Calling all Soviet Kresta-class (беркут) Project 1134 & Kara-class Project 1134B fans
- Neptune
Re: Calling all Kara and Kresta class fans
The Flat Screen was a test. There's something special about it, but I can't really recall what at the moment. I THINK, it was a phased array like US SPY-1 type of radar (although this one is rotating of course). I'm not sure, but I think that was the special thing about it, it can take a lot more targets than the regular Top Plate or Fregat radars. Kerch and Azov were both used for testing later in their lives. Kerch is still there, she's receiving occasional upgrades as she's sponsored by the city of Kerch. For a long time, a lot of things were regulated and provided by the city which sponsored the ship (and I think that actually still stands as of now).
The merchant shipyard
GaryM
Has anyone purchased these books? I would like to have an indication of the quality and price.Max Braun wrote:Hi Guys,
Just like to draw your attention to the 2 newest books published recently in Russia.
One - dedicated to Kresta-I and Kresta-II Classes.
Another - to Kara Class.
Both books are vividly illustrated with huge number (several hundred) unique photos plus genuine building drawings. They are the most detailed books on the subject ever published in the world. Highly recommend! I obtained my own copies through the site: http://siriusm.homestead.com
Covers attached above.
Regards
Max
Cheers GaryM
Sea_Burn
Hi!GaryM wrote:Has anyone purchased these books? I would like to have an indication of the quality and price.Max Braun wrote:Hi Guys,
Regards
Max
Cheers GaryM
Lock this page: http://kresta-ii.ucoz.ru/blog/2009-03-23-20
http://kresta-ii.ucoz.ru/blog/2009-03-23-19
http://kresta-ii.ucoz.ru/blog/2009-03-23-18
http://kresta-ii.ucoz.ru/blog/2009-03-23-17
http://kresta-ii.ucoz.ru/blog/2009-03-23-16
http://kresta-ii.ucoz.ru/blog/2009-03-23-15
http://kresta-ii.ucoz.ru/blog/2009-03-22-14
http://kresta-ii.ucoz.ru/blog/2009-03-19-13
http://kresta-ii.ucoz.ru/publ/
GaryM
Thank You Sea Burn most appreciated.
bootneck42
I found this photo amongst my old service photos.
I've also attached a chart on Soviet radars so that you can check out the fit in the photo
Mike
Mike
GaryM
Hello Mike, Thanks for those, sorry it took so long to reply. I see you were also a recipient of the "Joint Services Recognition Journal" I don't suppose you happen to have any copies featuring the Russian Projects 159 Petya or Project 204 Poti?
- oldnavalguard
A great ship hopefully we in the Western Navies will never have to deal with one
Cheers ONG
Cheers ONGToo the Sea...When I was a young boy I wanted to sail around the world
- Solomo
Hi all:
Not a very active subforum, but I wondered if anyone knows a source for the Czech "JaPa" 8-sheet plans of the Kresta I missile cruiser "Sevastopol" c. 1969 in 1:100 (or 1:200) ?
I've seen a copy and they look pretty good. Maybe Dave Wooley knows?
Best,
Paul
Best,
Paul
- AyalaBotto
Kerch (713), Project 1134B Kara Berkut Missile Cruiser
Hi,
Any idea about the deck colour (or colours) of the Kerch (713), Project 1134B Kara Berkut Missile Cruiser of the Russian Navy, in her present version?
I couldn't find a good aerial colour photo, and I suspect that some decks are painted with a different colour (perhaps a dark grey colour), rather than the standard Russian "red brick" colour...
A photo of this ship:
Source: https://commons.wikimedia.org/wiki/File ... 009_G1.jpg
What do you think?
Thanks.
Ayala Botto
What do you think?
Thanks.
Ayala Botto
Re: Calling all Kara & Kresta (???? ? ??????) fans
Is 2008 present enough? Navsource's photos show red. http://navsource.narod.ru/photos/02/206/index.html
- AyalaBotto
Hi Timmy,Timmy C wrote:Is 2008 present enough? Navsource's photos show red. http://navsource.narod.ru/photos/02/206/index.html
thanks a lot for the link. Highly detailed photos that will be usefully to my project!
And all decks painted with the standard Russian "brick colour"
It seems that none of this ships is in used today. All of them has been scrap.....
Ayala Botto
maxim
What is with Kerch now? Will she be back in service?
What is with Ochakov? She was raised again. But I cannot imagine that she will be ever back in service.
- AyalaBotto
Hi,
Conflicting reports regarding Kerch status after the fire that broke out on November 2014 in Sevastopol.
Depending on the sources the ship will be scrapped or repaired and returned back to active service.
Ayala Botto
Ayala Botto
- Rick_H
Looking at Kresta I class (Pr 1134) Side Globes ECM:
It appears to me that as built, all four domes were arranged in a vertical column. And it appears that when Vice Admiral Drozd was modified with the ADMG-630 ciws, the lowest dome was moved aft and higher than it was originally.
Can anyone confirm or correct me?
Rick
Rick
On the workbench:
1/700 HMS Swiftsure - Combrig
1/700 CGC Chelan - White Ensign
1/700 HMCS Forrest Hill - HP
1/700 Ulsan - Kobo Hiryu
--and dozens more
--and dozens more
- ozpirate
If anyone here wishes to build a RC model of the Kresta 1 or 2 and Kara contact me.
I have plans for you if your interested.
mick.elst (at) gmail.com
Building
1/72 Admiral Kuznetsov
Mick
Tumut Australia
Mick
Tumut Australia
- Rick_H
Has anyone had any success in constructing either the Scoop Pair or Peel Group radar arrays in 1/700?
For the Scoop Pair, I am considering use of two SPS-10 arrays, one above and one below.
Thanks!
Thanks!
On the workbench:
--and dozens more
--and dozens more
- Brett Morrow
Rick, You are correct about the ECM globes on Adm Drozd, the lower dome was moved several times over a number of years, but was moved back to its original position each time.
Adm Zozulya also had her lower globe moved.
JoeP
Re:
Hello all,maxim wrote:My own list, mostly confirming your list:
Kara
� Nikolayev 538, 155, 539?
� Ochakov 539, 707
� Kerch 713
� Azov
� Petropavlovsk 712
� Tashkent
� Vladivostok
Has anyone done the research to update the numbers? I am looking for hull 547, which "made friends" with USS New Jersey's battle group in September 1986 in the Sea of Okhotsk. I'm building a diorama of that group, and decided to place a Kara near them. Also reported were a pair of Grisha IIIs, for which I don't have photos.
- Brett Morrow
Your ship was the` Tallin` renamed Vladivostok in 1990.
She carried the pennant number 547, applied in 85.
In 1987 her number changed to 531.
mikasa
A friend of mine gave me a Kombrig Vladivostock to build. I'm looking for photo-etch sets for the radar antenna. I've found the GMM sets for aircraft carriers and for cruisers/destroyers. Are there any others? From the pic of them posted earlier it looks like there is a Big-net antenna amidships and I don't see them on the GMM sets.
