1/350 USS Shangri La CV-38 (1945) - Trumpeter
You see it on the port side to go around sponsons... routed early and then left in place when the sponsons for the hangar cats were removed. Honestly, I don't have access to the plans to tell you WHY they were routed the way they were.
Capt652
CV-38 Update
Post by Capt652 »
Hi all! Happy Birthday USA!
I've been working on the paravane tracks after the recent discussion on the subject. The pictures submitted in the posts showed some collective detail which, I believe represents the essex class build. I had purchased the L'Arsenal paravanes which are certainly much better than that supplied by Trumpeter. And I had also long ago mistakenly glued them to the fantail area... not the L'Arsenal, the trumpy ones which will have to stay. I looked around the hobby shops for some square stock brass, the closest look to what I believe were steel I-beam tracks. But I had no luck finding anything. So I used 22 gauge steel wire and ground the outside flat. I plan to also add vertical bracing after my flight deck is glued down the final time.
And a view of the L'Arsenal paravane
Capt652
Timm Smith
gtb -red
Post by gtb -red »
Man ,Cap what the #%#^& are you and Larsen doing. I'm putting alot of detail in Ranger? I don't think so! :worship_1: :faint: :crazy: :thumbs_up_1:
Capt652
1:350 CV-38 Shangri-la 1945
Post by Capt652 »
Hi all-
More work on the stern and starboard aft sections. After some talk in the CASF Essex-class area regarding the shape of the rear sponson I re-worked mine. The top edge of the sponson was not straight across as molded on the trumpeter model, so I removed the top rolled edge I had already applied and cut down the height. From forward to aft the height did increase as the splinter shield changed from longitudinal to transverse to a point just before the radius changed to the straight transverse behind the railing. The hard part was bending the wire to match the new slope. I also changed the railing on the main deck on the starboard side where it meets the large bulkhead. The Shangri-la had a short (railing height) bulkhead that ran transverse toward centerline a few feet. Between it and the large bulkhead I used GMM PE railing that represents removable chain links.
The starboard aft area from main deck up to the flight deck overhang needed a lot of detail. I had commented already about the potato lockers and piping on the Intrepid (AOTS Intrepid pictures and plans)and whether the two were ralated; with very few pictures in my possession of Shangri-la and just a couple pictures of that area of any of the other Essex-class carriers I worked out some details. Piping, vents, conduit, stairways, and structures were added. I used the ATOS Intrepid and the Raven Essex-class Carrier plans for the stairway. I gathered from the plans that the earlier carriers had the stairway start at the main deck away from the bulkhead and the later built ships with the first stair run against the bulkhead (minor detail).
Capt652
Timm Smith
Capt652
Re: 1/350 USS Shangri La CV-38 (1945) - Trumpeter
Post by Capt652 »
Back to work after having to take holiday while the sun is warm and camping is the thing to do... anyway I worked a little on the struts for the prop shafts. The Trumpy kit is lacking the detail that the essex class carriers had. Their single strut in real use wouldn't adequately hold a prop shaft turning with the potential of 150,000 shaft horsepower (or is it 150,000/4 per shaft?). The bracing I created is close to the look of the real ships. At Researchers@Large Tracy posted pictures of Intrepid in dry dock after torpedo damage to the rudder and fantail. This picture shows clearly the attachment of strut to hull for the center screws.
http://www.researcheratlarge.com/Ships/CV11/Photo75.jpg
I also found this picture of Shangri-la's prop shaft configuration.
download/file.php?id=3634&mode=view
And here is what I came up with...
I think I'll try some white glue (Elmers) to see if I can add a radius to the point of attachment of strut to prop bearing.
Capt652
Timm Smith
Capt652
Post by Capt652 »
Hi all!
Final work on the island... After studying pictures of Shangri-la taken in 1947 at PSNY that are very clear, and comparing those to pictures of Shangri-la in Sept.- Oct. 1945 that are quite blurry, I am now comfortable with building the final details of the island structure, especially the masts, antenna, and radar. I'm trying to be accurate with this area as probably all essex class carriers were different and simply by glancing at the island one can identify each ship. (I think everyone that his spent time scratch building these tiny parts have spent a far share on their knees trying to find one in the carpet - I know I have!!!) Firstr is a picture from PSNY and then my representation.
Capt652
Timm Smith
Capt652
Post by Capt652 »
Capt652
Timm Smith
FlyingLow
Post by FlyingLow »
Terrific detail Capt652. I am working on the island of my Tico right now and even though there are many differences I appreciate clear photos showing similarities. :thumbs_up_1:
prowannab
Post by prowannab »
Very ,very nice work. I applause your work so far,can't wait to see more!!!!!
Capt652
Post by Capt652 »
Been working on paint, this time the preliminary flight deck colors. I delayed doing stripes and numbers quite a while trying to find accurate information for Shang in Sept. - Oct. '45. A picture of Shangri-la taken during 'Navy Day' 1945 (some picture captions incorrectly date the picture as '46) show a white or light gray "Z" on the forward end of the FD. I couldn't find a picture in this time period that shows the aft end of the FD, all pictures of Shang have airplanes parked where the marking would be. For lack of better information I concluded that;
1.) The aft marking would be the same color, white / light gray.
2.) The aft marking would be the number 38 as opposed to another "Z".
If I'm wrong, so be it... but not to stress over this issue too long I mixed some paint and applied some color.
I had already purchased the GMM aircraft carrier decals, and of course the decals are flat black, but I didn't want black. I carefully cut out the three, the eight, and made a Z out of card stack and then using them for a pattern I made stencils out of .01" Evergreen sheet styrene. After looking at all the fantastic models in the gallery and seeing that colors have to be muted to look correct in scale I mixed flat white and flat black to come up with off-white for the "Z" and "38" and a darker gray for the hash marks.
I think that after weathering the deck should look nice and 'beat up'!
Capt652
Timm Smith
kidcurrie42
Post by kidcurrie42 »
A beautiful build Capt :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
John
Si Vis Pacem, Para Bellum
Elvis965
Post by Elvis965 »
Gorgeous! :thumbs_up_1: :thumbs_up_1:
Bob
That is fantastic! I love it.
Capt652
Post by Capt652 »
Work continues on the gallery deck catwalks and 20mm guns. A quick word on these 20's; I decided to stay with the Trumpy supplied guns from the kit. I looked at all the options and I know there are after market choices. I minimized by not adding the GMM PE I have (except for the splinter shields). The Trumpy gun barrels look fat and ugly so I couldn't justify spending the time adding the PE when the result would end up being less than satisfying.
I worked on replicating the details of Shangri-la, adding extensions and missing sections of catwalk. Besides the few pictures I have of Shangri-la at this time period I used pictures of Essex class ships from AOTS Intrepid, Warships Perspectives Essex class of WW2, Ravens' Essex class book, and Squadron Essex class carriers for generic details.
Added features;
Gas stations made of copper wire and bits of PE scrap.
Fire hose racks and FF nozzles.
Vertical ladders and GMM inclined ladders with platforms.
I really liked how the bow corner gun directors came out, a feature that is quite prominent on long hull ships. The railing at the bottom of the flight deck ends radius' (although I not exactly sure what they are for) were added. Other gun director platforms were scratch built from brass PE fret as were mounts for the four whip antennas along the starboard side.
Flight deck perimeter lighting.
I still want to add navigation lights on all four corners and other FF equipment (extinguishers and foam cans)
Timm Smith
Capt652
Post by Capt652 »
Timm Smith
Capt652
Post by Capt652 »
Timm Smith
Capt652
Post by Capt652 »
Timm Smith
Elvis965
Post by Elvis965 »
Like I said before....gorgeous! :thumbs_up_1:
Bob
Capt652
Post by Capt652 »
This the first time I ever messed around with rigging, and I am still intimidated with the whole process. I tried - without success - stretching sprue, but could not get even fine lines. :Mad_5:
I went shopping for some fly tying line (somewhere I read a posting that '20 den Uni-Caenis' was a good size for 1:350 scale) but couldn't find any. I think that these rigging line should disappear from view only inches away from the model or they look way over-scale. I finally stopped in a outfitters store in Traverse City, MI and talked to a most helpful fly fisherman who took the time to explain fly tying lines (and even experimented with different lines and CA glue). He suggested and I purchased 8/0 black polyester line. Back at my bench I studied the reference materials I have for layout. I couldn't find diagrams that showed both attachment points for the flag halyards. Side shots of the flag bags don't show where the halyard attaches to the yardarm. Yardarm attachment points don't show where the line attaches below. Does the most aft line at the flag bag go to the outer most or inner most point on the yardarm?
I can't wait to do a ship with lots of rigging stem to stern!
Overall I'm happy. :D
Timm Smith
Capt652
Post by Capt652 »
Navigation lights and whip antennas
Hi all :wave_1:
Finishing details again, this time the above mentioned parts. I added the perimeter flight deck lighting, red on the port side and white on the starboard. Also added the leading edge nav lights. These lights appear to be a hourglass shape, from what I could tell from various blurry pictures.
Whip antennas, in the case of the Shangri-la numbered eight, four on the island and then four on the starboard side of the gallery deck. I used stainless steel wire, tapering the top in my Dremel, although it took a long time as stainless steel is pretty tough. There was a large square object at the bottom, possibly a counter-weight that I made from polystyrene. I know that these antenna would pivot horizontal and therefore the base would have to allow that. I didn't scratch build that way though, so a slight variation.
To complete this ship I have some weathering to do and then a coat of Dullcote to seal. And I have to build my airwing.
Timm Smith
Return to “Completed Models”
