_pound:
jgrease
Post by jgrease »
Great stuff Red! Keep the pics coming!
JevJanson
Post by JevJanson »
Let me guess, 1/350? If so, could you fill me in on how you made it so I can make one like it. I want to have a Midway to go alongside Enterprise, Nimitz, Kitty Hawk, Wasp and New Jersey. Funny how there is one battleship mentioned with the carriers...
Ryon Olson
gtbred
Post by gtbred »
she is not in my hands anymore. John has her. :big_grin:
kidcurrie42
Thanks Guys and gtb :big_grin: :thumbs_up_1:
Happy Modeling
John
gtbred
Post by gtbred »
JevJanson wrote:Let me guess, 1/350? If so, could you fill me in on how you made it so I can make one like it. I want to have a Midway to go alongside Enterprise, Nimitz, Kitty Hawk, Wasp and New Jersey. Funny how there is one battleship mentioned with the carriers...
i'll post the thread latter JevJanson for you.
JevJanson
Post by JevJanson »
Thanks Red. Look forward to reading up on the ship!
Ryon Olson
starfighterace
Starfighter Decals
Starfighter Decals
Post by starfighterace »
I wanted you guys to see what I may release in the next few months.
SFD Nimitz by starfighterace, on Flickr
This is not the final design. It's pretty close. Just need to fill in some stuff. It's designed for the Italeri 1/720 US Nimitz Class CVNs. I also found out doing the artwork layout, the Pit Road/Trumpeter is identical in size when it came to fitting the decals. I'll let you guys figure that one out.... :scratch:
This set will replace 700-27 and 700-35 thru 700-39. The Alps printer is dying and the cost keep spiraling upword. Ink has increased almost 4x since I started in 2005. Paper and other supplies have doubled. This leaves me with two choices: discontinue the line, or silkscreen print them. I am not really sure if there is enough demand to justify the investment. I only sold 25 sets total in the last year. I sold that many CVN-65 sets alone. If I get enough positive response, I'll pull the trigger and get this and another CV sheet I'll post later printed. I have to sell 100 sheets to break even. The cost would be $12 (up from $10 for the Alps but you get more accurate markings and more options).
I'm posting this here, as this is basically my customer base. I know GMM has his set on the market and it's really nice. My set offers more "stuff", but Loren's is far more complete when it comes to the Island markings. His covers all USN "Supercarriers" while mine is very kit specific- Italeri Nimitz CVNs.
Why you ask? Because not counting the Revell Box Scale CVs and CVN-65, it has the longest continuious production run of any other USN Carrier kit. These kits have been boxed under Italeri, Testors and Revell/Germany .I do not want this discussion to turn into one on the merits of the kit(s), I'm just telling you the "Why" I designed the sheet the way I did.
To be upfront, this sheet is for the Nimitz Class only. I will develop a seperate sheet for the Revell CVN-65, Italeri Forrestal Class, and the "others" (Kitty, Big John, Americia), IF these sell well enough and the demand is there. The colors for the sheet are pretty much set. Please do not suggest adding items that would add to the color list of Red, White, Yellow, Blue, and Black.
So, what do you think? You want some? Like/Don't like?
A world without science is a world without model ships.
