I saved the ship, mostly. There was significant damage to about the first millimeter or two due to the resin, so she'll be in a nice, stormy sea!
New base is as follows:
1) Zeppy has been glued down.
2) Plaster of Paris was used to provide the larger swells. I used marked toothpicks to show high/low of about 15' foot seas and swells. It worked wonderfully. Plaster did not extend all the way to the hull.
3) Heavy gloss medium gel was used to fill in between the ship, plaster, and form the outline of the bow wave. I also coated the plaster to smooth and brush strokes not taken care of by sanding. A brush was used to stipple the water. My goal was to make it look choppy without appearing too overscale.
--INTERMISSION--
I will not complete the ship. All PE, figures, and planes will be added, with the exception of certain aspects of the rigging that could be destroyed by an errant finger.
--/INTERMISSION--
4) Base paint will be a black/grey/blue to make the ocean look dark, angry, and foreboding. I'll add some variation via thinned colors (sort of like Jim Baumann does) to break up the uniformity. Some wave crests will be lightly colored.
5) Lighten along the bow wave and hull as per sargentx's suggestion to add depth. I will then add some cotton saturated with gloss gel to simulate the mixing of the wave underwater, along the hull, and wake.
6) Resin, properly mixed this time. Mild stippling to add some variation to the surface.
7) Mixture of tissue (Again, as per Mr. Baumann) along the bow and cotton (as per sargentx) at the wake to try to add scale water effects. This will be held in place via gloss gel.
The Zeppelin will be passing through heavy seas, so her deck aircraft will be mostly tied down. I want to get the ship done and dull coated before messing with the sea. Hopefully, it would end up horribly.
I've finally made a little bit of progress on the island. I'm adding railing. Once that's done, she'll get a platform on the funnel and her range finders. I'll then add masts and hand paint where necessary. I also have to finish her light AA which I am NOT looking forward to... Pictures of her in the setting base:
