1/96th scale USS Clarion River LSMR-409
Re: 1/96th scale USS Clarion River LSMR-409
Post by Dave Wooley »
Hi John I have been following this impressive build and I shall be looking forward to seeing the method for developing the 5inch gun turret.
jcmackay
Building WT door master and work on the turret
Post by jcmackay »
Hi everyone,
One last posting for 2012. I trust everyone reading this had had an enjoyable holiday season. It has been busy for us, enjoying the company of family and friends, which means not much has gotten done on the 409. Today, though, I'll show you the little bit of work that I've been able to accomplish.
But first, I'd like to thank the following for stopping by and posting comments:
Neptune wrote:As usual your work is the definition of "crisp"!!! Sweet build John! Painting will even make it more impressive. Eagerly waiting for updates!!!
Thank you very much for your kind words, Neptune. That is the kind of motivation we all appreciate!
russclark wrote:the clarion river is looking good john,as for castings what ever the method you are useing it sure seems to work ,they all look great
Thanks for stopping by, Russ. Your comments and previous comments from others have persuaded me to take a bit of time to show everyone how I go about casting, starting with today's post. I'm looking forward to your feedback!
Both Richard O'Malley and Dave Wooley commented about the gun turret:
Richard J OMalley wrote:Hi John Your 409 is looking great. I like your turret construction.
Dave Wooley wrote:Hi John I have been following this impressive build and I shall be looking forward to seeing the method for developing the 5inch gun turret.
Richard and Dave, it's great to hear from you both! My ultimate plan is to build the turret up as a master, make a mold, and cast a copy for the model. Details on that to come and I hope you enjoy following the progress!
Many thanks to everyone for their comments! Now, on to today's update.
First off, let me tell you about the WT doors. On the main deck level, the 409 had 3 WT doors: 1 port and 2 starboard. Several vendors offer these, but since the turret is currently the limiting path on the project, I have time to build a master of the doors and cast copies. These were 'waffle' pattern doors and out of curiosity, I wanted to see if my skills were up to the challenge.
Before I discuss making the master, let me say something about casting. I've found that the best approach is to keep the mold as simple as possible. This often means taking a complex item and breaking it down into components that can be cast separately, such as with the Mk 102 launchers. One has to always keep in mind the limitations of the mold RTV and casting resin when determining the appropriate amount of detail to include on the master(s). Sometimes, it's better to forgo detail on the castings and add detail later. It is also a learning experience that takes practice and experimentation.
The first step is to make a good master. Let's take a look:
I began by cutting the door out of .030 inch styrene. Then, I used Testor's Plastic Cement to affix vertical strips of .010 x .040 styrene to the door.
Next, I used a variety of jeweler's files to cut the waffle pattern and bevel the edges.
Then, I mounted the door on a piece of .060 inch styrene.  This styrene will be the surrounding lip of the door. I outlined the door with a Sharpie marker to give a guide for trimming the door lip.  Then, I trimmed the residual material. I added the hinges from .020 x .030 inch and .010 x .020 inch styrene strip.  At this point, I decided that the master had adequate detail.  At this size, fine details such as door dogs would only cause more problems than they're worth. Later, I can add the door dogs, as desired.
Now that the master is finished, making the mold comes next. The WT door features detail on a single side, so I chose to make a very simple mold. Here's a look:
The first step in making the mold is to build a cofferdam around the part.  Yeah, I know this is a crappy photo. The cofferdam is made using LEGOS that I stole from my son.  Since he doesn't build ship models, he'll never know!  Any LEGOS assortment includes a LEGOS base, suitable for the base of the mold.  LEGOS provide a tight joint so that leakage of RTV is minor; the RTV readily peels away from the LEGOS.
Here's another shot. The blue material is non-hardening modeling clay, which provides a base on which to mount the door master.  Just press the part into the clay, but not too deep - it will stay in place. After the RTV has hardened, the modeling clay is easily removed and reused.
The RTV has been mixed and poured into the cofferdam.  In this case, I used Expert's Choice 2-part mold material (50/50 mix) from Bare-Metal Foil Co.  Let the mold sit for about 2 hours before separating, and allow 24 hours before casting to prolong life of the mold.
When the mold is separated from the part, it should look something like this and you are ready to cast copies.
In future posts, I'll show you how I make more complex molds. But now, let's take a look at the latest work on the turret.
I've been taking my time attaching the faces to the turret because I want it to be right. Here's some photos showing the turret coming together:
The basic approach has been to attach the face plates of .060 inch styrene using ModelMaster Liquid Cement, leaving room for 0.100 inch quarter round styrene strips at the joints. The interior frames provide the correct shape and size of the turret, adjusted for the layer(s) of .060 styrene.  Once the face plates are installed, I attached the quarter round strips using CA.  This shows the top plate with quarter round styrene attached on both sides.
All of the face plates have been installed, except for the 45 degree upper transition on the back of the turret, which is still open.  If you look closely, you can see the scratchbuilt turret is larger than the Haynes turret by about 1/8 inch.
The angled upper transition on the back has been closed with .040 inch styrene.  All that remains is to clean up the seams and file/sand the angled transition to the correct appearance.
At this point, the next step is to fill the seams and cut away the opening for the gun barrel at the front of the turret. Then, I'll begin adding detailing to the turret. But that will be a topic for upcoming posts.
Before I sign out for the last time in 2012, I want to thank everyone who's stopped by to check in on the progress. I especially want to express my sincere thanks to the many people who've posted their comments. :thanks:
Have a great 2013!
John :wave_1:
jcmackay
Some casting results and a 5 inch 38 update
Post by jcmackay »
Hi everyone,
First off, I hope everyone's 2013 is off to a great start! :woo_hoo:
Today, I'm going to pick up where I left off last time with a discussion of casting and an update on the 5 inch turret.
The WT door mold in the last update was very simple. A slightly more involved approach is required for parts that have detail on both sides or have multiple facets. As an example, in an earlier post, I told you about installing the ventilation blowers on the wheel house deck, port and starboard. Although I could scratch build the associated ventilation pipes, I decided to create molds and cast copies so that I could cast more of these in the future, if the need arose. The ventilation pipes can't be cast with a single-piece mold, though, so I decided to make a two-part mold. Here are some photos of the highlights:
Just like the WT door mold, I built a dam using LEGOS and mounted the master in a base of non-hardening modeling clay. Since it is going to be a two part-mold, it's important to have some method to index the molds together. I often use the cap off an old pen such as the one in this photo to make indents in the clay that will become the index pins.  The starboard pipe is on the left, the port is on the right.
Here's the first side of the mold. You can see the index pins formed by the RTV. The next step is to pour the other half of the mold. To keep the two sides of the mold from bonding together into a block, I rub Vaseline Petroleum Jelly on the surfaces of the first mold half. Then, using LEGOS, build up a dam around the first part of the mold tall enough to contain the RTV for the second part. Then, pour the RTV.
When the mold is finished, you're ready to cast. I've used a couple of different casting resins over the years and am currently using Smooth-Cast 310 resin. I've found there are a few tricks to using it, though. The first thing to be aware of is that this resin seems to give off a lot of gasses when curing. If you immediately pour resin into your mold, you'll end up with a lot of bubbles in the casting, which naturally usually accumulate around the surface that is oriented at the top when you are casting. Like any other resin, bubbles can be trapped in the casting along narrow details or corners. To minimize trapped bubbles, I mix the resin and allow it to sit for 10 to 15 minutes to 'breath.' To eliminate trapped bubbles, I use a toothpick or something similar to chase the bubbles out the mold after pouring the resin. Finally, I don't take for granted that all of the air will come out of mold after pouring in the resin. In the case of 2-part molds, I pre-load the mold halves with resin, chasing out all the bubbles and then assemble the mold halves together. Then, I pour in additional resin as needed to fill the mold. The parts can be de-molded after about 2 hours.
Here are some castings of the WT doors and ventilation pipes after cleanup. Again, the starboard vent pipe is on the left and the port is on the right.  All they need now is some primer and/or paint.  I've also included a casting of a davit for the small boat, which was also made using a 2-part mold.
Work has continued on the 5 inch 38 turret. Here are a few shots of the work progressing:
This shot shows detailing being added. I've probably gone a bit overboard by adding the framework under the turret.
A few more details applied. At this point, I'm already thinking ahead about how to make the mold so that I can capture all of the detail I'm going to add.   I'm starting to worry!
Next time, I'll show you the newly cast parts after painting and I'll update you on progress on the 5 inch 38.
John :wave_1:
jcmackay
WT doors installed and gun turret detailing
Post by jcmackay »
Hi everyone,
Since the last post, I've painted the WT doors and ventilation pipes, and installed them on the superstructure. I've also added quite a bit more detail to the gun turret. There appears to be a problem with the ModelWarships site because photos and text aren't uploading like they should. So, I've done what I could to upload some photos of the current status of the 409 along with some captions to describe what I've done.
In the coming days, I'm going to work on the flag bags and stern Mk 51 gun director tub.
John :wave_1:
In this photo, you can see the intake and exhaust pipes installed on the port and starboard sides of the superstructure.  Also, I've posed the davits in place, although I haven't painted them yet.  I'll paint them with primer soon and correct any blemishes and then they'll be ready to go.
A view of the starboard side.
A closer view of the WT doors and davits in this photo of the starboard side of the superstructure.    Before I can go too far with the davits, I have to build the small boat and its support framework, which is a little complicated.  More on that later.
In this photo of the port side, you can see the WT door under the superstructure overhang.  The wheel house door is also in place.  This door was smaller than the other three on the main deck level and is also a casting.  The rather obscene looking device just forward of the 5 inch gun is the King Post, which was used during underway replenishment.  To use it, the gun tube had to be rotated to its maximum elevation and then the King Post was raised to a vertical position as well, with guy wires holding it upright.
Here is a view of the 5 inch turret in its currently condition.  In this photo, you can see the comparative sizes of the Haynes turret and the scratchbuilt turret.
This photo shows most of the details installed.  I still need to add the counterweights on the forward edge of the turret and install the turret base ring, but other than that, it is complete. The various panels were made from .010 inch styrene sheet.  As I mentioned in a previous post, I often use Testors Plastic Cement.  One lesson I've learned when casting is that if you use cement like Testors or CA, you need to allow a lengthy period for the components to set before attempting to make a mold.  Although the joints made with these chemicals look dry, liquid cement and CA continue to give off gasses after they look dry that play havoc with RTV. Since I have plenty of other things to do on the model, I'll let the turret sit for a week before making the mold.
jcmackay
Tinkering away on the 5 inch turret and lifelines
Post by jcmackay »
Hi everyone,
I haven't made any dramatic progress since the last posting; I've been more or less tinkering on details and the 5 inch gun turret. The photos below show some of the recent progress.
I've begun making the molds for the flag bags and the turret. Hopefully, next time I'll be able to show you castings.
John :wave_1:
I've begun to start installing lifeline stanchions and railings.  This is a starboard side view of the superstructure as the rails were going on.  I used .020 inch brass for the stanchions and .015 inch piano wire for the rails, all held together with CA.
This is a port side view.  The railings have to be complete before I can even think about permanently attaching the superstructure to the main deck.  Another detail that has to be added is the stanchions that support the overhanging wings of the superstructure and the conning bridge.  Work on those will begin soon.
I've been dragging my feet on making the mold for the 5 inch 38 turret because I want to try to incorporate as many details in it as possible.  I finally quit procrastinating and have the turret ready for the RTV. The 5 inch turret had an antenna mounted to the square box on top.  I decided to use this feature as a fill path for the resin.  Along with the turret in this photo are the two types of flag bags that the 409 carried.  I'm going to make molds of these as well so that I can cast copies later if I want to.  On certain aspects of the flag bag masters, I've included extra material just to avoid the inevitable air pockets that otherwise ruin a casting.  Also, RTV sometimes doesn't like to release from highly detailed parts and the mold gets damaged.  To try to get the RTV to release easier from the masters, I sprayed a coat of floor wax on the masters.
jcmackay
Post by jcmackay »
Hi everyone,
Just a very short update to show you the finished turret mold.
John :wave_1:
This is the assembled mold.  Due to the complexity of the turret and the detail I wanted on the castings, I went with a two-part mold.  This used up almost every drop of RTV I had!
Here are the two parts of the mold.  I've done some spot repairs to correct air bubbles in the mold and am allowing the mold halves to cure.  Tomorrow, I'll give a try at casting a turret.
jcmackay
5 inch turret casting
Post by jcmackay »
Hi everyone,
My first attempt at casting a turret with the new mold turned out fine. After a bit of cleanup, it will be ready for paint. Here's a couple photos of how it turned out.
John :wave_1:
A view of the casting as it came out of the mold.  It turned out well but it will need cleanup before painting.  Lots of specks on the casting, but those are only bits of dust that were attracted by static electricity.
Another view of the turret.  The resin channel on the top of the turret will be trimmed down to make the base of the antenna that was mounted on the top of the turret.
Richard J OMalley
Post by Richard J OMalley »
John
The turrets are great .Looking forward to more .
jcmackay
Tiny bubbles...
Post by jcmackay »
Hi everyone,
It's been a frustrating couple of days working on the turret; more on that in just a second. But first, thanks to Richard for posting a note:
Richard J OMalley wrote:John
Great to hear from you again, Richard! :thanks: Congrats on the production line of tanker hulls, too!
As requested, here's a couple more photos to update everyone on the turret.
(On a side note, the website is still acting up and not allowing me to insert photos into the text, as well as not allowing me to insert smilies. Fortunately, I know the code for some of the smilies! :heh:)
John :wave_1:
At first glance, the turret casting looked like it might be fairly easy to clean up. However, since the resin is white, it is very difficult to see all of the surface defects until a coat of paint has been applied.   I was in for quite a shock after the primer went on.  I tried to fill in all of the visible defects prior to painting, but as this photo shows, the turret surfaces look like the face of the moon.  The turret isn't much bigger than a WEM paint tin, so these bubbles are pretty hard to see anyway unless you zoom in like I did here.
I can't recall having this much trouble with bubbles from previous resins I've used.  This particular resin seems to do nothing but produce gas.  Once I use up the small amount remaining, I'm going to switch to another brand because this resin requires entirely too much rework.
russclark
Post by russclark »
hello john,your method for casting is very informative,and you are right it is better to have a good not so detailed casting than to have one with lots of detail that takes more time to clean up than it is worth.i have not try'ed two part moulds yet ,but after seeing yours i may give it a try.
Neptune
Post by Neptune »
Hi John,
great molding, but indeed some small bubbles. Did you try or look for any method to create a slight vacuum in the mold? I know there are some people who attach some sort of suction to get the mold nicely filled.
I'm also looking at molding, but not sure which approach I'll take. The things I want to mold are much smaller than these turrets though.
The merchant shipyard
ADM
Post by ADM »
Nice turret, the bubble problem is easy to solve, it's not a matter of quality of the resin because when you mix or pour the resin there's bubble, you just have to make some vibration (the best solution) or repeated small shock below the mold to see all these bubble going out before it dry. Try it, it work !
jcmackay
Post by jcmackay »
Hi everyone,
Thanks to Russ, Neptune, and ADM for stopping by to post comments and suggestions! :thanks:
Neptune had this suggestion:
Neptune wrote:Did you try or look for any method to create a slight vacuum in the mold? I know there are some people who attach some sort of suction to get the mold nicely filled.
I'd heard of using a vacuum to get rid of bubbles, but until recently, it seemed like an unnecessary bit of extra trouble to go to. With all the problems with bubbles I've had, your suggestion has me rethinking that. I'm going to give it a try and I'll let you know how it turns out. Out of curiosity, how small are the parts you want to mold? :thanks:
ADM had this suggestion:
ADM wrote:...the bubble problem is easy to solve, it's not a matter of quality of the resin because when you mix or pour the resin there's bubble, you just have to make some vibration (the best solution) or repeated small shock below the mold to see all these bubble going out before it dry. Try it, it works!
I like this idea, too. Shocking the mold to free up bubbles seems like a good approach, but I'm struggling with how to actually do that. I'm going to try to find some way to vibrate the mold while the resin is curing but I don't want to hear any of you wise guys suggest I talk to my wife! :heh: :thanks:
I'll give another shot at casting another turret once I work out the technical challenges of the methods mentioned above, but for now, I've turned to a spare turret that I cast. I've set the first turret aside for the time being. I'll work on correcting all the bubbles in it at a later time. The second turret casting turned out better, but like the first turret, there are many small bubbles that only show up after painting. Here's a couple shots.
John :wave_1:
This is a shot of the second turret with primer applied.  I tried to fill in all of the visible defects prior to painting, but as this photo shows, there are still many small bubbles in the harder areas to work.
Another shot of the second turret with primer applied.
The turret with the main coat of paint and barrel installed.  The barrel is from B&D Barrels.  I'd hoped that the second coat of paint would hide the bubbles, but there are still too many bubbles that will need to be corrected.
DrPR
Post by DrPR »
John,
We occasionally pour resin castings to embed electronics used in oceanographic instruments. Bubbles in the resin can cause leaks so we must get rid of them. Most of the bubbles come from the mixing process, so you really only need to degass the mixture before you pour it.
We use a thick walled glass sphere (Benthos sphere) for the vacuum chamber because we had one laying around. It is good to many hundreds of psi so it is overkill.
http://www.ao-cs.com/Projects/urethane% ... oject.html
You can use anything that will withstand 15 psi air pressure. Just put the mixture in the vacuum chamber, pump it down and wait until it stops bubbling. Vibration will help the bubbles move to the surface. A wide shallow container will degass faster than a narrow deep one. You will need a slow setting resin.
Another trick is to paint the inside of the mold with the resin, working the liquid into all sharp corners. Then pour the rest of the degassed resin into the mold. This will eliminate bubbles at the surface of the casting.
Richard J OMalley
John
Buy a Harley !
jcmackay
Casting and installing the flag bags
Post by jcmackay »
Hi everyone,
Thanks to everyone for checking in and thanks especially to Phil, who wrote with a great description of how to deal with those pesky bubbles. :thanks:
Thanks also to Richard for his comment. I like your suggestion, too! :grin:
Today, I'm going to take a break from updating you on my turret travails and show you some work I did making molds and casting flag bags.
I mentioned previously that the 409 had two different styles of flag bags; the starboard flag bag was the typical rounded bottom type seen on most US Navy ships, while on the port side, the 409 had a deeper, square-bottom flag bag. The photos below show construction of one of the molds, casting the flag bags, and a shot of the flag bags installed.
John :wave_1:
This is the base of the square-bottomed flag bag.  As usual, I built a dam around the master using LEGOs.  This will be a single-piece mold; I decided against going to the trouble of making a two-piece mold because it will probably get limited use, plus, I can achieve what I need with a one-piece mold.
In this photo, I'm cutting the sides of the mold to expose the flag bag master.  During this operation, you can strategically cut so as to assure any seams in the castings appear in easy-to-clean-up locations.  You'll also need to cut the mold so that it will be easy to remove the casting from the mold.
Here's the mold opened up and the master removed.
Examples of the two types of flag bags, along with my old nemesis, air bubbles.  The extra bit of rectangular casting material along the sill side of the flag bags will be cleaned up to become the steps that the flag bags had.
First stab at painting the flag bags.  Will need some clean up.  Note the steps, which were painted the same Dark Sea Gray as the deck.
Here are the flag bags cleaned up, touch-up painted, and installed.  The port side flag bag was easy to install because of the extra surface area on which to apply CA, but I had to install a pin in the bottom of the starboard flag bag step to attach it to the superstructure.  I've installed the aft Mk 51 gun director tub, also.  The base and tub walls are of .010 inch styrene and the base framework is of .020 X .060 inch styrene strip.
GTDEATH13
Post by GTDEATH13 »
This build keeps getting better and better. Nice work with the flagbags.
NIKOS (NICK)
jcmackay
Permanently installing the superstructure, building the exha
Post by jcmackay »
Hi everyone,
Before I get into today's update, I want to first send thanks to Nikos for his post,
GTDEATH13 wrote:This build keeps getting better and better. Nice work with the flagbags.
Thanks for stopping by to post those encouraging words! :thanks:
In today's update, I'll tell you about some of the details I've been tinkering with.
First, I've finally permanently attached the conn superstructure to the main deck. The official nomenclature for the second deck of the conn was the 'superstructure deck' and as I'd mentioned previously, the superstructure deck had been expanded to port and starboard after the Korean War. The resulting overhanging spaces were braced with stanchions. Once I committed to installing the stanchions, it became necessary to permanently install the conn superstructure. Since I had gone that far, I went ahead and attached the wheel house and conning deck as well. No turning back now!
I've also been working on the diesel exhaust stack to the starboard of the conn superstructure.
Some photos of the progress along with descriptions are below.
John :wave_1:
A view of the superstructure from port.  I used .035 inch styrene rod for the stanchions.  The underside of the superstructure deck overhangs were drilled to accept the stanchions.  Corresponding holes in the main deck were drilled and then the superstructure and stanchions were carefully attached to the main deck with CA.   Closeups are a sure-fire way to show areas where paint needs to be touched up!
Starboard side view of the superstructure, showing the exhaust pipe.  The exhaust stack was not a single pipe bent to shape, but had several joints/transitions and 2 major bends, but for simplicity, I constructed it in 3 sections.  From the deck to a height of about 9 feet, the exhaust had a insulating jacket, which probably prevented burns to anyone making inadvertent contact. This section was made with 5/32 inch styrene tubing.  The next section of the stack, which made the first bend, was made of 1/8th inch styrene tubing.  To assure the tubing retained its curvature and didn't distort in the bend, I put a piece of 1/16th brass rod inside the styrene tubing before bending.
Another photo of the starboard side of the conn, showing the 3rd section of the stack.  This was made of 1/8th inch aluminum tubing.  Like the 2nd section, I placed a piece of brass rod inside the aluminum tubing to assure the tubing didn't collapse or distort when it was bent.  These photos don't show the  final item to go on the stack, which is a tophat.  Once that it installed, I'll paint the 3rd section and permanently attach it to the superstructure.
jcmackay
Installing the conning level roof
Post by jcmackay »
Hi everyone,
The LSMR-401 class ships were built on LSM hulls. Although the superstructure was considerably different, the 401 class ships shared with LSMs the characteristic of the same lack of weather protection for the crew on the conning level deck. In WW2 service, LSM crews found it advantageous to have a cover to shield the conn watchstanders from the elements, whether it was protection from the sun or squalls. Individual ships in the war zone soon improvised ad hoc covers that typically consisted of a tarp stretched over a simple metal frame. The LSMR-401 class had been designed to support the large-scale amphibious invasions used during WW2, but as their mission changed and their service life was extended, improvements such as a roof over the conn were made for crew comfort. Following Korean War service, the 409 was given an aluminum roof supported by stanchions over the conning level deck, with windows along the forward face and open on the remaining 3 sides.
The photos below show you the work on installing the roof on the conn.
John :wave_1:
I chose to attach the roof to the rangefinder base due to the advanced stage of work on the conn.  It would have been easier to install the roof before the conn was detailed and painted.   As this photo shows, the top of the roof was dark sea gray.
As you may recall, the rangefinder base originally had a screw on the bottom that anchored the layers of the conn superstructure to the main deck.  Since I've already joined the superstructure to the deck, the screw wasn't needed.  So, I replaced it with a styrene pin that would ensure it mounted in the right spot.
The roof is .020 inch styrene, with .030 x .060 inch styrene strip along the aft edge of the roof. Stanchions that will attach to the rocket director tubs are made of .020 inch styrene.  The framework on the rangefinder base is .020 inch aluminum and .008 inch brass, joined with CA.
A shot of the rangefinder base and roof installed.
A second shot.
A second shot.
And another shot.  From photos provided to me by veterans, it appears there were canvas closures on the outboard sides of the conn to seal off the area in really nasty weather.  I chose to omit these for simplicity.
russclark
Post by russclark »
hello john,as for air bubbles in your castings i have more trouble with the mould than the casting resin,my two part casting resin sets up fairly fast and does not seem to get air bubbles in it.but the moulding stuff gets lots of bubbles even if i stir it as slow as i can,it takes a long time to set so what i do to get rid of bubbles is put the container on my jig saw and run it slow ,it viberates a fair amount and gets most of the bubbles to come out.
