Carrier Builders Yard, whats on the Slipway
JimVarnellABH2USN
Post by JimVarnellABH2USN »
Red,
That looks amazing, I can't even tell where you cut the deck at. Did you use the rest to start the angle deck?, or was that totally from scratch? My biggest fear in doing something like that is cutting the deck in the wrong place and totally ruin a kit. I know with proper research you can find the proper answers or measurements, but I am still nervous about doing something like that just yet. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Jim Varnell
ABH2 USN/RET.
89-00
Eastern NC Modelworks
Up coming projects:
(Table 1 underway)Feb.2017
gtbred
Post by gtbred »
not mine. modeler from Japan did it. trying to have the guts to rebuild my 1/350 Hornet into a 1/350 SBC-125.
MM2CVS9
Post by MM2CVS9 »
Not good enough to scratch from scratch like these guys. Today I found a 1995 Revell 1/547 Midway clss/FDR kit at a LHS in Muskegon MI., never opened. It's a 1995, 1/547 scale repop of the original 1954 kit. I opened the box when I got home, everything is still sealed in the plastic bag. I couldn't believe it - as I know what this sells for - around $165.00 to $245.00. It was priced at $23.98 minus a 25% discount, $19.06 with tax. It's now in my stash.
Still workin on my 1/700 Hasegawa ESSEX - getting close. Learned quite a bit about scratchbuilding to alter her to Dec 1942 as commissioned. Next is my 1/540 Revell ESSEX H353-249 kit - gonna do her as it was when I was on her in 1961 and beyond.
EJ
" 1/700Hasegawa 45
" 1/700Dragon 44
" 1/700Trumpeter 43
" 1/540Revell vintage 62
" 1/350Trumpeter 42
Fair Winds and Following Seas
Mark McKinnis
Post by Mark McKinnis »
gtbred wrote:not mine. modeler from Japan did it. trying to have the guts to rebuild my 1/350 Hornet into a 1/350 SBC-125.
Get a 1/540-ish revell Essex, Yorktown, Wasp, Lexington kit and just glue it together for a reference model. Then drop a note to Nautilus Models and see if you can get a deck for the SCB-125 Essex Class ship that you want. Keep in mind, there were 4 flavors of SCB-125 done to 14 essex Class ships. 7 had Steam Cats and 7 had the Hydraulic ones. 3 had the starboard elevator further aft than the other 11. in 1/350 scale, I would use a Tico or Hanna kit as my donor kit. Hornet is completely wrong! I think that the island poses the most challenge in a scratch build. The SCB-125 Hull is a quarter of an inch wider at the hanger deck than the WWII kit. I figure an eighth inch piece of styrene down both sides of the hull blended into the bow and stern.
It is on my to do list but my stash is past the stupid point now. But man o man, I would love to do a Vietnam Bonny Dick or Shangri La in 350th scale! :thumbs_up_1:
Hippy Ed
Post by Hippy Ed »
MM2CVS9 wrote:Not good enough to scratch from scratch like these guys. Today I found a 1995 Revell 1/547 Midway clss/FDR kit at a LHS in Muskegon MI., never opened. It's a 1995, 1/547 scale repop of the original 1954 kit. I opened the box when I got home, everything is still sealed in the plastic bag. I couldn't believe it - as I know what this sells for - around $165.00 to $245.00. It was priced at $23.98 minus a 25% discount, $19.06 with tax. It's now in my stash.
EJ
That Midway class kit sounds kewl. I look foreward ta seein' ya work on her!!
Datz the same kit I got of the Essex & I just pulled out the instructions & it's copyrighted 1957 :big_eyes: I'll be startin' her up on May 1st :big_grin:
You've lost everything...
On the Bench:
gtbred
Post by gtbred »
Hi Mark, well my papercard/plastic scratchbuilted 1/350 Nam Hanna is almost done. still working on the island detail. like how Hong did is Hornet and I do want a Tonkin Gulf Shang in 1/350. :thumbs_up_1:
gtbred
Post by gtbred »
Image Image Image Essex Class SBC-125's forever. :big_grin:
Mark McKinnis
Nice Pics!! :thumbs_up_1:
JimVarnellABH2USN
:wave_1: Well I got a chance to do a bit of work on the TRUMAN, scratch built a few sponsons and field a few small gaps around the water line, found one area that needed some fine tuning and putty work, will finish that out in the next day or so. I have an idea :thinking: for the underside of the flight deck, will do the prep-work and layout soon. I will get more progress pics soon and post them. :thumbs_up_1:
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
Redlion615
Post by Redlion615 »
Evening - the papercard / plastic Sara looks awesome! If you don't mind me asking how do you guys do that? Do you build up a hull with the paper / plastic like a real ship and kinda go frame by frame or do you effectively make a block for the bottom of the hull then build up the hangar on top of it?
Jim - what are you thinking about the underside of the flight deck? I'm too tired to break out the glue and exacto knife tonight but I was measuring and drawing up a plan to add a little detail to the hangar overhead. I'm thinking about adding some real thin strips on the underside of the roof around the elevator openings to replicate the 'framework' that you see - some areas had the lights kinda recessed up in there, others seemed to have the lights dropped down. Know what I mean? If I figure out dimensions that look good I'll share if you're interested. I'm going for the 'looks good at a distance' not 'meets the print' spacing!
JimVarnellABH2USN
Hiya Red,
I was planning the same thing, as well as drop tank racks inside the hangar bay. I am taking the same approach in the structural steel beams and the light cans would be a good idea but I think using spare flt deck lighting from the island structures would be the better way to go, rather then try to scratch build something so tiny, I know on the HAWK, that's what we did for our amber lighting on the elevators at hangar deck level. What do you think about that idea?
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
MM2CVS9
Post by MM2CVS9 »
I'll be traveling for a bit and will be visiting the Yorktown museum in Charlson South Carolina and the Lexington Museum in Corpus Christi Texas. I will be taking photo's, but if anyone on this or any other thread has specific areas they would like photos of, let me know and I will do my best to get them and post them when I get home.
EJ
" 1/700Hasegawa 45
" 1/700Dragon 44
" 1/700Trumpeter 43
" 1/350Trumpeter 42
Hippy Ed
Post by Hippy Ed »
MM2CVS9 wrote:I'll be traveling for a bit and will be visiting the Yorktown museum in Charlson South Carolina and the Lexington Museum in Corpus Christi Texas. I will be taking photo's, but if anyone on this or any other thread has specific areas they would like photos of, let me know and I will do my best to get them and post them when I get home.
EJ
:censored_2: :Mad_6: :pout: Lucky pluck... Have fun & enjoy
On the Bench:
MM2CVS9
Post by MM2CVS9 »
Spread it around for me Ed.
EJ
" 1/700Hasegawa 45
" 1/700Dragon 44
" 1/700Trumpeter 43
" 1/350Trumpeter 42
JimVarnellABH2USN
EJ,
You are so lucky, be sure to enjoy yourself and have fun for all of us.
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
Hippy Ed
Post by Hippy Ed »
MM2CVS9 wrote:Spread it around for me Ed.
EJ
I'll see what I can do :thumbs_up_1: Just git me some pics of them ghosts on Lex :big_grin:
On the Bench:
kidcurrie42
Post by kidcurrie42 »
Hello All, well a big Wow is in order, some really great work going on around the Slipways.
Jim, Thanks for the great compliments, but i am a long way from being a Master modeler/builder, i am just a model assembler, just never found a model to assemble out of the box, the Trumpy Nimitz class should be the closest to this. i enjoy what i do, lots of research after deciding on what year i want to depict the carrier from, i find the research at times just as enjoyable as building. i may do a build post at some point, May or later.
EJ i would love to see the Port side of Yorktown and Lexington covered in detail, especially under the angled deck, this seems to be the least covered area, i find it hard to believe that we have 4 as museums, yet not one Plastic 1/700 or 1/350 kit. the research material is right there for the kit producers, i am sure the museum staff would be delighted to help.
Happy Modeling
John
Si Vis Pacem, Para Bellum
gtbred
Post by gtbred »
John is damn good! look at his work in 1/800 and 1/720. :thumbs_up_1: :thumbs_up_1: :big_grin:
Hippy Ed
Post by Hippy Ed »
gtbred wrote:John is damn good! look at his work in 1/800 and 1/720. :thumbs_up_1: :thumbs_up_1: :big_grin:
Yeppers. I corncur!!! :heh:
On the Bench:
JimVarnellABH2USN
John,
I really do hope you do a pic/ ref. build up post, your tips and tech. ability would be great. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
