1/200 Scale Group Build from 2015-17
For posting your photos of the group build subjects.
robertmelvin
Re: 1/200 Scale Group Build 2015
Post by robertmelvin »
As far as I know, and this is simply what I have heard from multiple sources, G-Factor just makes a brass re-cast of the kit prop. So, if the kit prop isn't accurate ..........
Bob
Post by Fliger747 »
There was a pretty decent discussion of this subject, as I recall in the Iowa CASF thread. Hank went with the Kieth Bender custom props. You might enquire as to the cost, but considering the investment of all the parts and pieces, the props are a focal point, especially if you leave everything bare brass.
Cheers. Tom
steinerman
Post by steinerman »
Just a quick question regarding painting, Gents. Which gets painted first, the black "Belly Band" or the red hull? I'm thinking you always cover a lighter color with a darker color, which would mean the grey goes on first, then the red, and the black band last. Or does it really make any difference?
Larry Steiner
Post by Fliger747 »
That's the way I did it, not a professional painter. Belly band is known as "boot topping".
Cheers. T
steinerman
Fliger747 wrote:.....Belly band is known as "boot topping"......
Oh it is, huh? Well Tom, up here in snow country "boot topping" is something that you rub on your boots before the snow flies to keep them waterproof. Nothing like wet feet when it's 10 degrees outside and a foot of white stuff on your driveway :big_grin: :lol_3: :nod_2:
Larry Steiner
Post by Fliger747 »
Fairbanks Alaska...
steinerman
Guess I'm preaching to the choir, huh? :Oops_1: :huh:
Larry Steiner
Post by Fliger747 »
Transported Alaska through snow, sleet and the dark of night over the hill and through the woods, bypassing grandma's house to its winter season shop. Appears to be in one piece so far.
steinerman
Hi Gang, How long does it take acrylic paint to fully cure to the point where I can tape over it and not have to worry about the tape taking off the paint underneath it. It's been primed, so it should be adhered satisfactorily
Larry Steiner
Post by Fliger747 »
Modeling hiatus, big wet snow, power out and fun to be had by all!
steinerman
Fliger747 wrote:Modeling hiatus, big wet snow, power out and fun to be had by all!
Please, PLEASE keep it up there! It's way too early for that crap down here.
Larry Steiner
Post by Fliger747 »
I think Hank had even more fun with ice storms last year in NC.
tegunn
Post by tegunn »
steinerman wrote:Hi Gang, How long does it take acrylic paint to fully cure to the point where I can tape over it and not have to worry about the tape taking off the paint underneath it. It's been primed, so it should be adhered satisfactorily
Assuming the model in room temperature ~70-74 degrees F, two days soonest. If you procrastinate, even better! :) Do a mask test on a small portion that's hidden if possible by seeing if it will come off with paint. Blue masking tape or similar.
Future Project: TBD
And try de-tacking the tape on a clean surface first to remove most of the stickiness from it - it'll help in reducing the chances of pulling up paint.
BB62vet
Post by BB62vet »
Yea, FUN :mad_1: I really think that driving in snow would be ok if it weren't for the idiots out there that haven't got a clue about common sense, etc. The ice storms keep the repair shops in business!!!
We're into a full week of rain and with the passing of Chungking or whatever the hell his name is (latest tropical storm) up the east coast, it should be a wet weekend to boot. We WERE planning on going to the fair this weekend, but that's now a distinct improbability. :cry_3:
steinerman
Thanks, Gentlemen! I knew I could count on an answer here!
Larry Steiner
Post by Fliger747 »
Whenever the power comes back on and I warm the studio back up, will get out the color chips and start matching a batch or two of Golden Acrylic. I need to do the main deck before I can do much more. Of course need to chase down the en transit Alaska book, possibly looping between post offices. Surely rivet counters, myself and a host of folks will be able to pick out many obvious errors in the model due to insufficient information.
T
Post by Fliger747 »
5:47PM Power back on! 4 1/2 days. Back to the life of Riley...
Larry:
As to bases, somewhere on this site is a great view of a completed HMS Renown on a small block base. Might take a look at it, really nice!
BB62vet
Post by BB62vet »
Tom,
Glad to hear that you are no longer having to watch TV by candlelight :big_grin:
Post by Fliger747 »
Hope that you aren't having to canoe about! Most of our new early snow has melted, the river at a surprisingly high level for this time of year. Progress on Alaska waiting on (1) arrival of Steve's book (2) work on 4 runner (head gasket etc) (3) some issue with heater in studio. Mainly don't want to progress on too much more in case serious alterations are necessary.
The only previous waterline model I completed was a very diminutive USS Whitehurst, DE 645, about 6" long, completed with absolutely no PE, using an old girlfriends long straight hair for lifelines. Mounted on a walnut block. However Alaska will likely need for me to simulate some water! Something I will have to bone up on and experiment with. A ways down the road, or a lot of bridge under the water as my submarine friends might say.
T
Return to “Group Builds”
