1/200 USS NIMITZ - 2003
- Jaguar
Re: 1/200 USS NIMITZ - 2003
Thank you guys. Actually, the main structures are relatively easy to do and not to much time consuming. when i will enter the details, it will be another story.
- Capit�o Norbert
details...Jaguar wrote:Thank you guys. Actually, the main structures are relatively easy to do and not to much time consuming. when i will enter the details, it will be another story.
i know this story very well......
- Jaguar
- ADM
The Hull is going better and better
, you've added a lot of weathering on your S3 vikings !!!
- Jaguar
Thanks ADM, these hoovers has spent to much time on the sea
- Jaguar
Hello guys. Here is the last main structure, the stern starboard flight deck support. From here, and after a primer layer for the hull, i will star with details.
- Dave Wooley
Hi Jaguar I have been following your Nimitz build impressive work for sure . Question will you be installing any lighting ? The great thing about carriers is there is so much choice but trying to locate the drawings , well not always an easy task .
- Jaguar
Thank you Dave, and of course, you are right, is not an easy task to find the correct drawings. You always are looking for information for "secret places" and so on. Sometimes you have to rework some places on the carrier because you discover too late a mistake. It always happen with such a long time building projects.
Of course, the hangar deck, the flight deck, etc will have its lightning with different types of leds. Currently, i�m looking for information about an IC for lightning the center line of the landing area.
Thanks for your comments
- Jaguar
Hi guys.
New pictures about my long long Project
Yhe final shape of the ship is almost finished, and a primer layer has been aplied. Take a look
This is all for the moment. Thanks for your attention
- Capit�o Norbert
WOW i like your hull.
you are working fast.
what glue do you use to styrene with wood? cyano or ep�xi?
great job Jaguar
great job Jaguar
- Jaguar
Thank you Norbert. I use Cyano, lots of cyano. This is the fast stage of the constructio, From now, my work will be slower as i afford the details.
- Jaguar
Hello folks. Well, it,s time to start with details, so, i have decided to begin with the main doors of elevator n�3.
Here are the photos.
For the tie down padeyes i will use 2 mm. dyameter 5 arm wheels for navy doors, from floating drydock.
Details being added to main door
Thanks for viewing
Thanks for viewing
- ADM
Beautiful Hull and your work with details is just superb !
- Jaguar
- Capit�o Norbert
i am very satisfied do see this build.
i like the details and attention to the construction.
hermoso
hermoso
- Jaguar
Thank you Norbert. I�m installing the antiskid layer in the hangar now. After that, i�ll paint the main doors of elevators 3 and 4. New pictures soon
- Capit�o Norbert
i will be waitingJaguar wrote:Thank you Norbert. I�m installing the antiskid layer in the hangar now. After that, i�ll paint the main doors of elevators 3 and 4. New pictures soon
- Jaguar
Well, here we are. I continue working on the hangar bay.
Main door of elevator n� 4, i discovered that is better to build and paint the parts one by one before glue them together
Now, starting the tedious work of make the holes for the padeyes.
I have used tamiya putty to simulate the joins between the antiskid plates
That,s all. Next to come: to paint the hangar bay
- Perth_shipyard
Fantastic work!
what are you using for the decks? looks like card of some kind?
AT
1/72 Arleigh Burke flight iia
viewtopic.php?f=13&t=154767
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 HMAS Perth 1942
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
