Carrier Builders Yard, whats on the Slipway
JimVarnellABH2USN
Post by JimVarnellABH2USN »
Well,
I was able to get a little work in on the TRUMAN this evening, did some finish sanding on the port quarter, primed the lower hafe of the hull to check for flaws, found a few and made a plan on how to deal with them. :cool_1: I also found a bit of time to start dismanteling a couple of other CVN's form the rebuild stash, and I feel like this will be a good chance to experiment with scratch building, without going to the expence of buying new kits to pratice on. :woo_hoo:
Maybe I can learn to be as good as John. :heh: :heh:
Now I have a real problem, where to start, and which ship to create, the era, ect.ect.ect. I have alot of planning to do! I need to find some good photo's, Order some Starfighter decals, plastic stock and what ever else I can :thinking: of.
Jim Varnell
ABH2 USN/RET.
89-00
Eastern NC Modelworks
Up coming projects:
(Table 1 underway)Feb.2017
JimVarnellABH2USN
:wave_1: Today was a very productive day in the ship yard :smallsmile: I was able to get the TRUMAN about 40% near completion. About all of the hull is complete, primed, but did have minor setback, the primer on the port quarter next to the fantail started to orange peel about an 1-1/2" long section. I have a trick I use for this, have warm air blown on the section, and take one of the CnC's make up sponges to smooth the section up, don't rub it, blot it. Darn near prefect results, every time. :lol_4: :lol_4: For the warm air I use the CnC, :lol_pound: no really a hair dryer on low heat and hold it about 8" away as to not heat the plastic up. Caution should be used during this, don't over heat the plastic as it does weaken and having the heat really close will blister the paint and sag the plastic. If you have not tried this method before practice on a piece of plastic stock to develop a feel for it.
As far as my build goes I'll take some pictures on Monday to show the progress, and the area I repaired from the orange peal problem.
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
gtbred
Post by gtbred »
Redlion615 wrote:Evening - the papercard / plastic Sara looks awesome! If you don't mind me asking how do you guys do that? Do you build up a hull with the paper / plastic like a real ship and kinda go frame by frame or do you effectively make a block for the bottom of the hull then build up the hangar on top of it?
Jim - what are you thinking about the underside of the flight deck? I'm too tired to break out the glue and exacto knife tonight but I was measuring and drawing up a plan to add a little detail to the hangar overhead. I'm thinking about adding some real thin strips on the underside of the roof around the elevator openings to replicate the 'framework' that you see - some areas had the lights kinda recessed up in there, others seemed to have the lights dropped down. Know what I mean? If I figure out dimensions that look good I'll share if you're interested. I'm going for the 'looks good at a distance' not 'meets the print' spacing!
I build my carriers from the waterline on up section by section. like the real thing.
JimVarnellABH2USN
Hi Everyone,
Well while waiting for primer to dry I started to dismantle some of the other carriers that are in drydock, That was kinda intersting to take apart a ship without making more damage. :big_grin: I am planing to rework them as they where when commissioned at the start of thier career but that will be with the NIMITZ class only. Still need to order decals but that will be a bit later, when rebuilds are near done.
Lots of haze gray getting underway :woo_hoo:
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
Hippy Ed
Post by Hippy Ed »
:thumbs_up_1: :thumbs_up_1: Good ta know!!
You've lost everything...
On the Bench:
JimVarnellABH2USN
:wave_1: :wave_1: Quick question, how much of a difference is 1/800 to 1/700-720 scale, and is the difference worth it to modify a kit? I've seen a lot on ebay and started :thinking: . Now I know some are the motorized kits but I some are static display kits. Just wondering about the difference in size, I do prefer 700-720 scale.
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
Hippy Ed
Post by Hippy Ed »
JimVarnellABH2USN wrote::wave_1: :wave_1: Quick question, how much of a difference is 1/800 to 1/700-720 scale, and is the difference worth it to modify a kit? I've seen a lot on ebay and started :thinking: . Now I know some are the motorized kits but I some are static display kits. Just wondering about the difference in size, I do prefer 700-720 scale.
No real difference Jim :thumbs_up_1: I have the 1/720 Nimitz & a few 1/800 Forrestal Class and, I don't see any difference
On the Bench:
gtbred
Post by gtbred »
if i build this WWII Iowa will I get kick out of the birdfarm culb. order the LionRoar kit. Image
Hippy Ed
Post by Hippy Ed »
gtbred wrote:if i build this WWII Iowa will I get kick out of the birdfarm culb. order the LionRoar kit. Image
Livin' dangerously aint ya?! :whistle: :whistle:
I need a USS Wisconson ca 1953... My uncle did a Midshipman's cruise aboard her :big_grin:
On the Bench:
JimVarnellABH2USN
Thanks Ed, I was really wondering about that, I am planning on ordering some of them now. :thumbs_up_1:
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
JimVarnellABH2USN
Red,
I think we can allow you to build the IOWA, but get back to the birdfarm real quick!!!!!
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
Hippy Ed
Post by Hippy Ed »
JimVarnellABH2USN wrote:Red,
:lol_4: :lol_pound: :whistle: :whistle:
On the Bench:
JimVarnellABH2USN
:destroyer: :good_one: :lol_3: :rolf_3: :whistle: :whistle: :whistle:
OH NO we sunk his battleship :lol_pound: :lol_pound: :lol_pound:
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
Hippy Ed
Post by Hippy Ed »
JimVarnellABH2USN wrote::destroyer: :good_one: :lol_3: :rolf_3: :whistle: :whistle: :whistle:
BWAaaaHahahahaaa!!!!!.......
On the Bench:
JimVarnellABH2USN
WELL.................I have primed the flight deck of the TRUMAN, totally dismantled the BUSH, STENSIS, did some repair work to the REAGAN, dismantled the NIMITZ, as well as dismantled four other NIMITZ class CVN's. I did take photo's and my daughter is downloading the pic's on our laptop as I am using my son school laptop. I did take pic's of the underside of the flight deck that I added I beams too. :thumbs_up_1: They are not accurate in distance apart but more so for looks. Like I learned a long time ago "if it makes you happy that's all that matters". I plan on getting more done this weekend on TRUMAN, plan to paint the flight deck, after the primer cures for a day or so. :heh: I am thinking about painting the flight lines on deck, but I will practice on a old deck first, just to see if I like it, and see how long it will take to mask. Wish me luck, I hope I will keep my IN-sanity stable!! :whistle:
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
JimVarnellABH2USN
TRUMAN underside of flight deck, and sponsins I made.....
Kinda fuzzy pic's but I tried
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
JimVarnellABH2USN
Dismantling the fleet............... :Tirade:
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
JimVarnellABH2USN
and more ..............
John C. Stennis
John C. Stennis
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
JimVarnellABH2USN
The dismantled fleet :Tirade: {9} NIMITZ CLASS CVN'S
Ronald Reagan, only real salvagable CVN
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
Hippy Ed
Post by Hippy Ed »
Well Jim, Looks like yer keepin' busy! :heh: That underside of the deck [Truman] sure looks good :thumbs_up_1:
On the Bench:
