Thanks, Rod. Yeah, there's lots of "stuff"........... it never ends! Things have gone pretty easy so far. The main superstructure is coming soon. That will be a challenge............ Stay tuned, I'm getting there!Millard wrote:Bill,- Excellent as usual.You are right, there's a lot to a BB.
Rod
USS Indiana BB-58 Scratchbuild in 1/96 - 1944
- Bill Waldorf
- Waldorf Productions
Rusty White
- Flagship Models
- Edward Pinniger
You can also get diamond textured plate from Slaters Plastikard (widely available in the UK, not sure about Europe). I've already used some on my USS Hazard. Slaters also produce plank-textured styrene in 2,3 and 4mm widths, which is ideal for deck planking if you can't face making individual wooden planks.Laurent wrote: I just hope this plastruct stuff is available in Europe![]()
- freelance
A silent watcher
Good Evening Bill, I'm a newbe at this hobby myself, the freelance system, one hull and several supers,
Thank you for putting your build, pictures and narrative up for all to see, our best to your wife... Pat
- Bill Waldorf
Re: A silent watcher
Thanks! I have not seen you here before. I appreciate you taking the time to post. Many people look, But many don't say anything. I don't know who all is looking. No matter, for all to see and enjoy. Also thanks for the thoughts on my CIC (wife). She is getting better, although tired lots of the time. Back to the Dr. on Wed.-- Her 60th b-day. Not much of a gift........... I do what I can. An older veteran of Escort Carriers, a TBM pilot as a matter of fact, told me to "Stay the Course". His aircraft was launched off the deck, unmanned to clear the flightdeck as they were under attack by the IJN. He was in the ocean for three days before being rescued, and is now in his 80's, and still tough. I'll take his advice. Thanks again, and stay tuned............. The adventure is just beginning.................freelance wrote:Good Evening Bill, I'm a newbe at this hobby myself, the freelance system, one hull and several supers,
- Bill Waldorf
OK... Enough of my ranting! Back to the build. I have finished installing all the small details along the hull and have painted the 5-N Navy Blue. A little haze grey, 5-H to do yet, after decks are installed. This will complete MS.21. A short update tonite! Lets take a peek..............
Here's a full view of the port side of the ship. If you look close fwd. you can see the dividing line between the 5-N and the primer coat, still visible. This is where haze grey will be applied.
Here's a closer view of the bow area. You can see the dividing line better here. I'll add hull numbers soon.
Dead on view of the bow here. Again note the dividing line between 5-N and where 5-H will go. 5-N looks a little light in these photos. I am using Testor's Model Master Marine Acylics here. They dry pretty slow, and get darker as the dry. Just painted this an hour ago. Should get a bit darker.
A shot of the stern here.
A close up of the armor belt area, stb. side. Note I have drilled out all the scupper pipes that hang beneath the main deck. .040 styrene rod used for the pipes. Drill bit is about .015. Thats it for tonite!! Hope you enjoy..........Stay tuned.............I continue on...............
- Dave Wooley
Hello Bill. Your finish is superb. Question,- I note in the picture that you have a halogen light . For close detail work and over all lighting to the job, I use a blue light which produces a light very close to natural . I've not worked with such powerful lighting as halogen. Are there any advantages ?
- Jose Chaica
Better than using one..is using 2 "blue lights"!!!Dave Wooley wrote:Hello Bill Your finish in superb. Question I note in the picture that you have a halogen light . For close detail work and over all lighting to the job I use a blue light which produces a light very close to natural . I've not worked with such powerful lighting as halogen is there any advantages ?
- Bill Waldorf
I don't use the Halogen light much anymore. It's actually too bright, and it gets hot. It does work well for short periods on parts that are highly detailed, such as the 40mm quad guns. I find that a plain old 100 watt bulb inside one of those hang up lites with the silver metal shroud works well too. What is a "blue light"?
- Andy G
You can buy blue light bulbs in the UK, often in Art & Craft shops - but I think the big DIY chains do them too - that have blue filter glass on them to better represent daylight.Bill Waldorf wrote:I don't use the Halogen light much anymore. It's actually too bright, and it gets hot. It does work well for short periods on parts that are highly detailed, such as the 40mm quad guns. I find that a plain old 100 watt bulb inside one of those hang up lites with the silver metal shroud works well too. What is a "blue light"?
The technical explanation: a normal tungsten bulb has a colour temperature of around 2800K. Daylight has a colour temperature of around 6500K. Look into people's windows in the evening when it's still light outside and rooms look like they have a yellow cast. That's because your eyes colour-balance automatically and see tungsten-from-daylight as cooler (yellower). The inverse is also true: look out of your window when adapted to tungsten lighting and things look hotter (bluer).
The halogen light is closer in colour temperature to daylight than tungsten, so would make a better light to paint and mix colours in, for those models that are destined for outside. Museum modellers might argue that painting under tungsten is the best choice for them.
A word of warning - never paint under fluorescent light. These lights are not "broad spectrum" like tungsten, halogen and daylight. They make up their "white" colour by having peaks of energy at different frequencies. It's possible to mix a colour that looks ok under fluorescent light which has distinctly "odd" shades to it when illuminated under another source.
Have I bored everyone yet?
Andy
- Bill Waldorf
seaphoto
- SeaPhoto
Hi Bill,
Try using the GE "Reveal" brand of lights - they are pretty nice to work under, not terribly expensive and no warmer than regular light bulbs.
I set up a halogen track light strip in my old shop. Great light, but you could get a suntan working under them. For my new place, I went back to Flourescent strip lighting, but put 6 skylights in too, and posistioned my paint area next to a south facing window - plenty of light during the day, which is when I do my painting anyway - like to have plenty of ventilation. In fact, whenever I can, I paint in next to an open roll up door with a low speed fan behind me to push the fumes out.
She is looking great!
Kurt
Kurt
Kurt Greiner
http://www.warshipmodelsunderway.com
Home of the Big Models
http://www.warshipphotos.com
SeaPhoto Maritime Photography
Rusty White
- Flagship Models
Those are lights that have a slight blue tint to them (duh), but they are designed to replicate natural sunlight. Photographers use them when shooting indoors. I bought a couple at my local photography supply and do make great lights to work under, but they are a little pricy.Bill Waldorf wrote:I don't use the Halogen light much anymore. It's actually too bright, and it gets hot. It does work well for short periods on parts that are highly detailed, such as the 40mm quad guns. I find that a plain old 100 watt bulb inside one of those hang up lites with the silver metal shroud works well too. What is a "blue light"?
Like you, I use a plain 'ol mechanic's clamping hood light with the shroud I bought at Wal Mart because it distributes light very well. I can also clamp them to my upper cabinet doors in my workshop to photograph models. The clamps allow you to place the lights anywhere you can clamp them to which comes in handy.
Rusty White
flagshipmodels.com
flagshipmodels.com
- ArizonaBB39
- Dave Wooley
Thanks Andy Interesting answer and one I've never really been aware of .Andy G wrote:You can buy blue light bulbs in the UK, often in Art & Craft shops - but I think the big DIY chains do them too - that have blue filter glass on them to better represent daylight.Bill Waldorf wrote:I don't use the Halogen light much anymore. It's actually too bright, and it gets hot. It does work well for short periods on parts that are highly detailed, such as the 40mm quad guns. I find that a plain old 100 watt bulb inside one of those hang up lites with the silver metal shroud works well too. What is a "blue light"?
Andy
Also I like the idea of two blue lights, one either side of the job to give an even dispersion of light.
- Bill Waldorf
If you'll go back a couple lines on the thread, you'll see I mentioned this as you have. I am using Testors MM Marine Acrylics. Comparing the dried hull to Snyder and Shorts WW2 color chips, it is slightly lighter, not much. If one were to allow for fading and different batches of the real paint, I think it would be acceptable. Anyone else want to weigh in here, please do!ArizonaBB39 wrote:Beautiful build Bill! Keep us updated for sure!
One question though, what color are you using for the 5-N? It looks a little light to me (maybe its just me though).
- ARH
It's not very often I say anything about someone else's build, but here goes. One has to remember lights and shades, you can take one photo and it can be perfect, take a second one and the light has changed, it's a totally different picture. Also angles of light, the way they fall, can change a paint colour. Moffett at times looks light blue, some times grey. The way I see it Bill, if your happy with the colour thats all its about, looks great to me,
Simple but effective.
- Bill Waldorf
- Bill Waldorf
