I think all of them are a good representation of the situation at least you get to make a judgment based upon a continuous set of footages that show different lighting conditions and how they affected filming...Jeff Sharp wrote:Here is some of the footage discussed above directly from the archives.
And here is the Nevada footage showing that thin blue line at the top of the boot topping very well.
California footage:
West Virginia footage:
Especially the scene where the children are being led out of the school and into their air raid ditches.... you have clouds going over which shows how dark it would get when the clouds were blocking the sunlight and how bright they would change to when they finally passed by.....
IMHO, it tends to reinforce my opinions on the ships colors especially the Nevada's footage where you get a direct comparison between 5D dark grey ships superstructure, (even though very worse for wear) & 5-S/N on the tug and the repaired ships hull just above the boot topping...
All the same light, same angles, same camera. If any of the colors are shifted, (which they probably are) they are all shifted the same amount... gives a very good reference between them as to how they compare with each other...
Even at this age, or the age at which they were digitized, the color shift doesn't effect the image perception that much....
Nevada was in 5-D, California most probably in 5-D, Wee Vee in 5-S, Arizona in 5-S.... It's a shame that the Maryland and Tennessee were gone at the time of these films cause it would have settled it for those as well....
Any way, I believe these films serve to strengthen my opinions....
Thanks Jeff for posting them, I know it took some serious time and effort to find them.... (the archives being what they are)
EG
