Carrier Builders Yard, whats on the Slipway
- kidcurrie42
Very nice model, really clean looking build.
The ship looks like an as built with the as built deck markings. Airwing could well be CVW-17, this was the first time Forrestal used the AA tailcode.
Also the A-1H is from USS Intrepid 1966 Vietnam tour (412 AK 135326)
F-8E's with AH tailcode were from Oriskany or Ticonderoga, CVW-16 and tailcode AH disestablished : Jun.30, 1971
Happy Modeling
John
Happy Modeling
John
Si Vis Pacem, Para Bellum
- gtbred
http://www.usnavymuseum.org virtual tour model ships.Hippy Ed wrote:Red, if I'm not mistaken, this is the CVW that was aboard in 1967? When they had the big fire...
- Hippy Ed
gtbred wrote:http://www.usnavymuseum.org virtual tour model ships.Hippy Ed wrote:Red, if I'm not mistaken, this is the CVW that was aboard in 1967? When they had the big fire...
You've lost everything...
On the Bench:
On the Bench:
- kidcurrie42
- angeleyes
building a Hornet into a Midway Enterprise which will be used in an action dio.Quite a few mods here and there , but mostly on the bridge.The resin parts i bought to be used as a direct replacement for the bridge unfortunately are not up to a usable standard so i am using them as reference.Weathering the hull at the moment so to make her look a bit worked up as requested.
- kidcurrie42
That weathered paintwork looks superb on the Enterprise, you have caught the at sea for long period/rushed painted in harbour look perfectly
Happy Modeling
John
Happy Modeling
John
- gtbred
yes he did.
- kidcurrie42
Just ordered some items to scratch the Mk-29 launchers,
Would this look good in 1/350
Anyone building a Lincoln
Happy Modeling
John
Happy Modeling
John
- Hippy Ed
On the Bench:
On the Bench:
- kidcurrie42
Well i managed to get some work done on Roosevelt today, got the fwd deck section secured down, i trimmed up a couple of areas on the aft section and this will now fit with no gap at the mid joint, waiting for the fwd section to dry before securing aft.
Cut out the closed doors from two elevator openings, and made two new ones, started on some of the hangar bulkheads.
Aft deck section secured, no fit problems.
Pics later
Happy Modeling
John
Pics later
Happy Modeling
John
- kidcurrie42
- simon b
Good to see it started John.
Are you going detail mad or for something a little more straight forward ?
- kidcurrie42
I am going to really push my limit on this, i have all four PE sets from WEM and GMM, so plenty to play with as well as tons of sheet/strip/rod styrene, i thought i had it all, until i went to start scratching the Mk-29 launchers, that is now on the way to me.
Not decided yet on what aircraft i will use, Tamiya or Trumpy. will build a couple of each and see.
Hangar will have Tamiya F-14, F-18, A-6, SH-3, S-3 and one each of E-2, EA-6.
Open canopies, not sure yet, never made clear canopies before.
Hangar deck lighting- No Way.
Any questions or advice welcome, either Here or PM.
Get cracking on that Lincoln Simon, i am planning my next one already, Maybe Eisenhower, Vinson or Washington, i have not seen those in 1/350 yet.
Happy Modeling
John
Happy Modeling
John
- simon b
Sounds good John
Maybe for the next one you could try the newer style Nimitz class (Vinson and now roosevelt with new radar towers)
- sgtryan13
Glad she is started John!
With all the scratch building you are planning, lighting the hangar deck will be simple, really! I can show ya how I did it, it was really as simple as cutting 4 wires on a battery powered string of LED's and re splicing them together out the bottom of the ship.
- kidcurrie42
Thanks Guys,
I do not really want to build a carrier with an all F-18 air group, maybe a 2010 Vinson with the aircraft below..........
610 HS-15 Red Lions SH-60F/HH-60H
(AC)610 HS-7 DET Dusty Dogs SH-60F/HH-60H
(AB)610 HS-11 DET Dragon Slayers SH-60F/HH-60H
(AJ)610 HSC-9 DET Tridents MH-60S
(BJ)5xx HM-14 DET Vanguard MH-53E
(TB)xx HM-15 DET Blackhawks MH-53E
40, xx VRC-40 DET 5 Rawhides C-2A NP
Ryan, i will think about the lighting over the next few days, Thanks for the offer.
Happy Modeling
John
Happy Modeling
John
- kidcurrie42
A couple of Hangar deck pics i found online, makes the Hangar look small.
Here is one for you Ryan
Happy Modeling
John
Happy Modeling
John
- sgtryan13
Nice John! Have you come across any good detail shots of the very aft hangar bulkhead? basically the spot where your above pics were taken from? That is the one piece missing from my hangar reference puzzle and if I can I would like to nail it!
- Mark McKinnis
Nice Pics!!
It looks like they still stuff the E-2 inside and forward of L-1. Somethings are timeless!
- kidcurrie42
Some links to pics of the aft end of Nimitz class hangars.
http://www.navy.mil/management/photodb/ ... 45-026.jpg
http://www.navy.mil/management/photodb/ ... 8J-024.jpg
http://www.navy.mil/management/photodb/ ... 8G-020.jpg
http://www.navy.mil/management/photodb/ ... 9H-092.jpg
http://www.navy.mil/management/photodb/ ... 6S-029.jpg
Last link is the George H W Bush with the Goshawks.
