Post by Fliger747 »
Not currently on Missouri and looking at my photos I don't see any items that look like mounts remaining. Interesting items and wonder if they made it aboard any of the ships and for how long. Another curiosity is the binnacle at this location. Some sort of emergency alternate conning station? No wheel, no engine order telegraph.
InchHigh
Post by InchHigh »
Fliger747 wrote:Not currently on Missouri and looking at my photos I don't see any items that look like mounts remaining. Interesting items and wonder if they made it aboard any of the ships and for how long. Another curiosity is the binnacle at this location. Some sort of emergency alternate conning station? No wheel, no engine order telegraph.
That's on the open bridge wings, that's where you conn during an UNREP.
Post by Fliger747 »
The position I am referring to is immediately aft of the forward stack, not on the bridge wings.
InchHigh
Post by InchHigh »
Ok, sorry. The one after the stack is the master compass, the others are repeaters.
Post by Fliger747 »
As good a place as one could find given the huge steel objects populating a Battleship.
bigjimslade
Post by bigjimslade »
Fliger747 wrote: Another curiosity is the binnacle at this location. Some sort of emergency alternate conning station? No wheel, no engine order telegraph.
It's the most remote, accessible location they could find. There is a 12' zone (sphere) around the binnacle where everything is non-magnetic material. There is 15' zone where anything moveable has to be non-magnetic. That's why you see a lot of brass around there.
As others have said, this is the master and it transmits to several locations throughout the ship.
Post by Fliger747 »
Except for the "Navigators Balls"
chuck
Post by chuck »
Fliger747 wrote:As good a place as one could find given the huge steel objects populating a Battleship.
The master compass is located where magnetic influences of different parts of the ship most nearly cancel eachother out.
The two big port and starboard iron balls on either side of the binnacle are on adjustable mounts and their precise locations are adjusted to as close as possible cancel out the residual magnetic influence of the ship.
bigjimslade
I found an interesting blueprint today. It showed all the 20mm and 40mm guns on the Iowa class replaced by 3/50 mounts.
Post by Fliger747 »
What was the date on that? Must have got lost in the "roundtuit" bin.
bigjimslade
Fliger747 wrote:What was the date on that? Must have got lost in the "roundtuit" bin.
I was so busy sorting plans that I did not check. However, the paper looked like 1950's.
Post by Fliger747 »
That makes sense as that was the period that the 3"50 twins were supposed to supplant the 40mm quads. Missouri, still in the reserve fleet in the early 70's still had her quads under the aluminum domes.
bigjimslade
1951. I have not unfolded yet but it looks like all the 40mm tubs would have had 3" guns. When I get it scanned, I can see if any got omitted.
Post by Rick E Davis »
I posted a message about the 'planned" (never never done) installation of 3-in RFG twin mounts on the IOWA class, earlier and I can't find it to reference. In 1951, the USN planned on replacing ALL quad 40-mm mounts with twin 3-in RFG mounts. But, because of the greater weight of the new mounts, it was "generally" done on a basis of two 3-in RFG mounts for every three 40-mm quad mounts. I don't know what the plan was in 1951 for the IOWA class, but in late-1950s Armament Summaries, the total "ultimate" number of twin 3-in RFG mounts was to be fourteen (although I think USS IOWA would have had only thirteen twin 3-in mounts). Interesting enough, the SOUTH DAKOTA class was to get ten twin 3-in RFG gun mounts.
USS IOWA and USS WISCONSIN were the only two members of the class to get close to having the twin 3-in RFG mounts installed. USS IOWA had the complete fire control upgrades for the twin 3-in RFG mounts installed and quad 40-mm mounts reduced to thirteen. USS WISCONSIN only had the quad 40-mm mount numbers reduced to the sixteen number (which corresponded to the fourteen number of twin 3-in RFG mounts plus the two quad 40-mm mounts replaced by GFCS directors like USS IOWA had.
By 1955 the USN had realized that the 3-in AA armament was entirely inadequate defense against jet aircraft, particularly with stand-off weapons.
So I would be interested in knowing what was planned in 1951 for the USS IOWA class.
bigjimslade
Rick E Davis wrote: So I would be interested in knowing what was planned in 1951 for the USS IOWA class.
You'll have to sweat in anticipation for a a couple of weeks. The plans are at the blueprint shop and I am going on vacation before I can pick them up. :-)
At my age, I'll completely forget about it two weeks. :big_grin:
bilou06
Post by bilou06 »
Hello to all the modelers from all the world !
I want to built 1/700 USS New Jersey BB 62 in his last modern config. (excately in 1984 after lebanon crisis).
What is the best kit for this project ? TAMIYA or TRUMPETER ?
And that are the best "add on sets" (PE, resin, wooden deck, ...etc....) ?
Thanks for your answers.
Bilou06
Gilles
bigjimslade
bilou06 wrote:Hello to all the modelers from all the world !
Full hull or waterline?
bilou06
Post by bilou06 »
Waterline. And for an extra d�tailled model.
Gilles
bigjimslade
This is the largest the forum will allow:
001 copy.tif
001 copy.tif (163.57 KiB) Viewed 3810 times
