probably too late, but this is how I do the windows...
thin gloss black paint, a very small drop at a time in each window with a small brush, work it out to the edges of the recess for each window. The frames look big enough to hold it in. Just do one side, keep the windows flat so the paint does not run. let the paint dry, turn tower over, do the other side (and when that's dry do the front..)
If you make a mistake, just rub the wet paint off the frame. After all is dry you can touch up any rough edges with the light grey again.
Kitty Hawk 1/700
Cezary
Re: Kitty Hawk 1/700
Thanksroym,much too late, but I will try to use it in the future. Thank you very much!
