At IPMS Houten I bought this great reference book for the Loire 130.
Strange how there are only hardcover references in the bookstores for this important French navy plane.
This catapult would later be used on Strasbourg and is here tested.
I will have to apply this lettering on the bow from the BBB set.
The Dunkerque emblem on planes.
A special elevator to move planes from the hangar to the catapult.
The colorful 1942 scheme on Strasbourg.
Blueprints for the planes. In total I will make about six of them, counting Richelieu in.
Now back to Dunkerque with the catapult PE from Shipyard.
The platforms are simplified to ease construction. Both sides of the turntable have railing. The frame seems a true copy of the pictures.
It's a clear improvement over the kit PE, there are now rivets and a more sturdy appearance.
Going over to Strasbourg, an addendum for the planes was done to the PE sheet.
In comparison with Shipyard the frame is quite different in the details. The rivets are recessed and the front part seems more correct.
The top view shows larger holes, a stepped "puzzle" edge and it is overall a bit more slender.
Bigblueboy reproduces the pressure system with a wire running on cams and two supports for a cylinder, though to scratch this is not suggested.
The cylinder is visible on this shot, but it also shows an error in the BBB frame. I will not correct this to avoid deformation of the catapult.
Another problem is the absence of a fitting hole. In this case I can line it up with the Dunkerque catapult.
Scratching the cylinders from 1mm Evergreen. A second small cylinder is found at the rear. I introduce these in both catapults.
To glue these catapult PE parts, in hindsight it was a better idea to reduce the gluing to a minimal to keep open the many minuscule fitting holes for the BBB platform supports. BBB uses 18 of these and on each of the 8 platforms are extra brackets that are introduced in these holes. A lot of them had to be drilled because of CA seeping into them.
This small crest was placed on the front.
The BBB catapult only had railing on the starboard side. The port has a lifting device, but you should not rely on the diagram for constructing this, because the photo near it shows the arm reversed with the pulleys out, which makes most sense.
Here some doors were added, but without a hatch like in the kit. I have lots of doors left with turnwheels, but no reference or instructions where these would go.
The boat cranes are next. The arms are easy to bend.
But the base is difficult, the PE parts break after removal and are too brittle. Also the instructions fail again, now the diagram is more logical than the pictures. If these are followed, the back of the crane is glued over some floor texture.
An axle is thrust through the crane arm, but this should be done before adding the little pulley to the base. That can hinder the axle.
These ladders are quite brittle to remove from the sheet.
