Calling all Essex-class (Cold War configuration) fans
modelersc11
Re: Calling all Cold War Essex-class Fans!
Hello all
My name is Sherman Collings and I work for Model Rectifier Corp., the distributor of Gallery Models� USS Intrepid. We�ve been asked to plan the changes needed to bring out a USS Ticonderoga and/or USS Hancock with the understanding that they are very close to the same, needing only detail changes.
My research on the internet is very confusing since there were many changes over time. We�re interested only in their Vietnam service deployments at this time.
Would some of you knowledgeable modelers be generous enough to guide me in this regard? We need to know the differences between Intrepid as we�ve modeled it, and the other two similar ships.
So far, I�ve found that Intrepid was the only one of the three with the bulbous Sonar dome on the hull.
Ticonderoga and Hancock seem to have a different-larger search radar as well.
Both Tico and Hancock did not retain their stern gun tubs as Intrepid did.
Both Tico and Hancock need the bow stem anchor moved to the port side.
Both Tico and Hancock had two large antennas on lattice-work supports mounted to the stbd. side that Intrepid does not have.
Thank you
Sherman
Thank you
Sherman
I met you or your represantive the Nationals , this year. I introduced myself and forgeve me i was stammering because I am still recovering from a stroke. I handed over to you.him 4 DVDs just loaded with imagery on the post war ESSEX CLASS totalling well over 1800 data and images with all the information you would need..we shook hands and I thought these would go into safekeeping. PLEASE CONTACT OFF THE BOARD PM me at stillmo@shaw.ca ASAP
RAY D. BEAN
Winnipeg Canada
204 888 6052
RAY D. BEAN
Winnipeg Canada
204 888 6052
- davidwaples
I'll let the real experts chime in on this. But with respect to the Ticonderoga, let's start the conversation with the stern and deck.
As you can see Tico did have the stern gun tubs but they were later removed. I'm not sure of the dates but I think this should be a modeler's choice. I would like to See Gallery have this as an option. Although they would need to provide a lot of different parts such as the older style mast and radar to make it work. Probably not a good idea and I see that they they want to focus on Vietnam cruises. I plan to build her without the tubs myself.
Second, the Intrepid kit deck is a mess. Photos of the refit show that the deck was reinforced (not sure with what but assume steel) on the deck at the wires. It's clearly visible in this picture. The rest of the deck is wood and photos of the deck show this clearly. I've seen photos of the decking along the cat rails which have several runs parallel to the rail. I'm hoping others can provide better images to verify. Note how visible and beat up the decking is.
[b]Note on photos below: Update 9/19: It's come to my attention that these photos were organized and published by Ray Bean which was unknown to me at the time. As noted later Ray gives his permission to have these photos listed, although I was unable to edit any of the text out of the photos. If you have any questions about the photos or text please check with Ray.[/b]
This photo of the elevator looks like wood to me. I think this is the port side elevator.
Here's the drop down elevator in the center of the deck. It's plated steel as described in the photo
On to the island. Here are some photos of the island and antenna arrays.
Like most Navy ships each cruise seemed to result in changes. I'm looking forward to seeing what everyone else has.
Dave
Dave
- wvtomcat65
Hello Sherman,
Sent you a Private Message. Please check you PM's. I have a friend who can help you greatly...
Thomas
Thomas
It should be noted that David's photos came from Ray Bean.
- davidwaples
Thanks Tracy. I had no idea where they came from as they were sent to me by a friend. Good to know who did the work. Now put your tongue back into your mouth.Tracy White wrote:It should be noted that David's photos came from Ray Bean.
- Dick J
Did anyone else happen to notice where the meatball was in David's top photo?
Nope! Leaving it there. Sorry to be a prig about it, but there are still people who believe that once something is on the internet it's free to everybody and no one owns it any more. I'm not saying this was you, because you didn't know where it came from. However, it costs one nothing to attribute the source of documents when known, and may help people like Ray sell more of his discs. At the very least, attribution is required to be compliant with the fair use clause of US Copyright law.davidwaples wrote:Now put your tongue back into your mouth.
My attitude of "hey, dammit, source that!" is still a valid reaction and I hope it gets the point across to the future readers, even though we've since discussed why and those readers would understand why you didn't.
- wvtomcat65
I can say with 100% certain that Ray Bean now has Mr. Collings contact info. Mr. Collings sent me an e-mail this morning from the PM I sent him last night. I forward Ray his contact info... So, Ray is on the case!! LOL... No doubt now MRC will have what they need to produce an accurate Tico & Hancock....
I personally am looking forward to seeing what other Essex Class can be done from the Intrepid kit. Tico & Hancock are no brainers, since the 3 are almost identical in flight deck, hull shape, & island... I hope they can also do the others that we're different in flight deck & hull shape. (BHR, Oriskany, Lexington, etc...) I have 2 of the Intrepid kit. But, would love to have a Lexington version as she looked in the late 80's/early 90's as a training carrier, before decommissioning...
Thomas
Thomas
Seconded; a 1943 and 1991 Lexington display would be awesome.wvtomcat65 wrote:But, would love to have a Lexington version as she looked in the late 80's/early 90's as a training carrier, before decommissioning...
- MAJOR-B
it's sounds like great news that MRC is going to do a TICO and Hancock... Again as others said would love to see a BHR or Big O...
Now for those whom are still doing the research for this project would it be possible to make a sub-heading for different builds based on what is currently available (TICO and Hancock) so as an aid to those whom will be building them in near future.
One last request any word on additional A/C for the different versions like when they where ASV such as S-2 trackers an which Sea king should be used I know several are out their and have herard mixed reviews... Again thanks to Ray for his wonderful DVD's and all you other subject matter experts.
for all your excellent advise and suggestions.
Thanks as always
Major-B
Thanks as always
Major-B
You're welcome to start a new thread for specific ships. it wasn't banned it in the past and there are more than a couple of cases where one ship in a class has its own separate thread. It hadn't really happened before because there was almost nothing to play with before this year. I would request, as a former mod, that you not just make a placeholder for OTHERS to fill information in; try and start with a good post of basic information (Navsource link, basic discussion of characteristics and differences, etc.) so that there is good information there for people to find and start with. Otherwise, you don't provide anything more tempting than this thread that already exists.MAJOR-B wrote:Now for those whom are still doing the research for this project would it be possible to make a sub-heading for different builds based on what is currently available (TICO and Hancock) so as an aid to those whom will be building them in near future.
hi all Tracy thank you for your kind imput. I don't mind a few of the pictures go up the net as long as the source, original are posted. Pictures are way okay after all I am going crazy posting pics on the SN site. However the images that have text them it my own words and research we all understand whats involved there.
I sent a letter thaw AM to MRC just not answered, no worries if they want my help its there on silver platter AND there are other good people who can contribute . My bog problem is I can NO LONGER get involved in explaining the dates of the mods in greater detail or has to WHO got equipment WHERE and WHEN .... Its very frustrating because I can't into details involved back and forth conversations this very emails in quite exasperating involve ding over and over again type overs,
Would like see a dedicated title on the INTEPrID TICO AND HANNAH those 3 sisters can be built from this one kit.... maybe somebody can set that up.
Hey Ray - I share some of your frustration. I've studied and learned a lot about the WWII Essexes, but it's been helpful that I just so happen to be living near the archives that holds the data for the Navy Yard that did or tracked most of the work.
The post-war ships are harder for me to learn because the records at either at NARA II, across the country, or still classified (there are no plans listed at NARA II for any Essex or Midway post 1945). Luckily we're a community and I'm just one guy - there are plenty of people out there with knowledge we could pull together some subject matter experts for this. Since the first kit is out and they have an established product, the "pressure" is off and they can speak and work more openly on the project. So, my hope is that we can help them produce a bunch of good kits that sell well and are well received.
And more damned aircraft!
modelersc11
Gentlemen
Thank you for the responses and offers of help. I do indeed have Mr. Beans CD's and they've been invaluable. I've been comparing the Tico and Hancock photos to what is supplied in the Intrepid looking for differences. Besides the differences I described in my initial post it looks like the huge SPS-43a radar is on both Tico and Hancock. I believe what we have on Intrepid is considerably smaller, so there's something that needs to be changed.
If anyone has more specific details that are different I sure could use the guidance.
Many thanks for the help.
Sherman
MRC
Sherman
MRC
- davidwaples
Hi Ray,
I didn't know the source of your photos at the time and if I did I certainly would have checked with you knowing the history behind them. I do know that my friend purchased one of your discs for me. I haven't received it yet but hope to have it soon. I also appreciate your willingness to share the research you gathered with the community and Gallery. Hopefully they take you up on your offer.
Dave Waples
Dave Waples
sierra hotel
this is test having trouble posting here..
sierra hotel
okay seems to be working here. Mark McKinnis and Tracy will be exchanging info on the project. I believe we should have separate dedicated THREAD TITLE covering the 3 sisters ---- 11 ,14, 19 CLASS . INTREPID TICO AND HANNA ??
THIS is not a covert secret project we can free and open here, and I now have fairly limiting skills....cant carry on and type lemgty explanations and I can no longer spell the simplest of words. and NO, spellceck gives me the wrong answers all the time. And I really have no idea of WHERE and WHEN each ship got their equipment changed, added of or removed, I am basically a photo guy and all my the research is from the tomes of FRIEDMAN , FAHEY, ad otter USNIP pubs.
I don't mind any of you posting the pictures from my DVDs. No worries . JUST CREDIT NAME AND SOURCE. Please don't post images that have captioning, word boxes, or dialogue boxes thanks. There are errors in these I know but over the years much have been corrected and changed TO THE BEST MY KNOWLEDGE . For example TEAK decks on the CV s really means TIMBER and so on. Dateing has been an issue for over 90% of the pics. A lot of it is researched EDUCATED guess work.
On the SN i will be posting a new set of starboard side clear images of the HANNA invaluable to the modellers of course. I just can't figure out HOW to post on THIS site sorry i am missing a step and i just give up. HOWEVER if some regular poster on this site will volunteer off c=board to post for me email me please of board and stillmo@shaw.ca thanks muchly,
Given that there are basically no other kits on the market (except Renwall/Revell's old kits) for the near future, I think we can keep the thread as it is. Once Gallery produces kits beyond the Intrepid/Tico/Hancock series, we can then see if there's enough demand to merit a separate thread for the different subclasses. As it is, I believe the vast majority of discussion on Cold War Essex kits will be around the existing and soon-to-be-existing three sisters. Making those three a separate thread would result in the Cold War Essex being quite redundant.
As for posting photos, just post the exact same thing you put on SN into the reply box here.
sierra hotel
