1/72 Bismarck
- Kiwimedic
Bismarck 1:72
Hi
I am sorry it will never be sold.
I have made a statement of intent and I have to stick to it.
There are to be 25 hulls only.
These are numbered.
19 to go.
Regards
Philip
These are numbered.
19 to go.
Regards
Philip
- JIM BAUMANN
Kudos for your ethics!
...scream of the chainsaw....
arghh!--but rules is rules!
Great project--watching this one!!
Jim Baumann
Jim Baumann
- Dave Wooley
- Torpedo
By the way, your picture cause a big discussion in a german forum HOW TO build such a function.what about black powder guns that good BOOM!!!!!
Reid Thumbs Up
http://forum-marinearchiv.de/smf/index. ... w.html#new
Latest thougt: Take 2mm Berloque-Amunition to ignite smokepowder and cause that effect. Blackpowder is far too dirty!
Problem in germany are the strict laws concerning everything that has to do with weapons and explosives. Therefor even such a small plaything has to be approved by authority
Uli "Torpedo" Setzermann
http://www.marine-forum.de - Das Kaiserliche Marineforum
Currently Building: SM TrpBt B-110, SM TrpBt S-37
Upcoming: SMS Derfflinger
- Dave Wooley
More from Phil on the installation of the power train for his 72nd Bismarck
A. Bismarck Power! You will see some thrust from them.
B. Another view. Note Kriegsmarine typical pointed tail on props
C. View from stern showing power leads for motors coming from a common Buss Bar System.
D. This view is for you Dave: You reverse the engine mounts and you can set the motors at zero height!
E. All joined up - Nice and neat
F. Powerhouse completed, Compact and modular. A few screws and electrical clips and it is out.
G.A stern view of progress.
H. View from stern showing wiring coming off Buss Bar.
I. Battery leads are attached to this bolt.
J. Bits of Brass hanging from the stern.
K.Power unit. Note colour coded clips. Port and Starboard.
- herrmill
H.A. Baker
Bismarck 1/72nd now available
Phil,
I congratulate you on your neat installation of the motors etc. Mine look like I threw a load of spaghetti inside and hoped for the best, but I'm gradually learning otherwise.
I'm following your build with interest as whenfinished your 'Bismarck' will be a very impressive piece of art.
More power to your elbow!
HAB
HAB
middle_watch
- Kiwimedic
Bismarck 1:72 Why 3 ESC's
The three ESC's are purely for control.
If you have a computerised Radio Set you will be able to manouvre the vessel on the Right hand stick. This will give you proportional engine steer.Bismarck will have the ability to rotate in it's own length.
(Once you have had it with a multi prop you will never do without it again.)
You will stilll have normal rudder control on the Left hand stick. You can use all of it(Rudder and engines) together and realy make it turn.
The power plants are Buhlers and I am running 24Volts through them and at dead stall (Use a spanner to hold the shaft.) they draw about 3 amps.
Hope this helps!
Phil.
Hope this helps!
Phil.
- Dave Wooley
Notch out keel for bolt. Do not flush solder or weld as it will not be strong enough.
All mounted up
Easy Flow them into place.
Once that is done file them down to the shape of the keel. Now invisible
Mark out position on hull and drill holes in hull for mounting.
Just sitting there not bolted up
Tightened up. Ready for bonding into position.
Looking good. Note: Keels or all brass work to be painted must be etch primed. If not the paint will not stick well.
All mounted up
- Torpedo
Cool! What do you mean by etch primed. What is etch primer?
- Kiwimedic
Bismarck Build. Etch Primer
Hi
(To Etch, is a chemical reaction that microscopically marks the surface to make it rough for painting)
It makes a key in the metal surface so that paint has something to stick to It is used mainly with Aluminium and Brass.
The yellow undercoat you see on the fusilages and frames of aircraft is etch primer.
It comes in many colours.
Hope it helps
Philip.
Hope it helps
Philip.
- Torpedo
Thanks a lot, that DID help!
- Dave Wooley
- Torpedo
VERY nice details. Maybe you publish also image details e.g. the grill and the anodes.
Although I have concentrated my interest on the imperial era (also for political reasons, as I have problems in identifying with the DKM) I must admit everytime that Bismarck/Tirpitz are real beauties!
- Dave Wooley
- vedro
- Torpedo
Very good work. I am afraid, what will come up with my Derfflinger...
- PetrOs
- PetrOs Modellbau
Are you doing it RC? If yes, WHY? Make a seat and a periscope in a main gun director, and you'll be fine!
Further kits in preparation.
- Kiwimedic
Bismarck Build. Sea Chest Intakes/Exhausts.
Dear All
I have been a bit quiet lately.
I have been to Dortmund, to the Model Show. Thanks to Guido and Dave Wooley for their help.
I made an alarming discovery. The intake/Exhausts in the Sea Chests are wrong! I was lucky enough to View an extensive set of albums on Bismarck. (The last few photos showing the intakes should be dis-regarded.)
When I arrived home the first thing I did was rip the old ones out. It has taken me a long time to construct new intakes etc. They are very fiddley and on a few occasions I ruined 6 hours work in 2 seconds. Once they were made they were installed and the damage from the old ones was repaired at the same time.
At the moment I am installing the Brass Casting Fairleads and the Anchor Clusses, also in Brass. These are exact copies of the originals.
I have also decided to add the detailing of the rivets on Bismarck, along with the lighter armour belting not usually seen on models.
(Yes folks Bismarck does have some rivets.)
There is a saying: You have not made anything until you have made it at least twice.
Dave will down load some photos when he can.
Regards
Regards
